Author |
Message |
Tonybloke88
Joined: 13 May 2006 Posts: 4 Location: Berkshire, England
Posted: Sun May 28, 2006 4:07 am Post subject: Diode Failure |
Does anyone know where the Diode is physically located in the wiring loom on a Baggy?
Mine has failed leaving me without any side lights! but the park lights work, which suggests that the diode is the cause of the problem. |
Back to top |
Joined: 23 Nov 2003 Posts: 1118 Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
Back to top |
Tonybloke88
Posted: Mon May 29, 2006 3:06 am Post subject: |
I found it!!
If any one else needs to find it then the diode is taped inside the loom. Its marked with a wrap of yellow tape and is half way along the top tube. When you open the loom you will see 4 grey wire comming from the front and one going from the rear all meeting inside a peice of black shrink wrap. The diode is inside the shrink wrap.
Mine had broken in half! so I routed a couple of wires back towards the air box and fitted a more robust item on spade connectors. |
Back to top |
andyw
Joined: 14 Mar 2006 Posts: 89 Location: UK South West
Posted: Tue May 30, 2006 3:31 am Post subject: |
Tonybloke88 wrote: | I found it!!
Thanks for that - details of the item you fitted, where you got it etc would be good
Thanks _________________ 2005 R1200GS - 2002 MZ Mastiff: No more
www.MotorcycleInfo.co.uk |
Back to top |
TrashBagh
Posted: Wed Jun 14, 2006 11:21 pm Post subject: Diode! |
Hey I had to replace two broken diodes in my harness. I was able to replace them with ones I got from radioshack... they only carry one diode which is rated at 3amps. Those are the ones you need |
Back to top |
