Author |
Message |
muzyjoe
Posted: Mon Nov 21, 2005 2:49 pm Post subject: hot exhaust at head. |
hello everybody i hope you can help me my 2002 traveler is getting very hot at the top of the exhaust pipe( just as it exits the head) i think it might something to do with the ignition but there is no adjustment .is it a cdi, problem? its also using a lot off oil. help! _________________ how the hell are you? |
Back to top |
Posted: Mon Nov 21, 2005 3:53 pm Post subject: |
You are right the ignition cannot be adjusted. Therefore I would check the carbs are set up right. If it is running weak then the engine would overheat. Also this overheating may be the cause of you high fuel consumption.
Keith _________________ Ride it like you stole it |
Back to top |
muzyjoe
Posted: Tue Nov 22, 2005 1:28 pm Post subject: |
hi Keith, thanks for the advice but it is burning oil and not hard on fuel there is not much i can do with the carb settings other than try a differnt size neddle but it is as it came from the factory , any ideas? _________________ how the hell are you? |
Back to top |
F0ul_Oli
Joined: 01 Mar 2005 Posts: 103 Location: Deeside,North Wales,UK
Posted: Tue Nov 22, 2005 6:30 pm Post subject: |
Working on theory, rather than a strong knowledge of your paticular model of bike, I would try a few things. Firstly, how much oil is it burning - can you see a blue coming out of the exhaust or is it just using more oil than you were expecting?
Have you checked the condition of the plug? Is it a nice brown or a horrible white, or a soggy black?
White is a lean mixture, black is too much fuel.
Is the exhaust glowing from the heat (look at it in pitch black) or is it just a bit warm (they all do that, its the hottest part of the exhaust!)?
Hows the performance - is it pinking under a heavy load (another sign that it could be the ignition)
Hope this tests help you find what the problem could be.
F0ul Oli _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
http://www.businessandit.co.uk - putting the IT in Profit! |
Back to top |
muzyjoe
Posted: Tue Nov 22, 2005 6:42 pm Post subject: |
thanks for the tips oliy, its used about 2 ltrs in the last 6 months there is no visable smoke on start up, and it glows bright red at start up could it be cdi unit? i will check the plug tomorrow. thanks mate! _________________ how the hell are you? |
Back to top |
whysub01
Posted: Wed Nov 23, 2005 8:02 am Post subject: |
A strange one. I would hazard a guess that either the fueling or ignition is out
I
How long (mileage wise) has it been getting hot?? I would agree that you check the plug, and also drain the carbs, and put plenty of carb cleaner through them (could be a simple blockage) to see if that cures it-quicker than a full carb strip.
Also finsd a nice friendly Yamaha dealer (I believe such a thing exists somewhere in the world) and see if they can let you borrow a TDM cdi box. These do let the bike rev a bit more, but iof yours is faulty, then the swap will confirm it. CDi's on ebay go for anything between £25-£50 which ois a huge saving on the MZ/Yamaha price for a new one.
Incidentally, my 30,000 mile Sport has consumed around 750ml of oil in between changes in 6,000 miles, and boy, does that get ragged everywhere! _________________ Becoming A Track Day Addict. Baggi Well On The Way To Completion. Well, One DAy Closer................ |
Back to top |
