Author |
Message |
misirli
Posted: Fri Dec 02, 2005 11:46 am Post subject: caburater |
hi,
I am from turkey. I have 2002 MZ rt-125. I have just bough and I love it. but its carburater is not good. it does not work stable. I asked for a new carburater but is costs more than 200 euro or 250 USD since there is no dealer in turkey I have to buy it from somewhere in europe. but I wonder if there is any possibility that any other bikes carburater may fit to my MZ.
does anybody know about this issue.
I would appreciate any help much.
thanx
aydin.... |
Back to top |
Scheffi
Posted: Fri Dec 02, 2005 1:22 pm Post subject: |
Hi!
Why do you want to buy a new carburettor? Probably it is just an adjustment problem. Go and look for a good mechanic and have the carburettor adjusted correctly.
Scheffi _________________ Baghira Enduro, MZ ETZ 250 with sidecar
http://www.sachsen-tourismus.de/
http://www.germany-tourism.de/ |
Back to top |
Posted: Fri Dec 02, 2005 7:39 pm Post subject: carb link |
carb link
hello
clean the carb
the choke or enrichment device on the front right side of carb sticks some times .....
set the fuel air mixture screw to 2 turns from seated botton middle of rear of carb best to do this off the bike it is easer to do
these bikes use very little fuel so dirty gas is some thing they dont like
view and read the post below also
http://www.mzriders.com/viewtopic.php?t=918
ar dave
ps cold weather starting don't turn throttle on use choke /enrichment lever
let run 1 min.. then ride away turning of choke as soon as it will run properley dont let it set and idle to warm up
need more info pm me _________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv |
Back to top |
misirli
Posted: Sun Dec 04, 2005 9:10 am Post subject: thanks a lot |
scheffi and david,
thanx a lot for the suggestions. I am not good at mechanical works. and this is my first bike. I think I better start to learn to do it myself. because I bought this bike 2 months ago and left it to a mechanic for overall check and other stuff. the very first day after I picekd it up it started to leak gas from the carb and, as a smoker, I was in big danger.
I found somewhere a repair book for rt 125 I will start to read it...
bye
aydin |
Back to top |
Posted: Sun Dec 04, 2005 10:26 am Post subject: CARB |
Hello
glad to help
the 125cc MZ Bikes are very strong and run very well i will
keep my rt125 till i can not make it run any more
so if you have a broblem ask questions
plan ahead on the chain sprockets i have found that here in my location
only the mz oem parts will fit so i will send you part numbers
for a list of spairs that i have used in the first 12,000 miles
is yours a rt125 or one of the other bikes
ar dave _________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
Back to top |
Drew
Joined: 17 Jul 2005 Posts: 84 Location: SF Bay Area (East Bay)
Posted: Sun Dec 04, 2005 5:05 pm Post subject: |
I had my carb leak gas too. Turns out there was a problem with the needle valve; the previous owner had worked on the carb, and inadvertently bent a tab of some sorts when reassembling the carb.
Also, check your fuel supply via the fuel filter. I found my petcock was mis-labeled; OFF and RES stampings were swapped.
It's a fun little bike, and the motor will become peppier as it is run in. Have fun with it! _________________ Relax. You'll live longer. |
Back to top |
Drew
Posted: Sun Dec 04, 2005 5:15 pm Post subject: |
Also, the carb is a Mikuni VM24 24mm; somewhat rare. Mikuni do make a 26mm and a 28mm that will supposedly fit, but you'll still be responsible for sourcing the rubber boot and any other pertinent parts. Plus you'll still need to rejet it anyways. And after all that, it may run worse at normal street speeds (low revs). That's a lot of money to throw at it; unless you plan on racing, I'd say to stick with the 24mm.
For any carb parts, www.sudco.com is the place to go. They have plenty of cool diagrams, manuals, and parts lists.
PDF of VM carbs, part numbers, diagrams
DAVID THOMPSON's suggestion of taking it to a mechanic to clean or rejet is the best bet. _________________ Relax. You'll live longer. |
Back to top |
misirli
Posted: Mon Dec 05, 2005 2:45 am Post subject: |
drew: thanks a lot for the suggestions . you are right. because leakage problem was last week and I decided to go to a mechanic but I did not have time so I run the bikealthough it was not stable at the beginning. then somewhat strangely it has started to become more stable. thanx god. I will check the web site and try to solve my problem on my own.
david: thank you too for your interest as well. by the way I saw you rt's picture and mine is the same. just yellow one. I am the 3rd owner. (as I know ) and previous ones did not behave the bike well I believe. but I love it. especially its sound. it sounds like a ducati monster.
I will try to attach a picture to this messasge. I hope I can...
aydin, |
Back to top |
