Author |
Message |
sean18
Posted: Fri Oct 21, 2005 1:58 am Post subject: rear wheel |
hello all a silly question how do you remove the back wheel of a sm 125. i tryed for about 1 hour and its still on. ive removed the axel nut on one side but the axel will not come out ive tapped it no still there i hit it a bit harder its still there i hit it very hard and its still there .is there any thing iam missing
sean |
Back to top |
jbthumper
Posted: Fri Oct 21, 2005 3:35 am Post subject: |
hi sean, was the wheel straight(i mean align) when you hit the axle...?
lift the wheel a bit while you're hitting it(the axle..haha)...
i don't think you did anything wrong....
last time when i took mine out, i just gave the axle a few taps and the thing moved...
maybe you can try spraying some wd40 on the axle(or anything that's touching it)
hope this helps... _________________
Back to top |
sean18
Posted: Fri Oct 21, 2005 2:21 pm Post subject: |
all done i just used a bigger hammer ...the axel was seazed but it out now thanks
sean |
Back to top |
jbthumper
Posted: Fri Oct 21, 2005 4:27 pm Post subject: |
no problem... intimidating the bike with a bigger hammer usually helps in most cases _________________
Back to top |
phlat65 Moderator
Posted: Fri Oct 21, 2005 10:53 pm Post subject: |
always grease the entire axle upon re-assembly, prevents seizing again! _________________ 2001 MZ Black Panther
Back to top |
