MZ Riders
rear suspension rebuild
Author Message
BRAAAP !
PostPosted: Tue Aug 16, 2005 3:24 pm    Post subject: rear suspension rebuild Reply with quote
I've just had the shock rebuilt and am having a go at the re-assemble. . .
I have nearly finished but am unsure of the procedure for tightening the rear-most bolt which attaches to the swingarm. .
anyone had a go at this ?, I'm having trouble getting it to tighten centrally. . .
Confused
Ed.
 Description:
 Filesize:  112.34 KB
 Viewed:  691 Time(s)
_________________
two wheels good, four wheels bad. . . .
Back to top
View user's profile Send private message
PostPosted: Tue Aug 16, 2005 5:14 pm    Post subject: Reply with quote
I carried out this task earlier this year, the bush in teh bottom of the rear shock went bad. Didnt have any problems though.
Just a thought, have any of the small collers in teh rearmost bearing broken, they are a litle fragile Embarassed
_________________
Back to top
Fil
PostPosted: Wed Aug 17, 2005 3:20 am    Post subject: Reply with quote
I've just stripped and rebuilt my rear suspension - I didn't have any problems with the bit you mention, but one thing you may have to do is use a small open ended spanner (can't recall what size) to hold the flats on one end of the shaft that runs through the bearing assembly, while you tighten the nuts.
Hope that helps!
Back to top
BRAAAP !
PostPosted: Wed Aug 17, 2005 3:46 am    Post subject: Reply with quote
I’ve had all the rollers out of the double needle roller bearings at the back, re-grease’d the race and put all of the (62 !) rollers back in. The shaft with the tapered collars and plain collars looks ok and feels smooth when in place.
As you know the shaft is threaded on BOTH ends. When I tighten up one end (and hold the squared end on the other side ?) then move to the other side and tighten that up as well, the plastic collars don’t squish up evenly.
So I took the nuts off again and I noticed the plain collars on either end of the shaft had not gone in to the casting the same depth.
Being too picky am I ?
_________________
Back to top
BRAAAP !
PostPosted: Fri Aug 19, 2005 2:05 pm    Post subject: Reply with quote
problem solved, took it apart and re-assembled and seems to be ok, tightened up evenly using the method advised. . .
them gremlins again I guess Twisted Evil
_________________
Back to top
Display posts from previous:
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
