Author |
Message |
blackpantheruk
Posted: Fri Sep 09, 2005 7:02 am Post subject: Hand Gaurds |
Anyone know what hand gaurds will fit straight onto the Black Panther?
trying to find some on t'internet.
i like the gaurds that cover your whole hand and connect to the bar end,
Cheers,
Craig |
Back to top |
BRAAAP !
Joined: 13 Aug 2005 Posts: 54 Location: Derbyshire, England
Posted: Fri Sep 09, 2005 1:02 pm Post subject: |
I've just bought some of eBay. .
check out item #4574270178 on ebay.co.uk
cheap end of the market but don't look like a pair of moose ears !
not fitted mine yet but dusne look to difficult . . . . _________________ two wheels good, four wheels bad. . . . |
Back to top |
roge-a-billy
Joined: 14 Aug 2005 Posts: 41 Location: edge of madness (west london)
Posted: Fri Sep 09, 2005 4:03 pm Post subject: |
Got some to of Evil bay. I'm going to have to either buy shorter / different levers or cut the ends off and get replacement ones to fit for M.O.T time. Also crash bungs for the wheel spindles, the spindles seem to be solid right the way through, so will have to put a thread in them with long bolts _________________ Up to my knees in gin & hookers |
Back to top |
BRAAAP !
Posted: Fri Sep 09, 2005 4:21 pm Post subject: |
going to get my MOT before fitting them. . .
seen a lot of folks that seem to angle the guards down to avoid this problem. . .
anyone got any ideas regarding fitting brush guards ???
Back to top |
phlat65 Moderator
Posted: Fri Sep 09, 2005 8:30 pm Post subject: |
trimming the levers, or wider bars so you can move the clutch and brake in to clear. I run bark busters on the RM , and never have to cut levers, but on the baggy, I had to remove 1 inch or so.
I run the MSR guards, and they have lived through an asphalt crash with minor scratching. _________________ 2001 MZ Black Panther
Old Hondas- TT500 Ascott, 305 Dream Touring |
Back to top |
bigzed
Joined: 08 Apr 2004 Posts: 31 Location: sunny essex uk
Posted: Sat Sep 10, 2005 3:31 am Post subject: |
I'm using acerbis guards,not the bark buster ones though, which went straight on to renthal bars with no cutting of levers or messing about. |
Back to top |
blackpantheruk
Posted: Sat Sep 10, 2005 6:16 am Post subject: |
where do i get renthal bars? are these better than the stock?
Cheers, |
Back to top |
bigzed
Posted: Sat Sep 10, 2005 10:51 am Post subject: |
Hi craig,Try bandcexpress , demon tweeks or google for a local dealer, i don't know if they're any better than stock but hey bling is bling |
Back to top |
blackpantheruk
Back to top |
bigzed
Back to top |
bigzed
Back to top |
phlat65 Moderator
Posted: Sat Sep 10, 2005 9:25 pm Post subject: |
size and bend are all preference. the CR high, and CR low are the 2 most common bends. I think I run a doug henry bend pro-taper, they are pretty straight with little pull back. _________________ 2001 MZ Black Panther
Back to top |
