Author |
Message |
badseed
Posted: Sun Jul 25, 2004 1:05 pm Post subject: Rear Brake light |
My RT 125's rear brake light does not work. There is no problem with the front brake. How does the brake ligt work? I did not see any circuit cable around the brake lever arm. Is it triggered from an other place? There are 3 cables at the back of the light. One is ground and are the two others seperate for each brake signal?
Thx
Ugur _________________ rt 125 |
Back to top |
Posted: Mon Jul 26, 2004 12:41 am Post subject: brake light |
there is a switch on the rear brake master cylinder
mine went bad
short the wires together at that switch.. if the light comes on switch is probely bad
i recomend that you replace it with a mechinical switch of some kind
as i am still trying to get the air out of my rear brake system
older bikes had a switch and a pull spring and you dont have to
mess with bleeding the brakes
ar dave rt125 in wv usa
note at the tail lamp
one wire is groung usuall brown on german bikes
one is nite and day time run
and the brighter of the 2 filements is stop _________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv |
Back to top |
badseed
Posted: Tue Jul 27, 2004 4:44 pm Post subject: rear brake switch |
I found the switch and short circuit the cable. The light came out. Then I took out the switch to clean inside with a needle. I put it back then checked if it works. It worked only two times. I realized that I did not tighten hard and the brake oil came out of the cylinder. I went to the service and fixed the brake problem. But then switch started not to work again. Did you get a mechanical switch, the guys told me that they have never seen a switch like that. I most probably will order a new one from http://www.mzparts.de. It costs 12euro or sthing like that. _________________ rt 125 |
Back to top |
Posted: Tue Jul 27, 2004 10:32 pm Post subject: brake light switch |
if you have a bmw dealer in your area show it to his part man
it may be the same on a bmw i will look to see if there is a bmw number
looking at my notes from past work on my bike
aprilia number on parts bag is 8124479
mz part number = 9013198000 brake light switch
german =bremslichtschalter
PAGE in MY Parts BOOK = FO9 B3 item 6
same page item 7
also order 2 of 9013199000 sealing ring (dichtring) or copper washer
i can email parts page if needed
you may have to force brake fluid through the system backwards
from the caliper end to get the air out i am still not happy with the feel of mine
show this picture below to your parts man
word search rearbrakeswitch rbsw
aprilia number on parts bag is 8124479 _________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Last edited by DAVID THOMPSON on Thu Feb 22, 2007 6:55 pm; edited 2 times in total |
Back to top |
jbthumper
Posted: Sat Jul 31, 2004 2:09 am Post subject: |
Hi all,
I had the same problem with my rear brake pump on my sm....the swith works when the correct amount of presure(which is 5 bar for my bike)is applied through the pedal.....but when it leaks.....there won't be enough pressure....
what i did was i went to this aprilia workshop which a friend of mine recomended and changed the MZ switch with an aprilia switch....now it works fine.....(so u won't need to use those expensive BMW parts )
hope this helps!! |
Back to top |
badseed
Posted: Sat Jul 31, 2004 3:41 am Post subject: |
Did the aprilla switch fit to the MZ? Or did you have to do some additional stuff? _________________ rt 125 |
Back to top |
Back to top |
badseed
Posted: Sun Sep 12, 2004 6:55 am Post subject: Fixed at the end. |
aprilia 8124479 is the original part. I paid 16euros and now rear brake light is working fine.
thanx a lot. _________________ rt 125 |
Back to top |
