MZ Riders
off road wheels for Baghira
Goto page 1, 2  Next
Author Message
F0ul_Oli
PostPosted: Thu Sep 15, 2005 4:00 pm    Post subject: off road wheels for Baghira Reply with quote
Hello
Did a search but with no luck!
I'm looking for some off road wheels for the Baggy streetmoto on ebay!
A difficult task at the best of times!
Does anyone have an idea of what other wheels might fit my Baggy (21", 17")
Does the compatable wheel depend on the disc and or the spindle?
I am guessing that a KTM wheel might do the job, but I don't want to buy anything until I have some kind of confirmation
Thanks in advance! Smile
F0ul
_________________
Back to top
View user's profile Send private message
PostPosted: Thu Sep 15, 2005 11:07 pm    Post subject: Reply with quote
well, I bought an early 90's KTM desert wheel, 18inch with a cush drive hub. bolts right in, I just need to figure out the brake rotor size, and sprocket size. they both line up, only needed to trim 1 spacer.
I have a 2003 ktm front, but the bearing ID is twice the baggy's. I think an early KTM front will bolt right in, then just have to find correct rotor. KTM's used the conventional 45mm marzocchi magnum fork until 97 or 98, so just keep your eyes peeled.
_________________
Back to top
F0ul_Oli
PostPosted: Fri Sep 16, 2005 8:21 am    Post subject: Reply with quote
Acctually, I hadn't thought about using an 18" wheel - it might just work!
What about some of the other manufacturers out there? I know the brakes are also found on Aprillias and the Yamaha DT (rear)
Anyone have dimentions of the wheels to do a virtual comparision?
thanks in advance
_________________
Back to top
DEmark
PostPosted: Fri Sep 16, 2005 11:07 am    Post subject: Reply with quote
If I was going to adapt a different spoke rear wheel to my Baghira, I would investigate using a wheel with straight pull spokes. I have had spoke breakage problems with the stock Baghira wheels. Straight pull is stronger and easier to replace a spoke when it breaks. The Honda XR650L has straight pull spokes....
Back to top
View user's profile Send private message Send e-mail
PostPosted: Fri Sep 16, 2005 8:15 pm    Post subject: Reply with quote
well, the rear hub is XT600, so you would think the XT wheel would fit. the stock XT wheels are steel, and the rear is 17 inch. I would go with the 18inch wheel, lots of tires avaialble!
_________________
Back to top
PostPosted: Sat Sep 17, 2005 12:58 am    Post subject: Reply with quote
Hi all
This idea has been looked at on previous threads. Basically the use of other Yamaha wheels has been looked at. All would appear easy until you come to fit XT wheels. Check tthinkhe bearing sizes first as I dont think Yamaha hubs use the same bearings, so either the hub would have to be modified, a different spindle/axle would have to be used or suitable spacers/bushings would have to be made.
_________________
Back to top
Anders-MZ
PostPosted: Sat Oct 01, 2005 3:57 pm    Post subject: Reply with quote
Phlat65.
Do you have any pictures of the KTM wheels? (closeup of the hub would be nice) Both me and Hoke intend to replace the original wheels with the KTM. The brake rotor size is not a problem, there is a company here in Sweden that uses laser to cut discs. There is no problem for them to cut a disc with KTM bolt pattern with different diameter. Price is aprox 50Euro each, that's cheaper then MZ-original.
Back to top
Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
PostPosted: Sat Oct 01, 2005 6:42 pm    Post subject: Reply with quote
if they have a web site send me there www and email
i paid $159usd for a rt125 front and would love to do buzness with them
next time i need a disk
i even have an old disk for a pattern
_________________
Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Anders-MZ
PostPosted: Sun Oct 02, 2005 3:23 am    Post subject: Reply with quote
The companys name is "Njurunda Teknikservice". The website is only in Swedish -> http://www.xenonljus.se/product_info.php?products_id=93
You can mail them at nts@telia.com
Phone: +46-70-533 1641 or +46-60-53 92 90
(timezone GMT +1)
If you need any help, let me know.
Back to top
PostPosted: Sun Oct 02, 2005 10:23 am    Post subject: disk Reply with quote
thanks Anders
i will put it in my notes as the price is very good even with shipping and
any dutys
i will have the bike apart after dec 1st and will be looking close at
all the parts as i plan on taking it on a 1600 + mile trip next summer
_________________
www.qrz.com/wd8cyv
Back to top
PostPosted: Sun Oct 16, 2005 8:35 pm    Post subject: Reply with quote
sorry for the late reply guys, been really busy.
here you go. appears to bolt right in with only 1 spacer change. axle dimension is the same, offset to both sprocket and brake disk are real good.. 18 inch by 2.5 inch wheel. cush drive hub.
cannot post pics at this time...... will put in the album.
_________________
Back to top
old paul
PostPosted: Mon Oct 17, 2005 6:56 am    Post subject: Reply with quote
How about getting someone to lace a different rim onto your existing hub? PO did that on my Mastiff, changing from the Behr wheel to Akronts. I don't know how to do that, or how much it might cost, but it certainly can be done.
_________________
Motorcycling used to be my second favorite thing, but now that I've become an old man, it's moved up a notch.
Back to top
PostPosted: Mon Oct 17, 2005 10:29 pm    Post subject: Reply with quote
the real nice thing about those KTM wheels are they are staight pull spokes, and it only cost me $75.00 on ebay
_________________
Back to top
DEmark
PostPosted: Mon Oct 31, 2005 9:19 am    Post subject: Reply with quote
I went for a 520 mile tour this weekend, entirely on the road. Found ANOTHER broke spoke in the rear wheel this morning. Again, it was one of the shorter side, inner spokes. This wheel was laced from scratch with new spokes by a professional in Texas.
If you want to change your 17" motard wheels for a 18 x 21 combo, don't waste your money on the stock Baghira wheels, get them ktm wheels like Pflat did.....
Back to top
Hoke
PostPosted: Mon Oct 31, 2005 12:16 pm    Post subject: Reply with quote
I have changed the "inner" MZ-spokes to ordinary "motorcrosswheelspokes". The guy who manufactured them, told me that the MZ-spokes probably broke because of the chroming. I got Zinked ones, but stainless is even better (he did not have them at stock).
I have not broken a spoke since i replaced them (been riding on road, dirtroads and endurotracks).
It only cost me 8-euro since I only replaced the innerspokes that keept on braking (grrrr no more MZ-spokes ). Off course i hade to loosen all spokes before replacing then bad ones.
At last the wheels seems ok for offroad use! Very Happy
(But the MZ-rims is still crap -get KTM....)
Edit:
Phat65, did the MZ cush drive hub fit right on to the KTM-wheel?
Back to top
View user's profile Send private message Visit poster's website
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
