MZ Riders
IGNITION LOCK, BIG PROBLEM!!!
Author Message
dan indian park
PostPosted: Mon May 22, 2006 7:42 pm    Post subject: IGNITION LOCK, BIG PROBLEM!!! Reply with quote
HI EVERYBODY.
Does anybody can help me? I bought my new Baghira 660 sm 1 month ago.
I did 1100 km and I just did the first check to the mechanist. He said that everything was perfect. The day after I tray to switch on the bike, but on turning the key on ignition on position nothing happened. The neutral gear lamp did'nt switched on. I try to switch off and on again, but nothing happened. One hour after i tryied again to swith on and the bike run perfect again. What do you think happened to the bike?
Dan Indian Park
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Sourcer
PostPosted: Mon May 22, 2006 7:53 pm    Post subject: Reply with quote
It's hard to tell. Maybe it's a ground problem. Inspect for defective cables, loose connections, corroded cable connectors or battery terminals, cracked cases or covers, loose hold-down clamps and deformed or loose terminal posts.
Back to top
Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
PostPosted: Mon May 22, 2006 11:50 pm    Post subject: electric Reply with quote
double check the fuse and its holder and did the key work freely
and check the plug where the key switch plugs into rest of harness
and just look carefully at the whole wire harness
and under fuel tank as well if he had it off he may have knocked a wireing plug loose
ar dave
_________________
Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Back to top
roge-a-billy
PostPosted: Tue May 23, 2006 3:27 pm    Post subject: Reply with quote
check side stand cut out switch is ok
_________________
Back to top
tuny
PostPosted: Tue May 23, 2006 11:28 pm    Post subject: Reply with quote
hi, i have hade 2 mastiff's and both hade this problem, it whas a relay located behind the left rear plate, next to the cdi box, this relais is one verry special with a internal extra resistor and therfore hard to find, i made a relais with the same resistance myself and it works perfect never hade anny problems after. hope this helps you.
Back to top
View user's profile Send private message Send e-mail MSN Messenger
Display posts from previous:
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
