MZ Riders
Traveller fuel cock
Goto page 1, 2  Next
Author Message
Nils D
PostPosted: Tue Feb 27, 2007 5:38 pm    Post subject: Traveller fuel cock Reply with quote
Hey there, this is my first entry.
Last april, at last I bought me a Skorpion Traveller.
Somewere on the web I had read that the fuel cock could be a bit tricky to reach. And on my Traveller it was almost impossible to turn unless I used both hands.
I had to buy a new fule cock. But still it was a bit hard to turn, particularily when it was time to turn it to the reserve.
I had to make som kind of lever.
A "hook" glued with Araldite and reinforced with wire.
One finger is enough.
Nils D
 Description:
 Filesize:  54.17 KB
 Viewed:  2783 Time(s)
_________________
Skorpion Traveller
Back to top
hb7
PostPosted: Tue Feb 27, 2007 9:54 pm    Post subject: Reply with quote
I never turn mine off.....no issues.
I need a the cup and the filter for my spare petcock.
Any other MC uses this style of petcock ?
Back to top
PostPosted: Wed Feb 28, 2007 2:42 am    Post subject: Reply with quote
Nils, end me your address, and I'll send you one.
bill
bill@william-jurgenson.com
_________________
Bill,
http://www.william-jurgenson.com
http://www.zabernet.de/bill/tuning.html
http://www.appel-tooling.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address
buckwheat5679
PostPosted: Fri Mar 02, 2007 7:23 pm    Post subject: Reply with quote
I never use to turn mine off either until one time after sitting for 2 months I checked the oil level before a ride and it was full to the top!
_________________
2002 Traveller
2001 Husaberg FX 470
1998 KTM 200
1984 Yam XT 600
1963 Honda 55
Back to top
hb7
PostPosted: Fri Mar 02, 2007 7:48 pm    Post subject: Reply with quote
So did you replace the float valve....?
Back to top
buckwheat5679
PostPosted: Fri Mar 02, 2007 9:20 pm    Post subject: Reply with quote
No, I did not think I would have to with only7900 mi. on it.
_________________
2002 Traveller
1998 KTM 200
1984 Yam XT 600
1963 Honda 55
Back to top
hb7
PostPosted: Fri Mar 02, 2007 9:37 pm    Post subject: Reply with quote
Did I understand correctly that the engine filled up with gasoline because the petcock was left on for an extended period ....?
Back to top
PostPosted: Fri Mar 02, 2007 10:55 pm    Post subject: bad Reply with quote
i have a bad habit of not turning mine off
they should be turned off each time you stop
if carb leaks and intake valve is open a real mess can develope
in the crankcase
suzuki made a 3 cylinder 2 smoker in the 70,s SUZUKI GT380 and 550 72-77
that would fill up the crankcase
of one cylinder and when it started on the other 2 it would strip the piston right off the rod
it would do it if gas not shut off and also would dump the autolube oil tank
into crank case if left set in the winter
these were 2 of the best suzuki's i ever had but shut off the oil and gas
or you would be replacing a piston soon
ar dave
_________________
www.qrz.com/wd8cyv
Back to top
PostPosted: Sat Mar 03, 2007 5:57 am    Post subject: Reply with quote
"bad Habit?"
dunno.
when we're talking about old(fashioned) Amals or Dellortos or Bings just after the war, that is one thing and I know from experience not to trust them.
But modern carbs of good design and materials don't need to be shut off ever if you ask me.
I don't shut mine off - I don't even have a petcock installed. I habitually remove them, replacing them with a quick-release hose connector. In the case of the Skorpion, the petcock is notoriously too small, another reason to do away with it. The quickrelease makes removing the tank easier in any event and on any bike. On the Skorpion in particular, where the petcock catches on the wiring harness and has to be carefully forced thru every time. And the quick-release can of course do double duty as a shut-off where it it is necessary; you can't be better shut off than entirely disconnected.
NB: the SZR has no conventional petcock nor any vacuum or electric one.
It does have a sort of faucet, but that can only be reached once the tank has been lifted; it is only to be able to remove the tank.
this is the kind between two hoses:
and then there are those in which the valve part is threaded and screwed into the the tank. Both Ducati and Aprilia have these as standard equipment. I get mine from the Aprilia dealer and he also has the proper tap to thread the hole.
_________________
Bill,
Back to top
PostPosted: Sat Mar 03, 2007 10:55 am    Post subject: connector Reply with quote
Bill
can you supply a brand name and part number for the disconnect you show
would like to have some but live many miles from any MC shop that would stock this stuff
a local ATV shop will order stuff for me if i know brand name and part numbers
ar dave
bmw shop 100 mile round trip closest they have ever been
most are 350 plus its 380 to look at ducati and triumph
the royal enfield from india is 650miles sold by the fellow that sold me the MZ
the MZ shop where i got the rt125 is 650 mile round trip
the reason i got to working on my own bikes was no dealer to serve me
so a mail order bike is the same as buying one from a dealer
you just miss out on the 500+mile round trip
_________________
www.qrz.com/wd8cyv
Back to top
buckwheat5679
PostPosted: Sat Mar 03, 2007 5:45 pm    Post subject: Reply with quote
Yep.
_________________
2002 Traveller
1998 KTM 200
1984 Yam XT 600
1963 Honda 55
Back to top
Drew
PostPosted: Sat Mar 03, 2007 7:35 pm    Post subject: Reply with quote
Yet Another Warning- always shut off the petcock. If your float level isn't set properly, you run the risk of fuel dumping out through the float bowl drain hose. I'm not sure how the drain is set up on the Baggies, but I've walked up to my bike sitting in a pool of its own gas before.
_________________
Relax. You'll live longer.
Back to top
buckwheat5679
PostPosted: Sun Mar 04, 2007 3:27 am    Post subject: Reply with quote
Kind of brought up a good point though, I wonder if I have pluged or pinched vent hose for the fuel to go into the motor. Confused
_________________
2002 Traveller
1998 KTM 200
1984 Yam XT 600
1963 Honda 55
Back to top
PostPosted: Sun Mar 04, 2007 12:36 pm    Post subject: Reply with quote
I googled around and found this for you:
http://www.colder.com/asp_main/GeneralPurposePlasticProducts.asp
_________________
Bill,
Back to top
droy
PostPosted: Wed Jun 27, 2007 6:43 am    Post subject: Reply with quote
Bill - do you have a picture and Aprilia/Duc part number for the fuel valve part as a replacement for the stock MuZ petcock.
BTW - link to that great quick connect valve.
http://www.motionpro.com/motorcycle/tools/quick_disconnect_couplings/
Doug
Back to top
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
