Author |
Message |
mzsrus
Posted: Sun Jan 14, 2007 4:55 pm Post subject: mz 1000s broke down |
hi folks,
can anyone help me,
MY mz 1000s wont start.!!!!!! me bit peed off
ECU light came on at petrol station and now wont start!!!
when bike turned off all electric check seems to work but ecu light always on.
when press starter button.switch, nothing happens??
help me please pic below has anyone got a wiring pictures/link??
bye andy from wales
Description: |
Filesize: |
369.96 KB |
Viewed: |
4049 Time(s) |
_________________ Owner of 10 old mz bikes from 1956 to 1976
new owner of Mz 1000s |
Back to top |
Joined: 23 Nov 2003 Posts: 1118 Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
Posted: Sun Jan 14, 2007 6:24 pm Post subject: things to check |
my rt 125 lost the starter relay with less than 3000 miles on it
not sure where it is on your bike
some of the bikes have a side stand switch they will not start if it goes bad
thank goodness your in england .. you may find a dealer that can fix it
here in the USA we are up a creek with no paddle when they die
ar dave
_________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv |
Back to top |
LWS66
Posted: Sun Jan 14, 2007 7:08 pm Post subject: |
Andy, I would start with the most obvious and simple things and work towards the complicated possibilities. Have you checked the fuses and relays under the seat? I will look at my schematic and see what relays are for what and let you know via pm. Give each relay a good tap and check the fuses and go from there. I suspect it is something simple.
Lorin
Back to top |
phlat65 Moderator
Posted: Mon Jan 15, 2007 12:22 am Post subject: |
so is this a no crank, or no start with engine cranking? will it bump start?
possibly kickstand switch? does the neutral light come on in neutral?
in my experience with cars (I am a master tech with a diagnostic background) hot soak no starts with the engine cranking are usually a enginge position or cam position sensor if they are reluctance type (2 wire)
or bad solder joints in a relay or component. since it is fuel injected, if you have spark, and can hear the injector clicking with a mechanics stethascope then probably fuel supply. if no spark but good injector pulse then suspect ignition coil (unlikely since yours has dual coil on plug). if no spark or injectors, then suspect a sensor or ecu. if it quits hot, and re starts after 30 min, try putting the ecu or suspected component in the freezer for 5 minutes and if it starts, then repeat to confirm the problem.
does the tach needle move when cranking? if it does then engine sensors and ecu probably ok, suspect fuel supply.
usually if the ecu light is on, then ecu is powered up.
_________________ 2001 MZ Black Panther
Old Hondas- TT500 Ascott, 305 Dream Touring |
Back to top |
mzsrus
Posted: Mon Jan 15, 2007 6:29 am Post subject: mz 1000s broke down |
all electrics seem ok,
when turn mbike on at ignition, the mz runs through the normal checks on the dash.
its just when u push starter button, nothing happens.
it will not bump start, did try but bit frightened might break something.
It will not turn over crank at all, just seized up on trying to bumpstart.
so god know hopefully going to mbike dealership today or tues 16th Jan,
I need.want wiring diagram if anyone gots one, hopefully just a switch or sensor faulty.
Best wishes from Wild and wet Wales
Back to top |
millgreen
Posted: Mon Jan 15, 2007 9:36 am Post subject: |
Andy
Try jumping the starter solenoid, my guess is the handel bar switch not making contact, what with all the dry weather riding you do
Good luck Bill
Back to top |
Back to top |
LWS66
Posted: Mon Jan 15, 2007 9:07 pm Post subject: |
The ECU (engine) light comes on and stays on until the engine starts, then it goes out. Just to verify what I was thinking, I just turned the key on mine with the switch in the run position without pushing the start button...the ecu light stays on....... until it's started.
Did the ecu light come on prior to stopping the engine at the petrol station or did you only notice the light afterwards?
The ECU light has nothing to do with the starter relay I'm fairly certain.
If the light came on prior to stopping the engine, that would point to other issues....which I doubt.
Try the jumping of the solenoid terminals, and if it cranks, then either your not getting voltage to the solenoid from the start button...most likely corroded terminals, or the solenoid is bad (the contacts that take power from the start button) . You could open up the handlebar switch housing and have a peek also....spray a little electrical contact cleaner on the button contacts.
Keep us posted...there are plenty here to offer help.
Back to top |
OLDMTNCARVER
Posted: Mon Jan 15, 2007 11:39 pm Post subject: |
mzsrus,
Don't know if this will help...
Go to main page, select forum and then scroll down to 1000s.
The fourth post down should be from m4panther.
(I just got a complete parts number catalog on cd-rom.)
It shows the harness assemblies, but not a schematic, GRRR!
I would hope that this might help isolate the problem. The only issue that I've read on the forum has had to do with moisture getting into the controls.
I don't know if any of this helps, just hopeing.
Regards,
Robert
PS Your bike looks great!!!
Back to top |
Back to top |
mzsrus
Posted: Fri Jan 19, 2007 12:21 pm Post subject: mz 1000s broke down |
HI FOLKS, FOUND PROBLEM,
RELAY BROKE BELOW IN FARING WHICH REGULATES THE STARTER SWITCH!
ANYONE HAVE ANY IDEAS WHY THIS MIGHT BREAK??
OR JUST COULD IT GO ANYTIME?
LET ME KNOW
HAVE ORDERED NEW RELAY HOPEFULLY BE BACK ON ROAD END OF NEXT WEEK, JUST IN TIME FOR SNOW AND ICE SO BACK IN HEATED GARAGE I THINK
HAPPIER TIMES AHEAD HOPEFULLY.
PS JUST TO LET YOU KNOW, I WILL HAVE APPROX 10 EX DEMOS MZ 1000 OF DIFFERENT GUISES FOR SALE IN FEB 2007.
BYE FROM COLD, WET WILD WALES, POSSIBLE MZ'S NEW DEALER TOO
Back to top |
Posted: Fri Jan 19, 2007 12:52 pm Post subject: post |
post a picture of the bad relay and where it is located ....AND MZ PART NUMBER
so the next guy knows where to look
relays are sort of like a bell you can use them for years or they may crack
after only ringing a few times
www.qrz.com/wd8cyv
Last edited by DAVID THOMPSON on Sun Jan 21, 2007 11:31 am; edited 1 time in total |
Back to top |
kilou78
Joined: 21 Nov 2006 Posts: 6 Location: Nezel - 40 kms W from Paris / France
Posted: Sun Jan 21, 2007 6:21 am Post subject: |
only a relay....
and what's the price of it ?
Back to top |
mzsrus
Posted: Sun Jan 21, 2007 2:28 pm Post subject: mz 1000s |
hiya,
let you know part no and price of garage repairs when i do,
part ordered from BSA REGAL MZ dept on Friday 19th, so tell you when mz is back and fixed.
Bye for now MZ Wales
Back to top |
perryboy23
Posted: Wed Feb 07, 2007 2:57 am Post subject: |
these bikes cant be jumped started!!!
fact
Back to top |
