MZ Riders
RT125 restricted?
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: 125 cc
Author Message
simon
PostPosted: Wed Nov 02, 2005 5:07 am    Post subject: RT125 restricted? Reply with quote
hello.
is the 2002 RT125 restricted?
if so how can i de-restrict it?
also is there any productes i can get that will increase the performance?
regards
Si
Back to top
PostPosted: Wed Nov 02, 2005 6:04 pm    Post subject: Reply with quote
some are and some are not
the restricted ones have a sensor unit on the rear wheel
near the disk brake and a wire that runs up the frame to the
cdi box
the cdi box must be changed to up grade it
_________________
www.qrz.com/wd8cyv
Back to top
mxsteven
PostPosted: Thu Nov 03, 2005 2:29 pm    Post subject: Reply with quote
i think the restriction sensor can be bypass which we can removed it.... if it cant be removed then we can try to use frequency converter which can cheat the CDI... if not mistaken the sensor is run on pulse... the restriction can be over come by removing the sensor or put a magnet or a metal at the sensor so that it will be in a "NC" bypass mode. By removing it it should be in "NO" mode.
that is just my logic idea.... dont take it too serious hehehe...
cdi box
_________________
Where u go, it's up to u,
Think b4 u do, Ride safe.
MXsteven
Back to top
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
PostPosted: Thu Nov 03, 2005 11:42 pm    Post subject: 125 info links Reply with quote
here is a link on sprocket changes
http://www.mzriders.com/viewtopic.php?t=49
and some more useful info
http://www.mzriders.com/viewtopic.php?t=804
_________________
www.qrz.com/wd8cyv
Back to top
herbalist
PostPosted: Fri Nov 04, 2005 6:50 am    Post subject: Reply with quote
cdi box
How would I go about de-restricting my SM125?
is this a lenthy procedure.
Or just a case of finding the restricter and removing it?
(I have a friend who has been riding his SM for two years now, and he thinks the bike just de-restricts itself after 2000 miles.
as he is now getting an extra 20mph, does that sound likly to you?)
P.S. Thanks for all your help trying to fix my idle problem but it just fixed itself after I refueled.
Rolling Eyes
Back to top
mxsteven
PostPosted: Fri Nov 04, 2005 7:36 am    Post subject: Reply with quote
heheh i think after 2000 miles the sensor went kaput. .. when the sensor kaput which gives the bike no restrictions... u may try to remove it
cdi box
Rolling Eyes
_________________
MXsteven
Back to top
simon
PostPosted: Mon Nov 07, 2005 5:38 pm    Post subject: Reply with quote
is there anywhere that i can order a new exhaust from
btw - thats a better / louder exhaust, not the box standard one Laughing
Back to top
rotus
PostPosted: Wed Nov 09, 2005 10:52 am    Post subject: SM exhaust Reply with quote
You can try to see if there is a dealer for M4 exhausts there. I have one and it sounds great (braaap).
I'll try to get pictures up of my bike. The can is scratched a little from racing, but you can see how nice it looks on the bike.
Back to top
herbalist
PostPosted: Wed Jul 05, 2006 8:05 am    Post subject: Reply with quote
cdi box
Sorry to bump an old thread, but my SM does not have a sensor unit near the back break or a wire.
can I still de-restrict it?
if so how???
Back to top
PostPosted: Wed Jul 05, 2006 11:38 am    Post subject: speed Reply with quote
if your sm does over 55 mph it is de restricted
i think the restricted models all were for germany
you must add a rear wheel speed sensor and different cdi box to make it a restricted bike
people think these things are restricted for 2 reasons
used to a 2 cycle bike with 5 or 6 more HP
or there riding one that is not broken in ...
mine had a very tight engine and it was almost 3500 miles before it got
loose and would wind up
this thing is a moped between 2,000 and 5,500 rpm ....6,000 to 10,500 rpm its a motorcycle
mine is geared 16x52 and does 69mph flat out at 10,500 rpm
original gearing was 16x49 and some where between 75and 80 was the top speed i saw from it
_________________
www.qrz.com/wd8cyv
Back to top
herbalist
PostPosted: Thu Jul 06, 2006 5:38 am    Post subject: Re: speed Reply with quote
Thanks for the info. Smile
This is my first motor cycle, I went straight from cycles and mountain bikes to my beautiful SM125.
My bike will just about hit 60mph if I rev the shit out of it through all the gears but sometimes just seems to cut out at the highest rev's, literally like the throtle is switched off .... it could be the way I am riding it im not sure.
I was instructed by the guy at the bike shop to really rev it through the gears to get the most out of the bike.
You are totally right about the engine being tight, I have done almost 3000 miles and it does feel quicker, and the sound from the engine and exhust is different also, more throaty. less tinny.
How do I find out what my gearing is? and what would be the best gearing setup for my bike, bearing in mind I only use it to commute through London.
I am a novice here but I understand the principles, a rear gear with fewer teeth would give more top speed but less power in the lower gears, right?
I also heard someone mention that the stock exhust could be restricting the power of my bike, do you know anything about this?
Back to top
Jimbo M
PostPosted: Thu Jul 06, 2006 7:56 am    Post subject: Reply with quote
My first time there. I've also got a SM125 all standard (fantastic first bike, 95mpg) nearly 4000km on clock, just starting to get bit more speed out of it!! Max speed seems to be in 5th.
Does anyone find the choke a little temperamental?
Top tip: I use 'Plexus' on the plastics it's the best thing ever!!!
Back to top
PostPosted: Thu Jul 06, 2006 12:12 pm    Post subject: Reply with quote
first the engine is tight when new 4000 plus miles before it will rev free
mine has a tachometer and 10,500 is red line on it
at rpm below 6000 it is sort of like a nice moped above 6000 it runs like a motorcycle should...
i get 60 to 70 mpg per us gallon... english gallon is 1 and 1/8 us gallons
stock gearing on a sm is 16 tooth front 49 rear i find mine runs better
with a 52 on the rear it is the stock sprocket for the sx
the sprockets are an odd size center hole ESJOT of germany is the only company listing them i think the front is same as a yamaha ya6 from 1966 but can not cunfirm that
phil at BSA in the UK may be able to get a better selection of sprockets than i can here in the USA
if yours has alloy wheels i can send info on how to adapt a sprocket
to it
the 52 tooth runs much better but knocks gas mileage a bit
the speed limits where i live are 55mph and lower except 2 roads which i do not need to use very often
i have been doing some experments with the air filter and every thing i do seems to lower the power and make bike slower so for now i recomend the stock filter
and donot store any thing in the space under the seat close to the air intake as it interfers with air flow to the air box
if you can find a tach for the sm get one if you can afford it
this motor wakes up at 7000rpm and pulls well to over 10.000
the choke is hard to work because of the control on the handle bar
same thing as my saxon tour and it is not to user friendly
start bike with choke on and ride away do not set and idle ....you should have it off after going about 1/4 mile
keep battery in good shape mine blew out the voltage reg because the original battery was junk from setting on dealers floor to long
ar dave
_________________
www.qrz.com/wd8cyv
Back to top
Display posts from previous:
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: 125 cc All times are GMT - 5 Hours
Page 1 of 1
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
