Author |
Message |
Garf
Joined: 06 Jul 2005 Posts: 92 Location: Manchester, UK.
Posted: Mon Oct 17, 2005 3:26 am Post subject: Engine swap |
Just curious, but has anybody out there ever heard of or indeed fitted a TRX / TDM twin into an MZ Baggy chassis ? _________________ HR Black Panther |
Back to top |
F0ul_Oli
Joined: 01 Mar 2005 Posts: 103 Location: Deeside,North Wales,UK
Posted: Mon Oct 17, 2005 6:57 am Post subject: |
I've not heard or seen of one, but using armchair engineering, it should be possible - but very difficult!!
As far as I understand, the mounting points on all the Yamaha engines are in the same place, however, there is the point that the TDM has its oil inside the engine, whereas the Baggy has an oil framed engine.
Would be interested to know an answer!
F0ul _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
http://www.businessandit.co.uk - putting the IT in Profit! |
Back to top |
RichBeBe
Joined: 09 May 2004 Posts: 74 Location: New York City
Posted: Fri Oct 28, 2005 9:35 pm Post subject: |
I own both a mastiff and a TDM850 and I see very little reason to do the swap. But that said I can tell you that the engine mounting points are very different and i highly doubt the TDM engione would fit in without opening up the cradle a bunch.
The TDM is also a dry-sump engine so that is not a problem as well. |
Back to top |
