Author |
Message |
mista aJ
Posted: Fri Dec 17, 2004 8:52 pm Post subject: need some answers! |
hey,wassup!?im a begginer in scootering.. jus 1 2 ask ppl out there about k&n?what`s the good and bad things that could happen if i put it on Mozkito..can it go for a long distance?effect the engine?or.....hope i can get some answers...thanx!  |
Back to top |
antonio
Posted: Thu Jun 22, 2006 8:45 pm Post subject: |
K&N airfilters is an aftermarket filters which suppose to be much better in letting air in and dust/debrie out....But beware if you use the direct filter to the carburettor your performance should drop a little...you must built some distance around 10cm from the choke of the carb...
performance wise is slightly the same... _________________ MZ Moskito 2005
125cc - 150cc Tokahi Racing Block
Racing Cam Stage 2 (Taiwan) Lift 11.5mm
Mikuni VM34
Malossi Air Filter
SpiltFire Spark Plug Cable
NGK Platinum |
Back to top |
