MZ Riders
DODGY FRONT END OVER 70MPH?!
Author Message
drj
PostPosted: Tue Apr 03, 2007 6:47 pm    Post subject: DODGY FRONT END OVER 70MPH?! Reply with quote
my baggy just went over 15000km recently and over the last few months the front end seems to be increasingly sketchier and sketchier on the freeway over 70mph...and i cant tell if its and axle issue - or something else...
any ideas?
drj
_________________
'03 Baghira (m4 pipe)
'00 XR400r (modded a bit)
Back to top
View user's profile Send private message
Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
PostPosted: Tue Apr 03, 2007 9:48 pm    Post subject: tail wags dog Reply with quote
can be many things but all the old timers i knew said check the rear end
as well as the front "the tail some times wags the dog"
tire pressure... tire wear
did you adjust chain and not get wheel true
did a tire go down and get pumped back up and not reseat on the rim properly
neck bearings did you hit a pot hole and stove something up
i hit a pot hole on us I77 in central ohio one year and busted both front wheel bearings and the race in the lower neck bearing doing about 80 mph
on a r90s bmw
rear swing arm bearings
the list can be long
ar dave
search words steeringbearing
_________________
Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Drew
PostPosted: Tue Apr 03, 2007 10:44 pm    Post subject: Reply with quote
Check for steering head play- involves lifting the bike up so that the front end is free to move, and moving the wheel by grabbing the axle to see if there is any play, front-to-back and side-to-side. The other thing to look for is to compress your forks (once it's all back on the ground!) and listen and feel for a "notch". You'll also want to check the nuts and bolts holding your steering head together.
15000km is about time you might think about having the head bearings checked, if not replaced. Typically motorcycle manufacturers use normal round bearings in their races (races in this context meaning the rings that hold the bearings in place), which eventually form a groove due to offset forces. If this is what you have (as most bikes come with this for upper bearings at least), then consider tapered roller bearings. The bearing assemblies themselves cost between $10 and $30, and you'll want to replace both upper and lower at the same time.
You'll want a reputable shop to do the work, as removing the bearings from the frame can be tricky without the proper tools, plus it's soooo easy to hide damaged goods in the steering head Exclamation
Skim through this link to get a better understanding of steering head anatomy, and what's involved.
don't have a baggy myself (strongly considering getting one soon) but I've had the steering head prob on a sportbike and had it sorted by a professional suspension shop.
_________________
Relax. You'll live longer.
Back to top
PostPosted: Wed Apr 04, 2007 9:30 am    Post subject: doggie Reply with quote
the link to the f650 site in drews post is a good read on the subject
and for the fellows with the rotax powered bikes a note
the OIL TANK IN THE FRAME seems to cook the oil in the steering head
bearings on bikes used in warm areas
so you fellows with the ROTAX MOTORS 4T
watch those neck bearings
as most of the rotax powered bikes are over 10years old
and even with low miles may need grease
ar dave
_________________
www.qrz.com/wd8cyv
Back to top
MSW
PostPosted: Wed Apr 04, 2007 11:00 am    Post subject: Re: doggie Reply with quote
ar dave
Wow. I never thought about this. The Baghira (and, I assume, the Mastiff as well) also has the oil in the frame, and not only that, a reservoir of oil connected directly to the steering head. Has anyone actually had issues w/this?
Maybe an add-on oil cooler is in order if one lives in a particularly warm environment. Or maybe a better grade of grease for the steering head bearings next time I have them out.
Thanks Dave.
_________________
MSW
2005 Black Panther
Back to top
PostPosted: Wed Apr 04, 2007 7:26 pm    Post subject: hot bearings Reply with quote
if BP and MASTIF have a frame oil tank
i would look close at the head bearing service intreval
mine a saxon tour with 504e rotax runs very hot and it
seldom gets past 90deg F in my area even on the hot days
ATK may have used oil in frame as well as CCM and HD in the MT500
if you have the front end off do check the neck bearings
ar dave
_________________
www.qrz.com/wd8cyv
Back to top
Display posts from previous:
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
