Author |
Message |
RiverDrive
Joined: 19 Aug 2004 Posts: 80 Location: Philadelphia PA. US
Posted: Sun Mar 13, 2005 3:15 pm Post subject: PSI |
This may be a dumb question but. How do I know what the best tire pressures for my skorpion are. The manual says 28 to 36 front and 28 to 42 rear, that is quite a range. Any advice out there? _________________ 01 Sport Cup
"Quality is the parent, the source of all subjects and objects." - Robert Pirsig |
Back to top |
Brian
Joined: 19 Nov 2003 Posts: 252 Location: Seattle, Washington
Posted: Thu Mar 17, 2005 1:07 am Post subject: |
30/32 would be a great startin point _________________ "Brian" 2003 MZ Baghira |
Back to top |
RiverDrive
Posted: Thu Mar 17, 2005 8:18 pm Post subject: |
I know that Front and rear tire pressure on a car can effect It's steering characteristics (under & Over steering) Does it have the same effect on a bike? If not what are the effects? _________________ 01 Sport Cup
Back to top |
F0ul_Oli
Joined: 01 Mar 2005 Posts: 103 Location: Deeside,North Wales,UK
Posted: Fri Mar 18, 2005 6:59 am Post subject: |
They have a much worse effect on a bike.
Too Low:
hard to steer, extra wear, inconsistant lean, loss of grip.
Too High:
Hard ride, no room for air to expand leading to a possibility of a blow out.
On the plus side, your steering will be faster!
I've noticed that outside Europe, people don't take much interest in setting up their tires properly, mixing brands, not checking pressures etc - anyone agree?
edit - its not so much the tires that define if a car will over or understeer, its where the power is coming from and the wheel that's under inflated. e.g a low rear tire on a rear wheel drive car will cause it to over steer but a low rear tire on a front wheel drive car will only cause the car to pull to one side. _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
http://www.businessandit.co.uk - putting the IT in Profit! |
Back to top |
RiverDrive
Posted: Fri Mar 18, 2005 8:58 am Post subject: |
You may be right.
All main stream Americas seem to care about is PH
"Low rear tire on a rear wheel drive car will cause it to over steer"
Point is well taken, I am a rear wheel guy, don't know much about driving front wheel drive cars.
Thanks for the info. _________________ 01 Sport Cup
Back to top |
