MZ Riders
Poor starting
Author Message
kendo
PostPosted: Sat Sep 15, 2007 1:50 am    Post subject: Poor starting Reply with quote
Hi guys,
My 02 Baghira is a nightmare to start after no more than a 2 week break (if the bike is started every other day there is not a problem). It will always start if i change the plug-- why is this??
The bike has covered 13k and is kept in a garage and connected to an Oxford trickle charger, this problem is becoming a right pain in the a**s as it takes an age to move the cars get my gear on only to find the bike doesn`t want to play.
Kenny.
Back to top
hb7
PostPosted: Sat Sep 15, 2007 1:18 pm    Post subject: Reply with quote
Try using some gas stabilizer....and cracking the throttle
a little. Gas goes stale....faster today.
Back to top
jimc
PostPosted: Sat Sep 15, 2007 5:41 pm    Post subject: Staleness Reply with quote
Mine starts hard after sitting awhile too.
If I anticipate not using the bike regularly - even for a week or so,
I've found that if i shut off the fuel about 1/2 block before I get home ( using most of the gas in the float bowl) or letting it run out before shutting down, it starts more easily , since this allows fresh gas when you open up the petcock . I have an older 550XT - same carb etc. that acts the same way.
You could alternatively use the drain screw to drain the float bowl before an extended down time - or over winter to get the same benefit.
Good Luck.
_________________
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
Back to top
PostPosted: Sun Sep 16, 2007 9:13 am    Post subject: hard start Reply with quote
my rt125 does the same... seem like the carb looses its prime
on mine i have to crank it a long time to get it to go...
warning opening the throttle any on mine
and it will never start that =no vacuum to prime the empty parts of the carb.
but do not have to do it very often as i ride it almost every day
several times i have had to take a hose and place it past the carb slide
and inject fresh gas into the intake in front of carb once engine ran on that gas
the carb seemed to get its prime back....
ar dave
_________________
www.qrz.com/wd8cyv
Back to top
kendo
PostPosted: Sun Sep 16, 2007 10:16 am    Post subject: Poor starting Reply with quote
Hi ,
When i arrived home from work yesterday the bike fired up no problem at all so i am thinking that if the bike does not fire up straight away the plug gets fouled with fuel and will not start until the fuel evaporates, with this in mind i am going to fit an aftermarket performance coil to give the engine the best possible chance of firing first time and stopping the plug getting fouled and me having to take the car to work. If anyone has done this can you post the make and specification.
Many thanks -- Kendo.
Back to top
PostPosted: Sun Sep 16, 2007 2:06 pm    Post subject: Reply with quote
it i not sp mucu that as that the volatile parts of the gasoline evaporate in the float chamber and what is left is very hard to ignite.
b
_________________
Bill,
http://www.william-jurgenson.com
http://www.zabernet.de/bill/tuning.html
http://www.appel-tooling.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address
omrra91
PostPosted: Sun Sep 16, 2007 6:38 pm    Post subject: Questions re: start up problem Reply with quote
I'm glad to see that Bill has responded to the thread because he probably knows the answer to my first question.
(1) Is there any difference from the Skorp and the Baggy in terms of the all the related parts?
(2) Does the bike still have a fuel pump?
Took mine off the other day. Had the bike since new and it's never started easier. I've run all the race bikes without fue pump for years.
(3) Have you drained the float bowl. A bit of water in the tank is going to head to the bottom of the tank and then........to the bottom of the carb. That can mess up starting and running. And, it can really fool you if it is only a little bit of water. Can't hurt to check.
Regards, Jeffrey
Back to top
kman.45
PostPosted: Tue Sep 18, 2007 12:30 pm    Post subject: Reply with quote
I would agree with most everybody that you should be turning your petcock off. Perhaps your float valve is leaking a tiny bit, hence the fouled plug. Sitting a day or two maybe not so much fuel leakage, sitting a couple weeks might mean too much liquid fuel down the carb, and we all know liquid fuel doesn't burn.. I'd run a couple bottles of Techron through my fuel system or go for the carb pull and clean.
Back to top
PostPosted: Thu Sep 20, 2007 12:28 am    Post subject: Reply with quote
If the float needle valve is not right, fix it. Turning off the petcock is not a fix for that. I don't even have a Petcock, long since replaced by a quick release fitting as on most of the machines I have modified. If and when I really do think "shutting off" the fuel is necessary, I just release the quick release. No connection at all the best possible shut off. The right side petcock for instance of my BSA leaks a little bit when closed, but the new AMAL carb needle valve works great.
When the Needle valve does stick open, the float chamber overflow tube dumps the fuel on the ground, not down the intake. That is what the overflow is for. This is not a Dellorto or AMAL from 1960.
b
_________________
Bill,
Back to top
phlat65
PostPosted: Sat Sep 22, 2007 10:31 am    Post subject: Reply with quote
there have been a few Baggys that have filled the crankcase with fuel with leaking petcocks. I know the overflow dumps overboard, but it seems with the bike on the sidesand, the chance of the fuel making it into the engine is greatly increased.
Try putting a block under the stand so the bike stands more upright.
_________________
2001 MZ Black Panther
Back to top
hb7
PostPosted: Sat Sep 22, 2007 12:59 pm    Post subject: Reply with quote
I would replace the leaking needle valve in the carb....and cure the problem. I have had 2 of the carbs and no leaking problems on either my Mastiff or Skorp. It's not complicated,
and can be replaced on the bike if you remove the starter.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
