Author |
Message |
F0ul_Oli
Joined: 01 Mar 2005 Posts: 103 Location: Deeside,North Wales,UK
Posted: Mon Mar 21, 2005 8:30 am Post subject: Backfiring! |
We had a lovely day yesterday - it was like summer so I went for a spin with a mate.
The Baggy was great, it kept up with a TRX850 on all the smaller roads, but wasn't too good on the bigger roads but neverthelesss ..
I found it was backfiring a lot - is there a way to stop it from doing this?
It seemed to be doing it on decelleration - coming up to a corner, I would twist the throttle closed, and it would go bang a few seconds later.
Will this damage the bike and is there a way of stopping it happening?
We were thinking that it might be running a little lean, but before I start fiddling, I thought I would be better off asking the people who know! _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
http://www.businessandit.co.uk - putting the IT in Profit! |
Back to top |
oldboyonrgv
Joined: 08 Jan 2005 Posts: 97 Location: Portsmouth U.K
Posted: Mon Mar 21, 2005 9:21 am Post subject: Lean |
they all do that sir !!, they are set up really lean standard, it won't do any intial damage but i wouldn't want to leave it like it.
Get a dynojet kit for a Yam660 http://www.tts-performance.com/ that will sort it. |
Back to top |
oldboyonrgv
Back to top |
Posted: Mon Mar 21, 2005 1:53 pm Post subject: |
Hiya.
Forgot where I put the info, could you e-mail me teh infoyou used to have on your old MZ web site on carb set up please.
keithcross55@hotmail.com
Ta
Keith _________________ Ride it like you stole it |
Back to top |
oldboyonrgv
Posted: Tue Mar 22, 2005 3:54 am Post subject: |
Ahhh , I was looking for the same thing ... I will have a look on the home P.C tonight. |
Back to top |
oldboyonrgv
Posted: Thu Mar 24, 2005 5:44 am Post subject: |
Nope its gone !! sorry, I could probably remember though . |
Back to top |
oldboyonrgv
Posted: Thu Mar 24, 2005 9:45 am Post subject: |
carb modifications. The mixture screw gets backed out(holeshot performance recommends 7 1/2 turns out from lightly seated),the main jet isn't adjustable, you replace the 130 main jet from the left side (as you're sitting on the bike)carb with a Kehin 135 and screw it in all the way tight. The midrange jet needles (both sides) get raised 1 notch, (this means the cirlip goes in the second groove from the pointy end) cut 2 coils from the constant velocity slide spring (right side)and re-install cut side down. Be sure to line up the diapraghm correctly, there is a little tab on the edge of it that fits into a recess cast into the top of the carb. At low altitude (below 5000 feet), you can drill the right carb's main jet with a #51 drill bit, just twist it between your fingers, no need for the drill press and re-install with a new P/N 90-20.142 crush washer. For around town riding this last step isn't really nessesary, you'll foul plugs more often and you should definatly keep a stock main jet (P/N 90-20.146) handy if you plan on doing any riding up in the mountains. The sync screw on top of the carb bank controlls the point after the low speed carb carb starts opening that the high speed carb begins to open, crank it in a turn or two so that as you twist the grip, you'll feel the freeplay take up, then the low speed carb start to open, then the added resistance of the high speed carb opening. You want the high speed carb to open just after the low speed opens, without as much of a delay as with the stock setting. This obviously needs to be set with the carbs reinstalled on the bike before the gas tank is replaced. Lastly, if yor bike is a Skorpion (Sport, Traveller, Replica Etc., not a Mastiff, Black Panther Etc.) Remove the black rubber snorkel from the top of the airbox. Of course, all these modifications are recommended for closed course, racetrack use only. Wink. |
Back to top |
oldboyonrgv
Posted: Thu Mar 24, 2005 9:48 am Post subject: |
By the way, You can also drillout the air damper hole on the CV side (its the hole next to the needle) to 4MM, this allows the air to move faster so the slide comes up qucker. and I also recall installing a larger pilot jet, but there again I was running a race exhaust. |
Back to top |
Posted: Thu Mar 24, 2005 11:31 am Post subject: |
All usefulstuff. As Iamgetting aspare set of carurettors (£20 froma guy I brought some gear off of on EBay) I might tryout some of the mods.
Any body else got tis on Carbs mods?
Back to top |
F0ul_Oli
Posted: Fri Mar 25, 2005 2:47 pm Post subject: |
This mod looks really good - but I think I'm going to have a go at getting an exhaust and a dyno jet adaptor sorted out first.
How much does this affect the fuel economy? _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
Back to top |
Whysub
Posted: Sat Mar 26, 2005 8:35 am Post subject: |
F0ul_Oli wrote: | How much does this affect the fuel economy? |
Who cares? If I wanted fuel economy, I'll ride everywhere at 50 mph, or buy a CG125.
Never bettered 50 mpg on either my Baggi or Sport-must be the way I ride them, as 40 mpg is the norm. I used to get 55 mpg from my GSX-R750 on my daily commute. But it was not even 10% of the fun I have now. _________________ 2004 Baghira
1995 Skorpion.
1992 CB750-Rat Bike
1986 CBR600-Makes The CB750 Look Tidy! |
Back to top |
boysie
Posted: Sat Mar 26, 2005 2:44 pm Post subject: |
Hi Kieth, yes mate I have also been running a similar setup for a number of years now, I seem to remember you have to order the pilot jet form a Yamaha dealer for an XT, as MZ don't supply pilot jet options, also you can modify your CV side main jet by drilling and taping it to accept Dynojet jets this gives more options for adjustment..
Oh yes, don't forget to drill some stonking great holes in the airbox;- |
Back to top |
Posted: Sun Mar 27, 2005 1:00 am Post subject: |
Cheers to all. Boysie. when we gunna see your bike now its had te engine mods done?
Back to top |
F0ul_Oli
Posted: Sun Mar 27, 2005 6:27 am Post subject: |
[quote="Whysub"] F0ul_Oli wrote: | How much does this affect the fuel economy? |
Reason Im asking is I wanted to know if it was a huge percentage or just a couple of MPG.
One of the basic laws of modification is that getting more power involves burning more fuel. My brother modded his smartcar and this knocked his fuel economy from 64mpg down to 34mpg! Quick though!
F0ul_Oli _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
Back to top |
oldboyonrgv
Posted: Mon Apr 18, 2005 9:26 am Post subject: MPG and tuning |
F0ul_Oli where did you get that from ? getting em to run right makes them more economic as they are more efficient so you dont have to use so much throttle for the same result.
its only when you tune for speed you start to have an effect on the economy.[/quote] |
Back to top |
