MZ Riders
Baghira handlebar width ?
Author Message
cat
PostPosted: Sun Dec 11, 2005 3:09 pm    Post subject: Baghira handlebar width ? Reply with quote
Someone please get me the width of the stock handlebars...? Smile
I want to get TAG bars (I think the TAG rubber mount clamps that I used on my KDX will fit the Baghira), but I need to be sure that the cables and the brake line will be long enough.
Now I'll find that thread where phlat put Pro Tapers on and see if he mentioned the width / the bend. Wink
 Description:
Available for KX/KXF/RMZ, RM, CR/CRF.
 Filesize:  6.94 KB
 Viewed:  892 Time(s)
Back to top
phlat65
PostPosted: Sun Dec 11, 2005 8:49 pm    Post subject: Reply with quote
I just used a standard CR high bend. there are no issues with cables and electrical not being long enough..
_________________
2001 MZ Black Panther
Back to top
cat
PostPosted: Mon Dec 12, 2005 1:35 am    Post subject: Reply with quote
Oh, good. The TAG CR Double Hi's are what I used on the KDX but here the height isn't necessary. .....ok, the TAG Cr Hi's are 10mm narrower than the Double Hi's - good. Thanks. ....ah...Pro Taper CR High is wider than the TAG ones and you had no problems. Good! Smile
width height pullback
Pro Taper CR Hi 813 62 95
TAG T2   CR Hi 795 62 95
TAG T2   CR Dbl Hi 805 62 115
TAG T2   YZ 803 57 92
Back to top
Dezmo
PostPosted: Mon Dec 19, 2005 5:20 pm    Post subject: Reply with quote
I have tag T2 SX hi bend, iirc they were only a few mm narrower than stock bars, the other bends were much narrower.
_________________
Hella Yella, coming ta getcha!
Back to top
View user's profile Send private message Visit poster's website
cat
PostPosted: Tue Dec 20, 2005 1:58 am    Post subject: Reply with quote
The stock bars must be quite wide - I must remember to measure mine - I need to check out the mounts, anyway.
I've got this spreadsheet with all the specs/bends (TAG, Pro Taper, Renthal, Magura) that I put together when I was selecting bars for my R100GS. (I needed high ones.)
hey, I also got a yella one!
Back to top
F0ul_Oli
PostPosted: Tue Dec 20, 2005 1:21 pm    Post subject: Reply with quote
I measured mine when I went looking for some higher ones - the standard is 830 mm - the same as a set of Renthal Dakar ones!
My bars are now a good two inches taller - makes a world of difference!
Smile
F0ul
_________________
Back to top
whysub01
PostPosted: Sun Dec 25, 2005 4:53 am    Post subject: Reply with quote
Smile
F0ul
Any problems with cables and switchgear? Don't like the bars on mine-I think they look and feel cheap (one of the only componants on the bike that does).
_________________
Back to top
cat
PostPosted: Tue Dec 27, 2005 2:59 am    Post subject: Reply with quote
Smile
F0ul
If the stock bars are 830mm [!] you won't have any problems with cables - because any bars you buy are not going to be as wide. Pro Taper, Renthal, TAG ... they range from 775mm for the 'woods' bars to 808...813, and the widest are the KTM bends 818 and 820.
hmh! I didn't notice that the bars were so wide - they felt fine.
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
