cat
Joined: 30 Nov 2005 Posts: 398 Location: South Africa
Posted: Wed Apr 12, 2006 1:08 pm Post subject: |
irishnutjars,
Thanks for the pictures. They help. I need to measure the gap between the 2 stock manifolds, now that they're in position without the collector (in a good position, clearing the master cylinder and as far away as possib;e from the coolant hoses as possible - draw around them - compare that to the diagram of the collector end - and figure out what to get what Burns Stainless. The picture of the Burns Stainless Y-pipe I posted in the other thread ..what length of output I need on that, or if must be short and have a bend welded on to clear the master cylinder, and then get some idea of the bend I need to get to the bottom of the can. I want to get as close as I can to 'plug-and-play' then get my friend to weld - cut and weld. and the can will have to get an outlet tube welded on to extend it and direct it away from the bike. I'm trying to think of something I can model it with (the connector pipe), but all I can think of is the vacuum cleaner pipe, or a ton of plasticene, a plasticene sausage. |
