MZ Riders
Engine trouble 660
Author Message
Fredrik
PostPosted: Fri Sep 29, 2006 4:02 pm    Post subject: Engine trouble 660 Reply with quote
My first try in this forum! I have a Mastiff 660, 1998 model with engine trouble. Was on a trip yesterday and had been driving for 4-5 hours, and stopped for 1/2-hour. When going off again the battery was flat. Just before I stopped a recognized that the RPM indicator just worked between 0-1800 rpm. When over 1800 it dropped dead to 0 but the engine was still running perfect. OK, flat battery. Managed to start it by pushing, running good. Hit the road and after one minute it just did work extremly bad over 1800 rpm. Idle at 1400 rpm = perfect. Checked the battery = bad things, 5Volt. Put in a new battery, checked charging, 14 volts = OK? Still running bad over 1800 rpm but sometimes it's possible to cheat it and get it work fine for 5-10 seconds. A friend stated that the CDI-box have three ranges : low, medium and high and it can work fine in low and high range. True ?
Could the low voltage on the battery result in a too high charging voltage that have damaged the CDI-box the way my friend stated? Maybe something else is damaged ?
I would really appriciate help on this!
Back to top
phlat65
PostPosted: Fri Sep 29, 2006 8:51 pm    Post subject: Reply with quote
yes the cdi could have been damaged. most common problem we have seen is corrosion in connectors, esp ones that carry current like charging system. if you have a DVOM, check for excessive AC voltage at the battery.
I would disconnect every connector you can get to, and clean and apply some waterproofer, or contact grease. removal of the fuel tank will make it much easier.
good luck!!
_________________
2001 MZ Black Panther
Back to top
Wonky
PostPosted: Mon Oct 02, 2006 3:56 am    Post subject: Reply with quote
Yes the CDI box can be damaged if run with a faulty battery! Also as just suggested above, use contact cleaner on your terminals if they look dark in colour, or rusty. You may have a problem in your wiring loom thats causing your problem, do you have a friend with a Mastiff/Baghira? Try using their CDI box and see if that cures it, if not then check relays,etc on loom. Or talk to David T, hes a bit of a wizz with the old electrics!!!!
Back to top
PostPosted: Mon Oct 02, 2006 11:35 am    Post subject: diode Reply with quote
there are diodes in the wire looms of the mz bikes that i have not seen in other makes these are to control spikes in the voltage from relays and the spark coil they can cause funny readings if you do not know there there
when checking with a voltmeter
several riders have said they have found some blown out.. one is under the gastank in the loom if blown or shorted they can cause funny things to happen Sad
electrical drawing are avabile i can forward them if needed
these bikes are bad about corrison in the connector plugs
and DO keep a close inspection of the battery condition as it is the sorce
of many problems due to its small size
_________________
www.qrz.com/wd8cyv
Back to top
Wonky
PostPosted: Mon Oct 02, 2006 1:18 pm    Post subject: Reply with quote
Wiring diagram here:
http://www.teamslipstream.co.uk/mzbaghirawiringdiagram.html
Back to top
Chris Hunsicker
PostPosted: Thu Oct 12, 2006 1:57 pm    Post subject: Reply with quote
This from a previous post:
Quote:
I wanted to repost the link to a terrific Skorpion resource--a wiring diagram from Tony Idle of the UK who originally posted it on the Yahoo group MZOG.
If you find Yahoo as much of a pain as I do, you can find Tony's diagram on
www.mzskorpion.de
Click on "racing/tuning," and then the 3rd item down is the one to click on: "Schaltpläne als ZIP (0,8 MB)"
Also, if the Baggy is like the Skorpion, a faulty tachometer can make the bike run poorly. Unplug the tach, and see if the problem goes away. I *think* the CDI boxes only rarely fail.
Chris Hunsicker, Philadelphia
Back to top
View user's profile Send private message Visit poster's website
Nils D
PostPosted: Mon Aug 06, 2007 4:13 pm    Post subject: Reply with quote
Chris, could you (or somebody else) tell more about what a faulty tachometer could cause.
My tachometer behaves normal at low speed and low revs. And it is quiet steady at 110 km/h, even if it then says the engine is running at 4500 revs, seams to low. But if I then slow down to 90 km/h, the needle bounces between 2500 and 6000 revs.
Recently my battery has started to dry very quickly, as if it is being charged to much. I have to ad more destilled water every 400 km.
What could cause this? A faulty tachometer? Or what?
Best regards,
Nils
_________________
Skorpion Traveller
Back to top
PostPosted: Tue Aug 07, 2007 12:37 am    Post subject: relay 19 Reply with quote
relay 19 (cutout relay) part of side stand interlock wireing and supplys cdi box with power....
look close at this relay it is to small and it failed the other day on my rt125
i have been having funny tach readings most of the summer....
from time to time bike would not start with kick stand down..
then last Thursday it just died
i jumped pin 3 to pin 5 and rode it home
replaced relay and no trouble for 6 days now
ar dave
ps on my rt125 it is mounted beside the battery and it is gray in color
the contacts carry a lot of current and supply's the cdi box on my rt125
so funny tach reading from funny voltage supply to cdi box ????
cdi box drives tach on most bikes
SEE ALSO HERE FOR REPLACEMENT RELAY DRAWING
http://www.mzriders.com/mz/viewtopic.php?p=12180#12180
 Description:
 Filesize:  47.71 KB
 Viewed:  3904 Time(s)
_________________
www.qrz.com/wd8cyv
Back to top
Chris Hunsicker
PostPosted: Tue Aug 14, 2007 10:31 am    Post subject: Reply with quote
Best regards,
Nils
Nils, I'm afraid I can't give you a definitive answer.
Somehow a faulty tach can cause the engine to missfire. Does your engine perform poorly when your tach starts to be erratic? If so, just unplug the connector at the back of the tach, and see if you still notice the problem.
You may have a faulty tach or have a separate issue that is causing your engine to misbehave.
These tachs are notoriously bad. There has been a lot of discussion on the MZSkporpion.de board about them in years past. Some people replace the whole instrument cluster with something aftermarket, but apparently one can still get the tach from MZ.
That said, I'm not so sure the tachs are terribly accurate, even when they are working correctly.
Hope this helps and good luck.
-Chris, Philadelphiariders.com
Back to top
PostPosted: Wed Aug 15, 2007 12:44 am    Post subject: Reply with quote
Yes the MBB tachs are worse than bad and even even working after a fashion, the values shown are from a different planet. Rest assured that the Denso CDI cuts the engine at precisely 7200rpm, regardless of what you see - or don't as the case may be.
As far as ill effects are concerned, it is really quite simple; the tach gets its signal directly from the coil, so if the circuitboard of the tach goes bad it can short out the ignition circuit and bingo - misfiring or totally dead.
_________________
Bill,
http://www.william-jurgenson.com
http://www.zabernet.de/bill/tuning.html
http://www.appel-tooling.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address
Chris Hunsicker
PostPosted: Thu Aug 16, 2007 8:06 am    Post subject: Reply with quote
For the record, here's the MFG's web site:
http://www.nova-mmb.com/
Back to top
Nils D
PostPosted: Fri Aug 17, 2007 10:46 am    Post subject: Reply with quote
Hmmm....
The tachometer has been strange for over a year. (It started with a electric black-out. It turned out to be the horn that had shortcuted. Just to get home, I got help to jumper. But during that 200km journey, the tachometer was far over the scale, just going down a bit if i used the indicators. Since then there has always been something strange with my traveller.)
The engine runs OK, apart from some missfireing at low speed. It has become worse this summer. I can sometimes provoke short, but total, loss of current by fidling around with the ignition-lock or its loom. I have opend and cleaned the ignition-switch, but the problem remains.
I realize this will cost. Time and money.
I have started to work me throug the conectors.
I have bought a new battery. (Had to be done soner or later.)
The tachometer is so expensive I might just unplugg it.
Since the ignition-lock is bad I have ordered a lock-kit wich also contains a fresch switch.
The screws holding the ignition-lock, do you think they can be drilled out? Or are they made of hardend steel?
Still serching, Nils
_________________
Skorpion Traveller
Back to top
hb7
PostPosted: Fri Aug 17, 2007 10:47 pm    Post subject: Reply with quote
They are one way hardened screws...and yes they can be drilled if you use very high quality drills, then tap in your easy out.
You have to remove the top triple to do it. The switch at the bottom is replaceable without having to change the lock.
ps: I used a drill press and recommend you do too.
The tach is repairable...open it up and resoldering the board worked for me.
Back to top
Nils D
PostPosted: Mon Sep 24, 2007 6:01 pm    Post subject: Reply with quote
Thank you for giving me the curage to "break" open the tachometer. I had no idea what I could meet inside, but it was quiet obvious what had to be resoldered. (Yes, you can't take on and of the glass of the tachometer more than just a few times.) I can't tell how accurate my tachometer is, but it doesn't suffer from hysteria any longer.
For the moment I think everything om my Skorpion Traveller works perfectly. (Touch wood!)
And a word of wisdom from an amateure like me: If you have electrical problems, that doesn't blew the fuses, look at the conectors right after the battery.
Nils
_________________
Skorpion Traveller
Back to top
hb7
PostPosted: Tue Sep 25, 2007 1:05 am    Post subject: Reply with quote
Good to hear it worked for you. Once the the tach bezel is gone....You can seal with silicone and tape it up.....or use a hose clamp to hold the glass/o ring in place.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
