Author |
Message |
Posted: Sun Aug 01, 2004 6:04 am Post subject: Ait filter box mods |
Hi everyone.
Now I have my carbs sorted on my Baggy, I am thinking of carrying out a few mods. One mod that is mentioned a lot is to drill holes in teh air filter box. Just where are you guys putting these holes?
Any ideas would be welcome.
Keith _________________ Ride it like you stole it |
Back to top |
gedge
Joined: 08 Jun 2004 Posts: 191 Location: Portsmouth, UK
Posted: Sun Aug 01, 2004 3:05 pm Post subject: |
Keith I put 2 x 22 mm holes on each side , just above the seat line, so that all the crud stays out. I thought if I put them at the front or back they would get sprayed with muck( although my mate suggested rigging up some sort of ram-air with some ducting etc), so setled for having them just out of sight..I think you could put more if you wanted , but personally I think this is a big improvement and the 4 seem adequate . |
Back to top |
matty
Joined: 29 Mar 2004 Posts: 17 Location: Wichita Falls Texas
Posted: Fri Aug 06, 2004 5:34 am Post subject: |
All I did on mine is remove that top seal that goes between the seat and the air box. Not sure if it is in my head but it seems to have made a difference. _________________ Where did all the flags go? |
Back to top |
Randew2U
Posted: Fri Aug 06, 2004 6:37 am Post subject: Vent hole screening |
I accidently posted this question in another forum here. I have seen air box mods for various bikes that use small diameter black plastic "gromets" wit black plastic screening of the openings. Does anyone know where these can be purchased Thanks |
Back to top |
Brian
Joined: 19 Nov 2003 Posts: 252 Location: Seattle, Washington
Posted: Fri Aug 06, 2004 11:27 am Post subject: Re: Vent hole screening |
Randew2U wrote: | I accidently posted this question in another forum here. I have seen air box mods for various bikes that use small diameter black plastic "gromets" wit black plastic screening of the openings. Does anyone know where these can be purchased Thanks |
Check out marine suppliers or RV dealers both of those industries make such things......If you get stuck I can always send you some picts from some of my suppliers.....
Hey Sean, could you comment on airbox mods and pulling off the gasket etc......I know you haven't touched yours at all ?? also you have tested the airbox and found a vacum build up because of the design !!! I'm gonna start on mine next _________________ "Brian" 2003 MZ Baghira |
Back to top |
gedge
Posted: Fri Aug 06, 2004 11:48 am Post subject: |
Before I drilled mine the bike backfired a lot on the overrun and was very weak on acceleration. The new can and the holes have sorted it out a treat. I didn't bother with trying to find the little mesh grommets as the location of the holes is behind the side panel , just below the seat line. Unless you are going to do some serious offroading I can';t see there being much of a problem ( the crud still has to get past the filter to do any harm) |
Back to top |
phlat65 Moderator
Posted: Fri Aug 06, 2004 9:05 pm Post subject: |
uni makes the vent grommets, they can be ordered at any motorcycle store.
I checked the air box for negative pressure at WOT, was less than 1 inch of mercury. did not feel mods were necessary. I think air box mods add "seat of the pants" performance on the baggy, due to the increase in intake noise. My 2 cents (or pence) _________________ 2001 MZ Black Panther
Back to top |
Randew2U
Posted: Fri Aug 06, 2004 10:05 pm Post subject: |
There is a really neat Baghira air box modification to install an auto air filter project on the RVB web site: http://members.tripod.com/roy_bertalotto/id25.htm. I would probably take on the project if I could get a scaled template for the cutouts.
He has a custom nice fork brace as-well. |
Back to top |
phlat65 Moderator
Posted: Fri Aug 06, 2004 11:56 pm Post subject: |
and he has the full tunebike big bore kit with Flat slide carbs!!!! _________________ 2001 MZ Black Panther
Back to top |
Posted: Sat Aug 07, 2004 2:24 am Post subject: |
Gedge
Your last post clears things up a bit. The first post on this thread confused me a bit, I was trying to understand where you could drill some holes above the seat line of the air filter box as stated in your first post
Back to top |
gedge
Posted: Sat Aug 07, 2004 3:19 am Post subject: |
HTH sorry about the consusing description.. I knew what I meant |
Back to top |
Brian
Posted: Sat Aug 07, 2004 2:33 pm Post subject: |
gedge wrote: | Before I drilled mine the bike backfired a lot on the overrun and was very weak on acceleration. The new can and the holes have sorted it out a treat. I didn't bother with trying to find the little mesh grommets as the location of the holes is behind the side panel , just below the seat line. Unless you are going to do some serious offroading I can';t see there being much of a problem ( the crud still has to get past the filter to do any harm) |
Maybe I'm just cookie....but, when you put a free flowing exhaust on a bike it requires more fuel in the mixture right ??? When you increase air into the airbox you also need to richen up the mixture.... with what you have done, your bike should be running way too lean and popping badly on deaccel....also poor accel.... When my exhaust was put on when the bike was new, the dealer claimed to rejet (he lied) so my bike pops alot... I am taking my bike to a Dyno shop and have it done right for me because I really believe its running lean.......am I nuts or what ???
If you had that kind of success then I'm getting out the drill and putting holes in that thing as we speak _________________ "Brian" 2003 MZ Baghira |
Back to top |
mzthumper660
Posted: Fri Aug 13, 2004 8:10 am Post subject: K&N solution |
A while back I read an article in the BMWMOA that suggested using small K&N filters the size of a U.S Silver dollar. This helped rides of the BMW K bike get more air. What was needed to do the job was removing the airbox, drilling holes with a drill bit the size of the filter the some how using an adhesive to keep them in place. Just make sure you drill the holes in a smart location, preferably before the main filter. This mod I believe will solve the "muck" issue.
Best regards,
Alejandro
mzthumper660@yahoo.com |
Back to top |
gedge
Posted: Tue Aug 24, 2004 9:24 am Post subject: |
Brian wrote: | gedge wrote: | Before I drilled mine the bike backfired a lot on the overrun and was very weak on acceleration. The new can and the holes have sorted it out a treat. I didn't bother with trying to find the little mesh grommets as the location of the holes is behind the side panel , just below the seat line. Unless you are going to do some serious offroading I can';t see there being much of a problem ( the crud still has to get past the filter to do any harm) |
If you had that kind of success then I'm getting out the drill and putting holes in that thing as we speak |
I agree with you on the theory, but my bike is definitely stronger now,no popping and better acceleration, and seems to be running fine as regards mixture. |
Back to top |
Brian
Posted: Tue Aug 24, 2004 10:26 am Post subject: |
I'm drillin holes tonight !!!! I'll post picts later.....Thanks for being the Guinea Pig !!!! _________________ "Brian" 2003 MZ Baghira |
Back to top |
