MZ Riders
stupid is to small a word
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk
Author Message
jim grace
PostPosted: Fri Mar 25, 2005 3:06 pm    Post subject: stupid is to small a word Reply with quote
Embarassed put new ebc disc pads in rear caliper yesterday= a doddle Had a go at changing the front!!! disaster, i only have use of one hand, so removed calliper and undid one of the pad support pins ,on the second one my hand slipped and i rounded the allan key head so i cannot remove it? can you buy replacement pins from MZ , also is it possible to drill out the damaged one CHEERS JIM. Exclamation
Back to top
View user's profile Send private message
PostPosted: Sat Mar 26, 2005 12:37 am    Post subject: Reply with quote
you may want to take the good 1 to a MC shop and match up. may be a pretty common pin size.
as far as getting the other 1 out, you should be able to carefully drill off the head of the bolt, then the rest should thread out W/O any problems. you can try an e-z out, but if it breaks, it makes the job 10 times harder.
I have had really good luck welding a bolt that fits into the rounded end to the damaged bolt, then backing out.
also, 1 last one, use an impact style bit driver with the correct size or next size allen socket.
_________________
Back to top
PostPosted: Sat Mar 26, 2005 2:07 am    Post subject: Reply with quote
In the past, when a allen type headed bolt has rounded out, I have managed to use a torx bit with a bit of gentle persusion. You have to prceed with care though as it will need some force to get the torx bit to fit and the bolt is useless afterwards.
_________________
Back to top
Dezmo
PostPosted: Sat Mar 26, 2005 3:31 am    Post subject: Reply with quote
reverse pitch drill bits are your friend....with a little luck the bit will grab and back the bolt right out for you. I have a set of them that comes with matching sized extractors. As long as the threads arent damaged, you should have no prob getting it out.
_________________
Hella Yella, coming ta getcha!
Back to top
View user's profile Send private message Visit poster's website
Display posts from previous:
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk All times are GMT - 5 Hours
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
