Author |
Message |
jbthumper
Posted: Sun May 08, 2005 3:17 pm Post subject: DIY: cam setting |
hey guys!!
can anyone teach me how to set-up those cams for the 125??
from scratch...like....how to loosen the timing chain....
how to check piston position and coordinate with the right cam position??
does the intake cam suppost to feel tighter than the exhaust cam???
i thank all in advance.
p/s:pics or diagrams or both would be great!!
Back to top |
witttom
Joined: 05 May 2005 Posts: 71 Location: Southwestern Ohio
Posted: Mon May 09, 2005 9:27 am Post subject: Re: DIY: cam setting(need help) |
Quote: | can anyone teach me how to set-up those cams for the 125??
p/s:pics or diagrams or both would be great!! |
Wouldn't mind seeing this information myself!
_________________ Tom Witt
http://members.aol.com/motorcyclelogic
78 Honda CX500 Cafe-X
99 Triumph Trophy 1200 Dual-Sport
02 MZ 125SM StreetMoto
03 MiniMax Z40 4Sale/Trade
04 SkyTeam ST50 |
Back to top |
mphcycles MZ Dealer
Posted: Mon May 09, 2005 6:22 pm Post subject: Re: DIY: cam setting(need help) |
witttom wrote: | Quote: | can anyone teach me how to set-up those cams for the 125??
Wouldn't mind seeing this information myself! |
The 6 mm plug screwed in the frt of crankcase is the TDC locator. Use a 5 allen pin, rotate the crank till the pin drops in. Now youre locked at TDC
The cams have a punch mark, intake is at 9 oclock, exh at 3.Flush wtih head parting surface.
I dont have any pics, but its a doddle of a job. If you have ever timed a four stroke , you can do this guy.
_________________ Mike Haven
MPH Cycles
www.MPHCYCLES.com |
Back to top |
jbthumper
Posted: Mon May 09, 2005 11:11 pm Post subject: |
info is great!!but i'm too scared to do it without a diagram...very much a newbe on engines...
i think i have a rough idea on how to position the cams....but using the TDC locator,that i have a problem with
Back to top |
jbthumper
Posted: Tue May 10, 2005 11:37 pm Post subject: Re: DIY: cam setting(need help) |
mphcycles wrote: |
i think i managed to find the TDC...i poped in the 5 allen just like u said...turn the crank shaft until it feels somewhat stuck...where the 5 allen had jammed it on TDC...right???
for the intake and exhaust position....is this viewed from tthe crankcase side or charging coil???
Back to top |
witttom
Posted: Wed May 11, 2005 1:34 pm Post subject: Re: DIY: cam setting(need help) |
jbthumper wrote: | i think i managed to find the TDC...i poped in the 5 allen just like u said...turn the crank shaft until it feels somewhat stuck...where the 5 allen had jammed it on TDC...right???
for the intake and exhaust position....is this viewed from tthe crankcase side or charging coil??? |
Are you taking pictures while you do this??
04 SkyTeam ST50 |
Back to top |
jbthumper
Posted: Wed May 11, 2005 11:16 pm Post subject: |
i still need to know from which angle to view the cams...you know...the 9 and 3 o'clock thing....will be posting those pics once i know....
Back to top |
bdalameda
Joined: 09 Sep 2004 Posts: 20 Location: Salinas, California
Posted: Thu May 12, 2005 1:46 am Post subject: |
I would make sure that the 5mm locking bolt is ground down on the end so it can engage the crank TDC point properly. The MZ tool is hardened so that it cannot be sheared off if using to lock the engine. You will be looking at the end of the cams from the mag side of the engine. The forward hole in the cam (bottom edge of the hole should be even with the cam cover gasket surface when the cam is timed properly. The cams are held in place by only a friction lock by tightening the cam sprocket center bolts. When you remove these bolts make sure to clean the threads very well both on the bolt and internal cam threads, use contact cleaner or alchohol. Use only blue threadlocking loctite on the cam sprocket bolts when re installing them, never use the red or you will never get the bolts out again. The engine will actually run better if you time the intake cam forward so that the hole in the cam is about 50% covered by the gasket surface. the engine will pull top gear better and have a more even powerband. Make sure you remove the cam chain tensioner if you are removing the cam sprockets. After making the adjustments to the cam timing remove the crank lock bolt and turn the engine over a couple of times and recheck the timing.
_________________ two MZ 125's
Cannondale E440 -Yes Cannondale made motorcycles!
KTM 380
Yamaha TTR 125
owned 26 bikes over 36 years |
Back to top |
jbthumper
Back to top |
jbthumper
Posted: Sat May 28, 2005 5:47 am Post subject: |
Then,unscrew the allen plug in front with number6...
Description: |
Filesize: |
118.45 KB |
Viewed: |
2924 Time(s) |
Back to top |
jbthumper
Posted: Sat May 28, 2005 5:51 am Post subject: |
with pushing the number5 allen in,rotate the magnet(PIC 1) until the number5 drops a bit deeper in the crank...you will feel the restriction on the magnet...this is the TDC position
Back to top |
jbthumper
Posted: Sat May 28, 2005 6:03 am Post subject: |
loosen the cam sprocket like so...
(do on both cams if you need to set both)
Description: |
Filesize: |
119.71 KB |
Viewed: |
2917 Time(s) |
Back to top |
jbthumper
Posted: Sat May 28, 2005 6:04 am Post subject: |
i think you guys can follow fom what bdalameda says on the position...
don't forget to tighten them cams up...
take out the number5 allen and spinnnn the magnet....
Description: |
Filesize: |
120.35 KB |
Viewed: |
2916 Time(s) |
Back to top |
jbthumper
Posted: Sat May 28, 2005 6:07 am Post subject: |
DONE!!
i thank all of you guys that helped me and those who took their time to see these pictures!!(sounds like something from the Grammy Awards..lol)
Description: |
Filesize: |
121.31 KB |
Viewed: |
2915 Time(s) |
Back to top |
jawzx
Joined: 16 Apr 2005 Posts: 19 Location: Johnson VT, USA
Posted: Sat May 28, 2005 9:42 am Post subject: Mystery wheel in the background... |
Hey JB, I can't quite tell 'cuz it's out of focus, and a little low resolution, but is that an Alfa Romeo wheel I see in the background?
Nice pictures of the job by the way, very helpfull!
_________________ 2002 125-SM |
Back to top |
