Author |
Message |
gedge
Joined: 08 Jun 2004 Posts: 191 Location: Portsmouth, UK
Posted: Thu Jul 08, 2004 3:17 am Post subject: Modified front end? |
Has anyone managed to change the front of their Baghira and replaced the headlight and all the scaffolding that keeps it up?
I figure that this weighs a lot and so would be interested to hear if anyone else has managed to bin the lot. Photos would also be reallly helpful
Back to top |
Brian
Joined: 19 Nov 2003 Posts: 252 Location: Seattle, Washington
Posted: Thu Jul 08, 2004 9:54 am Post subject: Re: Modified front end? |
gedge wrote: | Has anyone managed to change the front of their Baghira and replaced the headlight and all the scaffolding that keeps it up?
I figure that this weighs a lot and so would be interested to hear if anyone else has managed to bin the lot. Photos would also be reallly helpful |
Check picts of Phlat65's he has a Acerbis Cyclops.......
_________________ "Brian" 2003 MZ Baghira |
Back to top |
gedge
Posted: Fri Jul 09, 2004 3:21 am Post subject: |
Thanks. I eventually found a pic of his bike... Looks great but there isn't much detail showing. do you think he could post( or email me) a close up of the Mods so that I can have a better look? Imitation is the finest form of flattery!
Back to top |
cat-tard
Posted: Fri Jul 09, 2004 9:40 am Post subject: |
I don't have a photo of phlat's bike... but here's the acerbis photos/info:
http://www.acerbis.com/p107_headlight/3002.html
I may be interested in the original parts that you remove for this mod if you go through with it depending on what kinda $ you want - if you're willing to sell the stuff, of course.
Back to top |
gedge
Posted: Fri Jul 09, 2004 10:13 am Post subject: |
That probably depends upon what the finished result looks like If it turns out okay I might sell them otherwise I may keep them until trade in time ......Could be expensive to ship though.
Back to top |
phlat65 Moderator
Posted: Mon Jul 12, 2004 11:56 pm Post subject: |
i will do some detailed pics tomorrow for you! installed HID lamp and controler last weekend, you cannot miss this thing during the day, it is BRIGHT!
_________________ 2001 MZ Black Panther
Old Hondas- TT500 Ascott, 305 Dream Touring |
Back to top |
gedge
Posted: Tue Jul 13, 2004 3:01 pm Post subject: |
Thanks I look forward to seeing the close ups.it will give me something to think about when I cant go out (.Just spent £6000 on wifes new car balance and then had to splash £400 on tyres for mine so I won't be doing much this month ...Ohh and I need spendies for my summer hols.).... skint again......
Back to top |
phlat65 Moderator
Posted: Tue Jul 13, 2004 11:47 pm Post subject: |
check the pics, I cut the side panel suppurt tubes even,, moved the cap from the inside to the visible side. The headlamp is held on with the supplied rubber straps. made a harness, and zip tied it between the 2 bosses on the head tube so it does'nt catch when turning. there is not enough room to run the stock speedo, so I installed a Trailtech electronic speedo, which is great!
in one of the pics, you can see me holding up the wind deflector that came with the headlamp unit, I modified and installed 1 I got of a BMW650 at a motorcycle swap for $10.00. MUCH better wind protection, but still looks cool
mounted lockhart phillips flush moun turn indicators on the hand guards, drilled through and ran the wiring on the back side.
last weekend added the HID lamp setup in the larger reflector, and mounted the controller under the right sidepanel.
any questions?
Description: |
Filesize: |
88.44 KB |
Viewed: |
2954 Time(s) |
Description: |
Filesize: |
70.8 KB |
Viewed: |
2954 Time(s) |
Description: |
Filesize: |
90.31 KB |
Viewed: |
2954 Time(s) |
Back to top |
phlat65 Moderator
Posted: Tue Jul 13, 2004 11:48 pm Post subject: |
the rest....
Description: |
Filesize: |
88.5 KB |
Viewed: |
2953 Time(s) |
Description: |
Filesize: |
82.67 KB |
Viewed: |
2953 Time(s) |
Back to top |
gedge
Posted: Wed Jul 14, 2004 3:13 am Post subject: |
Thanks for the pics. Just what I needed to see.. Just need some cash and a bit of nerve to start cutting!!!
Back to top |
DEmark
Joined: 30 Dec 2003 Posts: 218 Location: Maryland USA
Posted: Wed Jul 14, 2004 5:37 am Post subject: |
Phlat,
Where did you get the Trailtech speedo? Is it illuminated? Is it like a bicycle speedo?- i.e. picks up the signal from a magnet you install on the front wheel, program the wheel diameter into it so its dead accurate. How much it cost? Do you like it? My speedo cable broke yesterday, I'm thinking about alternatives......
Back to top |
phlat65 Moderator
Posted: Wed Jul 14, 2004 9:52 am Post subject: |
under $100.00 at a motorcycle shop.
I like it alot, has alot of features..
http://www.trailtech.net/computer.htm
Back to top |
DEmark
Posted: Wed Jul 14, 2004 11:16 am Post subject: |
I'm gonna order one up! Any idea which one (part #) you have?
Back to top |
DEmark
Posted: Wed Jul 14, 2004 2:34 pm Post subject: |
Phlat,
I just got off the phone with Trailtech, they have no idea which one to sell me. They need some more details.
How long is your cable? (I'll add 2" for my STD height)
How did the sensor mount? Screw to Caliper mount? Wire tie to fork leg?
What kind of magnet are you using? A magnetic disc bolt?
I hope you can help me out. They look like a good item to have....
Back to top |
phlat65 Moderator
Posted: Wed Jul 14, 2004 9:09 pm Post subject: |
got the universal, epoxyed the magnet to the right side of the hub, right at the spoke circle, and made a small "L" bracket for the sensor, bolted to the inboard axle pinch bolt, so the pickup is pointed at the magnet.
i will try to get some pics tomorrow for ya!
Back to top |
