Author |
Message |
smudge660
Joined: 17 Nov 2004 Posts: 12 Location: asylum central (uk)
Posted: Wed Dec 15, 2004 5:12 pm Post subject: bloody leak |
my baggi has a leak coming from underneath somwhere but do you think i can find it. it's only a couple of spots but it's annoying me big style i've checked the drain plug but no joy .any ideas _________________ Hated by many,understood by few |
Back to top |
Posted: Wed Dec 15, 2004 6:07 pm Post subject: |
There are lots of possibilities but look at the following first (the easy to fix items)
Sump drain bolt/sealing washer
Oil pipe bolt to frame
Oil pipe to engine (two allen screws)
Next try
Gearchange shaft oil seal
Gearbox out put shaft
next
Left and right hand outer covers.
Crankcase
These could be a pain if the surfaces are leaking.
Just had a thought, you dont have an automatic rear chain oiler fitted do you? If so it could be oil from that, try turning it down a bit.
Keith _________________ Ride it like you stole it |
Back to top |
phlat65 Moderator
Posted: Wed Dec 15, 2004 10:09 pm Post subject: |
don't forget to check the vent tubes. did you just perform any maintenance? _________________ 2001 MZ Black Panther
Old Hondas- TT500 Ascott, 305 Dream Touring |
Back to top |
