MZ Riders
Oil filter
Goto page 1, 2  Next
Author Message
matty
PostPosted: Thu Jul 08, 2004 12:18 pm    Post subject: Oil filter Reply with quote
Can anyone give me a number for an oil filter for a 2003 Baghira Enduro? Dealer wants $17.00 and Yamaha has no idea which one I need!
_________________
Where did all the flags go?
Back to top
PostPosted: Thu Jul 08, 2004 5:43 pm    Post subject: Reply with quote
The oil filter is the same as the old XT250 from 1980, if this helps
_________________
Back to top
View user's profile Send private message Yahoo Messenger
buckwheat5679
PostPosted: Thu Jul 08, 2004 8:10 pm    Post subject: Oil Filter Reply with quote
The Filter is the same as the yamaha XT 600; Yahama part # 4X713440-90 for about $9.00 or a Fram CH6005 for $5.00 but the Fram also comes with new O-rings and looks the same quality. Shocked
_________________
2002 Traveller
2001 Husaberg FX 470
1998 KTM 200
1984 Yam XT 600
1963 Honda 55
Back to top
DEmark
PostPosted: Thu Jul 08, 2004 8:30 pm    Post subject: Reply with quote
I use Emgo #10-79100 from JC Whitney, $2.99 each. Same as for SR500, and a whole bunch of other Yamaha models....
Back to top
matty
PostPosted: Fri Jul 09, 2004 4:16 am    Post subject: Reply with quote
Thanx a bunch!
_________________
Back to top
matty
PostPosted: Fri Jul 16, 2004 12:34 pm    Post subject: Reply with quote
I just got 10 Emgo filters off E-bay for $24.00. Man you gotta love technology!!! Anyone running sythetic oil? If so, what?
_________________
Back to top
phlat65
PostPosted: Fri Jul 16, 2004 7:51 pm    Post subject: Reply with quote
yes, I run the Pentosin full synthetic 5w-40 year round.
_________________
2001 MZ Black Panther
Back to top
hulagun
PostPosted: Tue Nov 23, 2004 7:57 pm    Post subject: Can someone tell me the best way to change my 660 BP oil? Reply with quote
Can someone tell me the best way to change my 660 Black Panther oil?
I don't want to overlook something. I have a new filter from the dealer already and am fairly mechanically inclined. Just dont want to over or underfill it, etc.
THANKS in advance-
Ivan
_________________
1978 Ducati 900SS cafe racer
1996 Kawasaki KDX200
Back to top
phlat65
PostPosted: Wed Nov 24, 2004 12:12 am    Post subject: Reply with quote
remove drain fitting from engine case, remove Banjo bolt attaching oil line to bottom of oil tank/head tube to drain tank.
remove bleed screw from oil filter housing and wait for oil filter housing to drain filter, then remove oil filter and replace with new filter. leave bleed screw loose when re-installing.
clean and re-attach Banjo bolt/screen.
clean and re-attach drain bolt.
add 2 quarts of oil. install oil fill cap and start engine breifly, watch for oil at loose bleed screw. shut off engine, tighten bleed screw, and add 3/4 of a quart to oil tank. start engine and follow oil checking proceedure, run at 3-4000 rpm until warm, let idle for 30 sec, and shut off and add oil until at full mark.
one easy tip: after the inital 2 quarts, you can start the engine with the oil fill cap off and listen for the tank line to suck air, you will notice a change in the sound from the oil tank. it will not hurt the engine, because there is oil in the crank case.
_________________
Back to top
hulagun
PostPosted: Wed Nov 24, 2004 10:33 pm    Post subject: Reply with quote
Thanks Phlat!!! I finally dug up my manual and your version is better.
Did you reuse the o-rings at those fittings or replace them with new? My buddy Tony said his MZ660SM leaked when he reused his old o-rings, and he had to do the oil change twice.
He also said the filters are a really tight fit. Guess I'll find out.
BTW, I plan to use Golden Spectro 4 synthetic in 10w40 as recommended by MZ.
Ivan
Back to top
phlat65
PostPosted: Thu Nov 25, 2004 12:08 pm    Post subject: Reply with quote
I have re-used the o-rings every time with no leaks. just don't overtighten the oil filter cover bolts. Very Happy
_________________
Back to top
m4panther
PostPosted: Mon Jul 04, 2005 2:10 pm    Post subject: found this for an oil filter alternative Reply with quote
http://www.hiflofiltro.com/17.0.html?&L=0&sel_uid=2507
_________________
2001 Black Panther
2004 1000s
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address Yahoo Messenger
PostPosted: Mon Jul 04, 2005 6:55 pm    Post subject: here it is Reply with quote
this link answers which one
the 660 motors
http://www.knfilters.com/search/kn_cross_ref.aspx?kn=KN-145
4cycle rotax and rt125 SM SX fun-x atk2003 LQ 125 4 stroke
http://www.knfilters.com/search/kn_cross_ref.aspx?kn=KN-151
the KN filters list for about $7.50usd
660 yamaha and rotax504e 500cc plug ngk d8ea dp8ea-9 dpr8eix-9
4 cycle 125 rt sm sx ect.... cr8e cr8eix
200spark
_________________
www.qrz.com/wd8cyv
Back to top
Chayanne
PostPosted: Wed Jul 06, 2005 7:27 pm    Post subject: Oil filter Reply with quote
K&N filters have good less cost options... See www.knfilters.com
_________________
Chayanne
Back to top
Nozz
PostPosted: Wed Jul 06, 2005 8:59 pm    Post subject: Reply with quote
From Foul_ Olis' post a couple of months ago...
Service parts are the same as Yamaha XTZ 660
Oli Filter - Yamaha part # 4X7-13440-90
Back to top
View user's profile Send private message Visit poster's website
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
