Author |
Message |
kerry
Joined: 12 Jun 2004 Posts: 28 Location: frankfort, NY
Back to top |
cat
Joined: 30 Nov 2005 Posts: 398 Location: South Africa
Back to top |
cat
Posted: Tue Apr 04, 2006 4:57 pm Post subject: Identifying Keihin and Mikuni jets |
Identifying Keihin and Mikuni jets - see the 2 attached .mht files. Useful pictures and dimensions and descriptions.
According to information posted here by oldboyonrgv, Keihin main jets fit the primary carb - I think they're the "small round" type. The Mikuni small round ones have a different thread.
Description: |
Download |
Filename: |
Keihin & Mikuni jets (rageperformance.com).zip |
Filesize: |
171.6 KB |
Downloaded: |
112 Time(s) |
Description: |
Download |
Filename: |
Keihin & Mikuni jets (Factory Pro).zip |
Filesize: |
102.39 KB |
Downloaded: |
75 Time(s) |
Back to top |
roge-a-billy
Joined: 14 Aug 2005 Posts: 41 Location: edge of madness (west london)
Posted: Thu Apr 13, 2006 8:14 am Post subject: |
Cheepist Dynojet kit (stage 2) ive found is 55.70 at www.busters-accessories.co.uk. Delivery will take time as none in stock and I don't think any will be stored in UK, so that means it will come from USA
_________________ Up to my knees in gin & hookers |
Back to top |
cat
Posted: Thu Apr 13, 2006 9:37 am Post subject: |
roge-a-billy wrote: | Cheepist Dynojet kit (stage 2) ive found is 55.70 at www.busters-accessories.co.uk. Delivery will take time as none in stock and I don't think any will be stored in UK, so that means it will come from USA |
thanks, good one. that's a lot less.
no they don't stock them, the last person that mentioned it said they were making it up in the USA. (the needle, the big secret needle.)
meanwhile, i've just got 3 primary main jets 132.5, 135, 137.5 (non-genuine Keihin). oldboyonrgv said go from 130 to 135; i got the others in case i needed to play.
something else i found... the choke mechanism from the XT600 fits - it's the pull-knob (that sounds wrong) type. i got rid of the cable, it was stiff and ...one cable less, and rigged it up with a cable tie to pull out the choke plunger, but there's nothing to stop water getting in; the genuine brass shaft thing would be better.
Back to top |
dmon722000
Joined: 28 Nov 2005 Posts: 51 Location: Ft. Lauderdale, Miami
Posted: Sat Apr 15, 2006 12:52 am Post subject: about them jets... |
A gentelman by the name of Gayland @ Bikeworx.com is the hook up for all of you carb needs. He is helpful and friendly and his jet kit is less than any of the prices I've seen. Check him out, I used his kit and my Baghira woke up pissed off! it realy worked great.
Back to top |
dmon722000
Back to top |
cat
Posted: Fri Apr 21, 2006 9:05 am Post subject: |
Dwight, did you do the jetting before you did the exhaust or after/when you did it?
Back to top |
dmon722000
Posted: Fri Apr 21, 2006 4:38 pm Post subject: |
I did it after I installed the +1 Piston. When I installed the pipe @ 0 miles (new from the showroom)with a stock motor then I put the bike on the dyno and had a remarkable 58 rwhp. Pipe only, the graph was smooth and flat and had no dips or spikes. I faxed it to Gayland, at "Bikeworx" he said whatever I'm doing is good enough. I had to agree, I'm into riding bikes and this one ran great. So no jet fiddiling (yet). After the piston was installed (35ish thousand miles?) I said WTF and do the jet kit (more displacement and everyone was raving about how much of a difference they made etc...). After getting the jet kit (from Bikeworx, great service, greater advise) I installed it easy enough and then rode the bike and I was pretty amazed. Both the low end torque and trottle response was great, real bad ass street hooligan stuff...But, my driving style was fouling the plugs a bit due to a combination af the secondary carb coming in earlier and the secondary was also jetted. It was getting too much fuel while bliping the throttle (downshifting etc...)So I went back with the original jet for the secondary and only have the primary jetted with the air screw turned 5 1/2 turns from bottom (sealevel, Miami). The bike runs like a pissed of thing with something up its arse! I love it. Well, hope that helps you out.
Dwight
Quote: | "If there were a better bike, I'd be riding it" |
Back to top |
cat
Posted: Sat Apr 22, 2006 4:55 pm Post subject: |
dmon722000 wrote: | I did it after I installed the +1 Piston. When I installed the pipe @ 0 miles (new from the showroom)with a stock motor then I put the bike on the dyno and had a remarkable 58 rwhp. Pipe only, the graph was smooth and flat and had no dips or spikes. I faxed it to Gayland, at "Bikeworx" he said whatever I'm doing is good enough. I had to agree, I'm into riding bikes and this one ran great. So no jet fiddiling (yet). After the piston was installed (35ish thousand miles?) I said WTF and do the jet kit (more displacement and everyone was raving about how much of a difference they made etc...). After getting the jet kit (from Bikeworx, great service, greater advise) I installed it easy enough and then rode the bike and I was pretty amazed. Both the low end torque and trottle response was great, real bad ass street hooligan stuff...But, my driving style was fouling the plugs a bit due to a combination af the secondary carb coming in earlier and the secondary was also jetted. It was getting too much fuel while bliping the throttle (downshifting etc...)So I went back with the original jet for the secondary and only have the primary jetted with the air screw turned 5 1/2 turns from bottom (sealevel, Miami). The bike runs like a pissed of thing with something up its arse! I love it. Well, hope that helps you out.
Dwight
Great, that helps. Now I'm going to..focus even more on your exhaust design. That's convincing. Maybe you should try to market it. Think it through.. what it would cost to get the collectors/connectors made. ...Oh, I was going to ask, what altitude, but I've just notcied that it's Miami - sea level. Good! Me too. That helps. Now I know I don't need to worry about the main jet in the secondary carb. I was just about to buy 3 for drilling. Maybe I'll just get one and make it 'half a size' up / 2.5 increment. But I won't need it until I've got the exhaust done anyway.
Did the jet kit come with a needle? Is it the Dynojet kit?
Back to top |
