MZ Riders
Malaysian - MZ 125SM
Goto page 1, 2, 3 ... 28, 29, 30  Next
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: 125 cc
Author Message
biolator
PostPosted: Fri Feb 18, 2005 2:52 am    Post subject: Malaysian - MZ 125SM Reply with quote
Any malaysia user here?
need some information where the best place to get cheap spare part and accesories for this bike...
_________________
-zaki-
Back to top
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
jbthumper
PostPosted: Mon Feb 21, 2005 12:32 pm    Post subject: Reply with quote
In Kl u could try jln sentul(NKS) or Jln Ipoh(gentali).
But the variety would be in singapore.
Back to top
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
biolator
PostPosted: Tue Feb 22, 2005 12:26 am    Post subject: problem... Reply with quote
any usual problem on this bike? i'm having some problem the engine always turn off, even the engine is warm up....
_________________
-zaki-
Back to top
PostPosted: Tue Feb 22, 2005 1:15 pm    Post subject: problems Reply with quote
hi
check for dirt in gas
check kick stand safety switch
check right hand handle bar kill switch
check choke to make sure it is turned off when engine is warm
check fuses under seat may have one going bad
ar dave
_________________
www.qrz.com/wd8cyv
Back to top
biolator
PostPosted: Tue Feb 22, 2005 10:49 pm    Post subject: Reply with quote
kick stand safety switch? i dont get it...
_________________
-zaki-
Back to top
ptong
PostPosted: Tue Feb 22, 2005 10:57 pm    Post subject: bike stoppage Reply with quote
I had a similar problem and it truned out to be the choke sticking on. The plunger in the carburetor was actually rusty (almost brand new). I fixed it by taking off the tank and then manually pulling the cable whilst using a little wd 40 to loosen it up. I ended up loosening it and then with a bit of lubrication i shoulodnt have any issues.
Hope that helps.
_________________
ptong
Back to top
PostPosted: Tue Feb 22, 2005 11:01 pm    Post subject: Reply with quote
on my rt125 it you put the bike in gear with the side stand down
the engine will die your's may or may not have it
look for electrical wires near the piviot point of side stand
it is required saftey device here in usa
so if you put bike in gear with stand down engime dies
if it is bad it can kill engine
ar dave
_________________
www.qrz.com/wd8cyv
Back to top
biolator
PostPosted: Wed Feb 23, 2005 3:33 am    Post subject: fan Reply with quote
one more question...
i need to know, how's the fan for the radiator work? it is always work when the bikes running... or it only on when the tempreature goes up. How to confirm the fan is working or not?
_________________
-zaki-
Back to top
micheleen
PostPosted: Wed Feb 23, 2005 6:07 am    Post subject: Reply with quote
The fan only runs when the coolant is approx 100 deg Celcius or hotter.
To test the fan you can run leads directly to it and check it rotates, the terminal connected to the black and yellow wire is +ve.
To test the thermal switch you need to remove it and heat it, checking the contacts close with a meter.This does entail draining the coolant first though Rolling Eyes .
Cheers, Mike
Back to top
biolator
PostPosted: Wed Feb 23, 2005 11:20 pm    Post subject: Reply with quote
what do you mean the thermal switch? you mean the red LED indicator on the meter?
How frequent i should change the water coolant?
regards..
_________________
-zaki-
Back to top
micheleen
PostPosted: Thu Feb 24, 2005 4:52 am    Post subject: Reply with quote
The thermal switch is mounted into the back of the engine on the left hand side, it is what actually turns on the fan and the red temp warning light.
The manual recommends changing coolant every 2 years.
Cheers, Mike
Back to top
biolator
PostPosted: Fri Feb 25, 2005 1:10 am    Post subject: Reply with quote
Anyone,
Got a list for each spare part that i should keep spare which is frequently need to be change and fix?
_________________
-zaki-
Back to top
biolator
PostPosted: Fri Mar 04, 2005 2:08 am    Post subject: coolant Reply with quote
any one here got some idea / howto , to change the coolant?
_________________
-zaki-
Back to top
micheleen
PostPosted: Fri Mar 04, 2005 2:23 am    Post subject: Reply with quote
I just disconnected the bottom hose between the engine and the radiator, and drained into an old bowl. I used a new retaining clip when I reconnected the hose and then refilled with a 50/50 mix of antifreeze and water (the antifreeze must be suitable for aluminium engines)
Cheers, Mike
[edit] I think it took about a litre of liquid to refill
Back to top
PostPosted: Fri Mar 04, 2005 11:16 am    Post subject: Reply with quote
in the above post
retaining clip
equals
hose clamp in usa english
english is a wonderful langague 25 different names for the same thing
and 50 different spellings for each name
_________________
www.qrz.com/wd8cyv
Back to top
Display posts from previous:
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: 125 cc All times are GMT - 5 Hours
Page 1 of 30
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
