MZ Riders
lightning up the flywheel
Goto page Previous  1, 2
Author Message
basser23
PostPosted: Fri Oct 27, 2006 12:38 pm    Post subject: lightening the flywheel Reply with quote
DeMark,
Barkers has a huge amount of Mz,SZR,Raptor experience..their exhausts
are excellent for the Sport anyway. i have spoken with Andy Weiss on
occasion at Summit Point Wva raceway...he was running his SZR..most excellent.
I am located near Gaithersburg/Germantown/Frederick...
Chip
Back to top
View user's profile Send private message
Kirk
PostPosted: Sun Nov 19, 2006 11:30 pm    Post subject: Reply with quote
Yes the Raptor top end parts are a direct swap. I ordered a Hot Cam and Wiseco Piston for a Raptor and they were a drop in. The bottom ends are different so you need a parts fishe to compare for assurance.
_________________
98 mastiff
99 skorpion (wifes)
99 zrx
03 dl1000
09 hawk gt (wifes)
93 F650cs (wifes)
Back to top
PostPosted: Mon Nov 20, 2006 2:36 pm    Post subject: lighten flywheel Reply with quote
HI, Lightening the flywheel and starter freewheel is the first measure I recommend, long before changing anything in the engine or using other carbs.
I do this in in exchange for the parts from the customer plus of course the cost of modifying them, THAt whay the customer doesn't have to wait. Normally, I do it in the shop here while the customer waits and watches or helps if he wants to.
Part 1: the flywheel is turned down as much as is reasonbly possible.
Part 2: the freewheel is turned down to the step and an aluminum ring shrunk on, the whole turned to the original size. The freewheel is then reground inside.
The engine revs more freely, so the bike is more responsive, especially if the owner has followed my recommendation to mount a 42 or 43 tooth chainwheel + plus he best chain mony can buy(DID520 ERV2)and a 8400 rpm CDI. Besides the performance imporvement, the bike also need less gas for the same kind of riding. Stand to reason since the mass of the flywheel+freewheel is not eating up HP.
 Description:
reduced flywheel
 Filesize:  75.1 KB
 Viewed:  2434 Time(s)
 Description:
modified freewheel
 Filesize:  14.55 KB
_________________
Bill,
http://www.william-jurgenson.com
http://www.zabernet.de/bill/tuning.html
http://www.appel-tooling.com
Back to top
View user's profile Send private message Send e-mail Visit poster's website AIM Address
Wonky
PostPosted: Tue Nov 21, 2006 9:45 am    Post subject: Reply with quote
Hmmm! Great that you have some knowledge for us MZ guys Bill but lightening the Flywheel/Freewheel doesn't increase BHP. BHP will only be increased if you increase the amount of compression in the engine, cylinder volume, i.e a bore/port and polish. Lightening ANY parts in ANY engine just means that the engine has less resistence whilst turning over, thus meaning that the engine spins more freely. In the XT engine, for example, lightening the Flywheel/Freewheel will make the bike a little twitchy bottom end as there is less resistence from the heavier parts. This will result in a lurching twitchy throttle reponse and increasing the sprocket size will cause the use of more fuel. This approach to your XT engine before any other engine modifications would definately not be a good approach to tuning an XT engine. It would make an excellent addition to lightweight race-tuned components but i certainly wouldn't advise it as a first stop approach to unleashing power on a road tune or anything else for that matter! Confused
Back to top
basser23
PostPosted: Wed Nov 22, 2006 11:18 am    Post subject: lightening the flywheel Reply with quote
I agree with BOTH, Wonky and Bill. To realize what hp is available stock,
and increase the responsiveness,lightening the flywheel would make sense. You are using available hp to move the bike,not spin a flywheel up.
To make more hp, the mods suggested ,ie compression,bore, cams and carbs, exhaust would be in order.
Chip
Back to top
PostPosted: Thu Nov 23, 2006 2:07 pm    Post subject: Reply with quote
wonky wrote a bit further up:
Quote:
Lightening parts will add less resistance within the engines moving components, less vibration and will help with picking up the revs. Losing weight helps with higher speed and acceleration...
Exactly what I meant!
and then went on to write following my posting:
I did not mean to imply it does - of course it doesn't, but that doesn't deter from the fact that the mass of the flywheel etc does use power when it is accelerated. BHP is measured on the brake at more less constant revs; once at speed to flywheel doesn't need that power to be moved, on the contrary it could even aid in giving a eversoslightly higher rating since its mass also stores some of that power it needed to be accelerated.
The point ist - see wonky's quote above - that the lightened parts accelerate faster, need less power to do so and so also need less gas to do so. This has been tested. And of course when the rider takes advantage of the better performance he is NOT going to get beter mileage. I wrote
Then the
can't be used as an excuse. There is no excuse for not learning to control that right hand. The CV carb is of course no help since it allows heavyhandedness without punishment. Change to a flatslide and quickturn grip... Or perhaps "go back to school" with a classic high-performance 2-stroke with that narrow on/off band. My Tour will idle at 850rpm if need be - with that lightened flywheel assembly and no counterbalancer. Of course there is no reason or purpose for such a low idle in real life riding.
I have done this modification to several bikes with the XTZ engine, some tuned (lightly as well heavily; my racer has no flywheel at all, much less a starter and a much lightened crank and no counter balancer but has the least vibrations of any engine I have built) and a couple not at all, including my own SZR, a stock Tour and another stock Replica. Both the Replica rider, a motorcycle journalist, and the Tour rider reported independently that the bikes were noticably quicker to ride and needed less gas. What can I say? At the time I did it to my own Tour, it was not tuned either, but the counterbalancer had been removed. I ride the thing that way and have done so for the last 45000km.
_________________
Bill,
Back to top
Wonky
PostPosted: Thu Nov 23, 2006 5:28 pm    Post subject: Reply with quote
Good stuff mate, you didn't have to justify what you wrote, all input is appreciated and i'm not questioning your work, just the quote that you advise Lightening Flywheel/Freewheel as a first stage of Tuning to increase BHP, which it doesn't and wouldn't, with which you have explained in your above post, no worries! You obviously have lots of experience and i respect that. We've tuned hundreds of XT engines and our best engine won us the 2000 Supermono European Championship Title, we are very proud of that and try our upmost to explain things a little less technical, we are not all engineers and sometimes what we write can be a little misleading to those not as mechanically minded, thats all buddy. Thanks for the input though!
Back to top
tuny
PostPosted: Tue Dec 05, 2006 6:33 am    Post subject: Reply with quote
bike is running again and made some rides now,
i'm impressed by the power but if there is a big difference i can not tell, what i do know is that the bike comes up better in lower rev's and seems to pickup a bit sooner after chifting up. in the summer i'l try some more, with this weather it is not so perfect, i allready crashed it's front fender on a light poal. but the bike is ok, no other damage little to crazy ont the trottle in wett conditons made a hell of a slide but did not put him down, my front fender grabed the poal an i mised it by a mm. scarry but not enough to stop me back on and directly the trottle is the best cure.
Back to top
View user's profile Send private message Send e-mail MSN Messenger
Wonky
PostPosted: Tue Dec 05, 2006 8:52 am    Post subject: Reply with quote
Easy tiger! Take care out there buddy, make it safe.....or test on a bloody long straight road!
Back to top
tuny
PostPosted: Thu Dec 07, 2006 6:50 am    Post subject: Reply with quote
and back without bike Sad
this weekend i'm goiing to tri and find the error, my left handlebar swich doesn't work annymore, and have no time today and tomorw so it will be saterday as i test this. hope i find it quick Smile
Back to top
tuny
PostPosted: Thu Jan 04, 2007 6:37 am    Post subject: Reply with quote
yes yes long time but i'm back running. using my bike every day now and the most noticable difference i can find is that the bike schifts much much better in and out gear. the rest is not as spectacular as asumed but ok, i'm still satisfied i did this change and would do it again.
_________________
bandit rocks, mastiff kills
Back to top
cat
PostPosted: Fri Jan 05, 2007 4:24 pm    Post subject: Reply with quote
tuny wrote:
my bike goes like HELL realy i can pull it up on gas in 3e gear !!! but still want more
juss! get an R6 - and put mx bars on it - take the plastic off and put mx bars.
Back to top
PostPosted: Fri Jan 05, 2007 5:08 pm    Post subject: Reply with quote
Or for a little more comfort, put Enduro plastics, tyres and bars on a Goldwing Smile
_________________
Back to top
Display posts from previous:
Page 2 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
