Author |
Message |
kman.45
Joined: 06 Apr 2006 Posts: 65 Location: Knoxville Tennessee USA
Posted: Sun Jun 11, 2006 1:12 pm Post subject: Water Pump hose |
Does anybody know if the hose that connects the intake of the water pump (points out from the front of the water pump) to the "tee" below the radiators is a Yamaha part? or just an MZ part?
thanks,
kman
Back to top |
Joined: 23 Nov 2003 Posts: 1118 Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
Posted: Sun Jun 11, 2006 8:54 pm Post subject: hose |
what bike model and year
and some of these hoses can be found at auto parts stores
if you have an experanced parts guy look at what your replacing
he may be able to do it from a car heater hose he has in stock
_________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv |
Back to top |
kman.45
Posted: Mon Jun 12, 2006 9:51 am Post subject: |
Sorry, duh, model would have helped. 2003 Baghira. A generic hos is not going to work because it has two (maybe three) right angle bends molded into it. It fits snuggly in between the motor and exhaust pipe too, so it really needs to be the stock replacement. Just wondering if I can order it from the friendly Yammie dealer or have to call BSA Regal.
Back to top |
Posted: Mon Jun 12, 2006 12:23 pm Post subject: fast |
probely faster to just get it from phil
if you call him early tue. morning
you should get it in next monday or tue mail
phone number and fax number is on web site
and do search up above for bsa and info will show up in
a post
or link here
http://www.mzriders.com/viewtopic.php?t=1438
dont forget the time difference 5 to 6 am edt here is just before lunch
there and an early call may get it shipped on tue
Back to top |
Drew
Joined: 17 Jul 2005 Posts: 84 Location: SF Bay Area (East Bay)
Posted: Mon Jun 12, 2006 3:23 pm Post subject: |
For my MZ, I replaced mine using CPE hose. If the bends aren't too crazy, then this is a viable alternative. Note that the 125SM has two right-angle bends...
Description: |
Filesize: |
27.97 KB |
Viewed: |
1668 Time(s) |
_________________ Relax. You'll live longer. |
Back to top |
Drew
Posted: Mon Jun 12, 2006 3:24 pm Post subject: |
This is what I replaced it with (not my bike, but it looks the same)
Description: |
Filesize: |
54.08 KB |
Viewed: |
1666 Time(s) |
Back to top |
Posted: Mon Jun 12, 2006 5:46 pm Post subject: |
Hey that looks a lot better and stronger. The hose looks real vunerable where it is and I can see it getting damaged if the bike is used off road.
Back to top |
Drew
Posted: Tue Jun 13, 2006 1:07 pm Post subject: |
keithcross wrote: | Hey that looks a lot better and stronger. The hose looks real vunerable where it is and I can see it getting damaged if the bike is used off road.
Keith |
Thank you! The stock hose is braided, but the new one is a bit thicker and much nicer. The only drawback is that the connector from the rad is 1/8" larger in diameter than the connector into the engine. It just took a little more "oomph" to get the hose on the rad (not so much that it killed the radiator, though!).
kman.45, also consider checking the KTM parts catalogue. My rads are KTM-made, and it wouldn't surprise me that the Baggy uses rads from them as well. Try sites like KTMcyclehutt.com; I did see some exploded parts diagrams online of KTMs.
Back to top |
kman.45
Posted: Tue Jun 13, 2006 5:03 pm Post subject: |
[quote
kman.45, also consider checking the KTM parts catalogue. My rads are KTM-made, and it wouldn't surprise me that the Baggy uses rads from them as well. Try sites like KTMcyclehutt.com; I did see some exploded parts diagrams online of KTMs.[/quote]
thanks for the tip. I will do that. The hose on my Baghira is nothing like the one you show. As I stated it has to run through the exhaust pipes and fits fairly tight, so seems it has to have those molded corners.
Back to top |
