Author |
Message |
friendfire
Joined: 09 Jan 2005 Posts: 52 Location: Tring, hertfordshre. UK
Posted: Sat May 19, 2007 7:56 am Post subject: Relay Unit |
Hi All, need some advice please. My relay unit keeps packing up! on my second one now and dont know what to do or whats causing it...however...I did change the rear light for a twin LED unit and changed the rear indicators for led also....would these blow the relay unit?
If so, what could I do? will have to call BSA on Monday for replacement relay unit
Apart from that my Bike is ready to ride and will upload my freshly built bike....I feel so proud......well almost
ThanksMick _________________ http://www.projectmz.co.uk |
Back to top |
Joined: 23 Nov 2003 Posts: 1118 Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
Posted: Sat May 19, 2007 2:27 pm Post subject: relay |
which model bike and name or number or what relay is used for
leds use a bunch less power and should not be the problem
unless they have a load resistor built in to make the stock flasher work
which is a bad design
or sounds like the wireing is shorting to ground some where
if bike is a BP several fellows have had problems with pinched wireing harness under the seat or behind body panels
careful inspection of wireing harness is first place i would start
ar dave _________________ Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv |
Back to top |
friendfire
Posted: Sun May 20, 2007 6:29 am Post subject: |
Thanks for the reply, its on my Skorpion sports 96, the relay unit is the default part for this bike. I was told that these relays are weak and it would be worth finding a replacement from another bike...anybody have any suggestions?
Many Thanks
Back to top |
Posted: Sun May 20, 2007 2:39 pm Post subject: |
Friendfire
If you are talking about the main relay for all of the electrics, then a normal 12v spotlamp relay can be adapted to fit.
Keith _________________ Ride it like you stole it |
Back to top |
friendfire
Posted: Sun May 20, 2007 2:45 pm Post subject: |
Hi Keith,
All I can tell you is that its under the riders seat next to the fuses? I am rubbish with electrics as you can guess......so I'm assuming you mean I can purchase any relay unit and fit it? doh!! sorry _________________ http://www.projectmz.co.uk |
Back to top |
Posted: Sun May 20, 2007 2:58 pm Post subject: |
Friendfire.
The main relay on the Baghira is a small relay (with a aluminium case) mounted to teh frame next to the indicator relay.
To fit a normal relay requires some adaptation of teh wiring connections, but internally they are the same.
It might be worth buying a good quality relay.
Spot light relay connections form ths pattern
. 1
2 l l 3
... l
. 4
- or l indicates connection on relay and its orientaion. Please ignore the dots as I had to put them in tfor everything to line up
Connect as follows
Connection number 1 to rt/sw
Connection number 2 to rt/sw
Connection number 3 to gn (I think)
Connection number 4 to rt/ws
I think rt = Red
sw = Black
ws = White
gn = ?
Maybe others can confirm the wire colours as I am not sure.
Back to top |
Joined: 18 Nov 2006 Posts: 113 Location: D-74348 Lauffen am Neckar
Back to top |
friendfire
Posted: Mon May 21, 2007 4:22 am Post subject: |
Great thx for the replies! I have ordered what I now know to be the starter relay and didnt even consider the solenoid! The starter relay makes clicking noises etc. Have ordered 2 in case the next one packs up again...if it does I'm assuming what your saying is that the problem could indeed be the solenoid?
Many Thanks again
Back to top |
Back to top |
Posted: Tue May 22, 2007 2:36 pm Post subject: |
Ah, so the problem is solved. I was thinking of one of the other relays fitted to the Baghira, the stop relay, which is bolted onto the frame adjacent to the indicator relay.
The stop realy can be replaced with a normal accesory relay available from car shops.
As for starter relays, any replacement must have both of the wires for the control coil avaialble. One that is connected to the starter button, the other to earth. A diode is connected in parralel to thes wires, not sure why.
Most Honda ones can be adapted to fit, and if necassary, some older cars ones might be adaptable for fitment.
Back to top |
friendfire
Posted: Tue May 22, 2007 3:24 pm Post subject: |
Thanks for the input! new solenoid should be with me tomorrow so will let you know if this does indeed solve my problem! fingers crossed
Back to top |
Posted: Tue May 22, 2007 11:52 pm Post subject: |
Quote: | A diode is connected in parallel to these wires, not sure why. |
just for safety's sake. The relay spool doesn't care which is plus and which is minus; it will pull either way unless the plunger is a permanent magnet. Neither does the starter as far as that goes, tho it would turn the wrong way.
Again excluding permanent magnet motors.
Current flows from minus to plus in a diode. With the diode in parallel, exchanging the plus and minus will then create a short circuit, blowing the fuse but nothing else will happen.
Seriously, the diode is about a useful as a fifthwheel on a car (German expression). In the harnesses I have made there are no diodes at all. _________________ Bill,
http://www.william-jurgenson.com
http://www.zabernet.de/bill/tuning.html
http://www.appel-tooling.com |
Back to top |
friendfire
Posted: Thu May 24, 2007 1:11 pm Post subject: |
Weeeeeeeee!! it started after i replaced the starter sollenoid!!! well pleased...however....the M4 exhaust is..........LOUD! I have a sneaky feeling I could be getting stopped by the police more than once with this exhaust fitted! _________________ http://www.projectmz.co.uk |
Back to top |
