Author |
Message |
Ballacraine
Posted: Wed Feb 02, 2005 3:07 pm Post subject: A 'Hello' from a Newbie! |
Hi Folks,
Just happened on a link to this site.... Looks pretty smart
I have a '96 Skorpion Tour.....It was in a bit of a state when I acquired it.
I love the way it rides & the big softy of an engine. As I am vertically challenged I put in longer dog bones on the rear suspension to sit the bike a little lower. It helped a lot.
It is my knockabout bike but I would like to refine & improve it.
As you probably guessed, I do have a problem I would like some input on.
One of the problems I had when I got it, was that the front brake caliper was seized on the two inner pots. I freed them off OK, but the damage was already done... The disc has been pushed over.....Dished, if you like...I priced up a replacement from the UK importer...Comes in at over £90 + VAT + P+P
Please does anyone know of discs from other bikes that fit...or any other info (part nos. sources etc) on compatible replacements...Brembo or whatever?
TIA
Nige. _________________ Sanity is in the eye of the beholder! |
Back to top |
Whysub
Posted: Thu Feb 03, 2005 9:15 am Post subject: |
Welcome (familiar name from another forum perhaps?),
The Yamaha R6 disc is a direct swap on the Baghira, but not too sure on the Skorpion. Not yet anyhow. |And not sure if the Tour differs from the Sport.
I have only just discovered that the Skorpion and the Baghira do not have the same brakes. After7 months of ownership.
Have a look at supermono.co.uk, as sometimes stuff appears on there that maybe of some use. _________________ 2004 Baghira
1995 Skorpion.
1992 CB750-Rat Bike
1986 CBR600-Makes The CB750 Look Tidy! |
Back to top |
Ballacraine
Posted: Thu Feb 03, 2005 12:28 pm Post subject: |
Thank you.
Could be!
The Tour, Sport & Cup Skorpions use the same front wheel / brake set up.
The Replica is twin disc and uses different discs.
I know the MuZ part number for the front disc, (9013164000).
What I need to know is are there any others which fit?
Thanks very much for the reply & link I will check it out.
Back to top |
