Author |
Message |
Chayanne
Joined: 03 Jun 2005 Posts: 48 Location: Mayaguez, Puerto Rico
Posted: Wed Feb 21, 2007 8:56 am Post subject: Lowering Kit or Dogbone for Skorpion tour 660 |
I'm trying a hayabusa dogbones for my skorpion, fits very good and gives 3 height options...
_________________ Chayanne |
Back to top |
Garf
Joined: 06 Jul 2005 Posts: 92 Location: Manchester, UK.
Posted: Wed Feb 21, 2007 10:03 am Post subject: |
Let us know how you get on fella. Do you know whether these would fit the mastif / Baggy suspension as well ? Post a few pics when you are done if you can.
Cheers
Garf
_________________ HR Black Panther |
Back to top |
sapperk9
Joined: 29 Aug 2004 Posts: 60 Location: Perth, Western Australia
Posted: Thu Feb 22, 2007 9:01 am Post subject: Busa Dog Bones |
Any chance of a pic of the Busa dog bones?
_________________ "In questions of science the authority of a thousand is not worth the humble reasoning of a single individual." - Galileo Galilei |
Back to top |
Chayanne
Posted: Sat Feb 24, 2007 3:21 pm Post subject: Lowering Kit or dog bone for Skorpion tour (PHOTOS) |
Please see photos attached... dog boe part# hayabuza 7075 T6 ...
Description: |
Dog bone for Skorpion Tour 660cc
(Hayabusa 7075-T6) MOTORCYCLE |
Filesize: |
149.21 KB |
Viewed: |
1849 Time(s) |
Description: |
(Hayabusa 7075-T6) |
Filesize: |
153.11 KB |
Viewed: |
1849 Time(s) |
Description: |
Filesize: |
158.37 KB |
Viewed: |
1849 Time(s) |
Back to top |
sapperk9
Posted: Sun Feb 25, 2007 9:02 am Post subject: Busa Bones |
Nice!! Thanks for the trouble Cob.
I'll have to get a pair.
Back to top |
AndyDent
Joined: 25 Oct 2005 Posts: 12 Location: Perth, Western Australia
Posted: Sun Feb 25, 2007 7:22 pm Post subject: |
Naive questions:
1) why would you want to lower it in the first place? Cornering or aesthetics?
2) if you're just lowering the back of the bike, what does this do to the steering geometry and braking feel. Does it make the rear brake more useful? I find the rear end incredibly light on my Sport and am considering making changes to make it lock up less, as per Ienatcsh's advice in "Sport Riding Techniques".
Back to top |
Garf
Posted: Mon Feb 26, 2007 3:14 am Post subject: |
If you dont lower the front proportionately, lowering the rear will effectively reduce the head angle and slow the steering a touch and make the bike a bit more stable.
Lowering both ends will keep the same geometry but change the centre of gravity which will also effect braking.
Just lowering the rear will put a little more weight over the rear so would presumably change the braking characteristics ....... whether this is a good or bad thing is probably down to personal preference.
Personally I reduced the front fork length of my baggy by 15mm to quicken the steering up a tad and put a bit more weight over the front wheel. I think this has improved the handling significantly ....but again this is probably just my preference.
Now I need to lower a baggy front and rear so the Mrs can get her feet down when I buy her one hence my interest in whether these bones will fit. Not a big deal really as they will be simple enough to fabricate anyway.
Cheers
Back to top |
Chayanne
Posted: Thu Mar 01, 2007 9:29 am Post subject: lowering Link |
I'm putting the lowering link for two reasons to fit a rear tire from 150/60/17 to 170/60/17 (more wide) and reach more stability near the original design.
Back to top |
g.forrest
Posted: Wed Mar 14, 2007 4:52 am Post subject: |
i can't see you using these adjustments. as on the muz this will radicaly change the angle of the swingarm which will change the handling very noticeably. found out when i replaced the bilstein with a koni 20mm longer. ended up with slots in new dog bones i made of alloy angle, then blocked off slots once i found the right angle.. cheers
Back to top |
