MZ Riders
lightning up the flywheel
Goto page 1, 2  Next
Author Message
tuny
PostPosted: Tue Oct 24, 2006 9:31 am    Post subject: lightning up the flywheel Reply with quote
hi,
i removed my flywheel and send it to be lightend i beleve it whas 400g they would take off.
but wile i whait i'd like to know if enyone allready is driving a modified flywheel? and what's the result of remarks?
still 3 weeks waiting ahead of me so that long time to miss the baggy Smile
Back to top
View user's profile Send private message Send e-mail MSN Messenger
Wonky
PostPosted: Tue Oct 24, 2006 10:41 am    Post subject: Reply with quote
What other modifications have you had to warrant lighten/balance?
Back to top
tuny
PostPosted: Tue Oct 24, 2006 12:51 pm    Post subject: Reply with quote
? don't understand the question, my bike is big bore 680 with other cams, other exhaust other piston (higher compresion) and tops on dyno at 57hp and 67Nm at back wheel but wanted just that more wich i could not find Smile hope to finde it in the wheel, cdi (and carbs in future)
Back to top
Wonky
PostPosted: Tue Oct 24, 2006 1:03 pm    Post subject: Reply with quote
Thats exactly what i meant buddy! Have you had 102mm bore? Have you had the head gas-flowed/ported? This will give you much more BHP. Lightening parts will add less resistance within the engines moving components, less vibration and will help with picking up the revs. Losing weight helps with higher speed and acceleration, thats why you can get titanium engine parts, power-to-weight-ratio is what we're discussing here! Hope this helps!
Back to top
ZzerO
PostPosted: Wed Oct 25, 2006 10:21 am    Post subject: Reply with quote
i think tuny has a 101.6 mm piston, cause it's a 680cc. would 8cc(or 0.4 mm on piston) make a big difference? i would also like to tune my skorpion in the future, something like tuny's baggie, about 60hp. does anyone have an idea how the performance would change on my skorpion? topspeed, acceleration...
greetz
Back to top
tuny
PostPosted: Wed Oct 25, 2006 11:56 am    Post subject: Reply with quote
greetz
yes thats the case with me, and my intake's are floated, didn"t think about it when i wrote the rest, don't be mistaken!! my bike goes like HELL realy i can pull it up on gas in 3e gear !!! but still want more
Back to top
Wonky
PostPosted: Wed Oct 25, 2006 2:08 pm    Post subject: Reply with quote
greetz
The performance change would be almost identical, the engines are the same! Our Factory MZ Skorpion, which your bike is based on, puts out 80+ BHP!
Back to top
Wonky
PostPosted: Wed Oct 25, 2006 2:11 pm    Post subject: Reply with quote
greetz
Back to top
Wonky
PostPosted: Wed Oct 25, 2006 2:12 pm    Post subject: Reply with quote
...and yes even 1mm in a bore will make a difference. I advise a 102mm bore with a JE or Wiseco piston and a Carrillo rod, plus all the other stuff you can afford! Very Happy
Back to top
DEmark
PostPosted: Wed Oct 25, 2006 5:56 pm    Post subject: Reply with quote
Increasing the displacement from 660cc to 680cc is a 3% increase in displacement, so horsepower should increase no more than 3%. A 3% gain on a 50 horsepower motor is 1&1/2 HP. This is assuming there are no other modifications. Am I right or am I missing something?
Back to top
ZzerO
PostPosted: Thu Oct 26, 2006 8:31 am    Post subject: Reply with quote
i'm not sure if thats right, could be, but normally if you rebore you replace the piston with a high compression piston, like the JE pistons, it goes from +/- 9:1 to +/- 11:1 so i think there is the most of the power from.
Back to top
DEmark
PostPosted: Fri Oct 27, 2006 8:33 am    Post subject: Reply with quote
zzero, yeah, I think you are right, most of the increase in power comes from a boost in compression ratio. I am shopping for a piston for my Baghira now, does anyone know FOR SURE if a raptor piston will fit the Baghira motor? I want a few more ponys without loosing much reliabilty, I am thinking a little increase in c.r. and a street cam. I suppose I ought to put a Carillo rod in too. I already have the Keihin fcrs and a M4 can.
Back to top
basser23
PostPosted: Fri Oct 27, 2006 10:57 am    Post subject: lightening flywheel Reply with quote
DeMArk,
Everything I have read indicates the Raptor piston is the same..
Have you checked at Barkers Bars? They have them for about $160.
Where in the Maryland republic are you located?
Chip
Back to top
DEmark
PostPosted: Fri Oct 27, 2006 11:31 am    Post subject: Reply with quote
I just checked out the barkers bars website, it looks like they have a lot of experience with the 660 motor, they even make their own connecting rods. I am in Elkton, just off I-95 a mile from the Delaware line. Where you located chip?
Back to top
ZzerO
PostPosted: Fri Oct 27, 2006 12:09 pm    Post subject: Reply with quote
yeah i 'm pretty sure that the raptor has the same engine and also same piston(not 100% sure though) but if it's the same, why would you have a increased compression then? does the raptor has a standard higher compression?
Back to top
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
