Author |
Message |
dthemic
Joined: 08 Nov 2003 Posts: 40 Location: Pittsburgh, Pa.
Posted: Thu Feb 05, 2004 11:02 am Post subject: attachments? |
just trying attachments with a photo of my MZ
Description: |
stock tour w/bags & windscren |
Filesize: |
59.13 KB |
Viewed: |
3122 Time(s) |
_________________ Dave
'01 Skorpion Tour
Pittsburgh, Pa |
Back to top |
125SMash Moderator
Posted: Thu Feb 05, 2004 1:02 pm Post subject: |
nice
_________________ 2002 MZ 125SM |
Back to top |
icannonball
Posted: Thu Feb 05, 2004 1:25 pm Post subject: another Tour with bags! |
[/img]
its nice to see what my bike would look like in Red! What windscreen are you using? This is a flyscreen from Holeshot.
Description: |
Filesize: |
58.99 KB |
Viewed: |
3110 Time(s) |
_________________ 2002 Skorpion Tour - blue |
Back to top |
phlat65 Moderator
Posted: Thu Feb 05, 2004 11:16 pm Post subject: |
heres the back of my Baggy...
Description: |
Filesize: |
108.35 KB |
Viewed: |
3100 Time(s) |
_________________ 2001 MZ Black Panther
Old Hondas- TT500 Ascott, 305 Dream Touring |
Back to top |
dthemic
Posted: Sat Feb 07, 2004 10:58 pm Post subject: Re: another Tour with bags! |
[quote="icannonball"][/img]
It's a Givi. The model is "Roadstar".Very easily removed and reinstalled. I like that. My bags are Hepko-Becker and look somewhat smaller than yours.
Description: |
Filesize: |
70.16 KB |
Viewed: |
3082 Time(s) |
'01 Skorpion Tour
Pittsburgh, Pa |
Back to top |
BAR
Posted: Mon Feb 09, 2004 3:28 pm Post subject: |
here's an '04 in the US
Back to top |
125SMash Moderator
Posted: Mon Feb 09, 2004 4:40 pm Post subject: |
vicious
Back to top |
phlat65 Moderator
Posted: Mon Feb 09, 2004 9:48 pm Post subject: |
saaweeet!!! Full height too
Back to top |
BAR
Posted: Tue Feb 10, 2004 1:10 pm Post subject: full height... |
Yeah, I need it being 6'5" and all...
Back to top |
Randy in norCal
Joined: 18 Dec 2003 Posts: 5 Location: Yuba City, Calif.
Posted: Sun Feb 15, 2004 7:13 pm Post subject: |
My copper colored Tour has a National Cycle deflector shield & universal mount Maier black hand guards. I don't have any pics of it yet, but this setup protects my whole body w/wind hitting my helmet, just like I want it to. The whole 3 pieces probably weigh all of 2? lbs. & cost about $100 total. When I have a pic I'll try to send it here.
I also got some waterproof black tank panniers(Rev-Pack) to carry stuff & they keep my legs out of the cold wind/rain. My shins are warmed by the motor heat.
_________________ `01 Skorpion Tour |
Back to top |
Brian
Joined: 19 Nov 2003 Posts: 252 Location: Seattle, Washington
Posted: Fri Feb 20, 2004 1:20 am Post subject: |
Niiiiice.... let me at the rear fender/light..... double check those caliper bolts on the front, my dealer claims the one lower hole was slightly oversized so was the two he had in stock... had to use loc tite.... so he claims worth a double check.....
_________________ "Brian" 2003 MZ Baghira |
Back to top |
BAR
Posted: Fri Feb 20, 2004 1:04 pm Post subject: rear fender/light... |
Yes, please ellucidate...
How would one go about modifying that back end to remove some of that "extra" rear fender area? There's a support bar back there about half way up the "vertical" section of the rear fender, so if you were to simply cut it (fender), you'd be exposing that bar (ugly).
Wish there was a simple way to "clean it up"...
Yeah, checked the caliper was first thing I did, after bringing it home...
Back to top |
Brian
Posted: Fri Feb 20, 2004 1:27 pm Post subject: |
I will send picts today.... its easy.........later.... Brian
Back to top |
BAR
Posted: Wed Feb 25, 2004 12:31 pm Post subject: |
Brian,
What's the steps to removal/modification of the back fender extension?
Back to top |
Brian
Posted: Wed Feb 25, 2004 4:46 pm Post subject: 2003 baggy rear fender |
I cut the fender using nibblers (look like a drill body with small scissor like cutter) In place (not removed from bike) can use jigsaw and flat file
Took grab bars off and used 5/16" Carriage bolts (1 1/4" long) to re fasten side covers to frame at the side of the seat.
used toilet hold down(teebolts) to hold rear fender assembly to tail light assembly
I removed the tail light assembly to cut frame
I moved tailight assembly back in place to where rear light is flush with back of fender.... marked near holes with marker tip going through fender holes, drilled holes and re assembled
These aren't in order but pointers only, I'll send picts in a bit
Back to top |
