Author |
Message |
jbthumper
Posted: Wed Sep 14, 2005 2:06 pm Post subject: Grimeca Front Master Cylinder(rebuilding) |
Hi all,
Does anyone know any compatible rebuild kit that might fit the front master cylinder???or OEM ones???
also...how much do they cost??
Appreciate all the help... _________________
Back to top |
jbthumper
Posted: Fri Sep 16, 2005 2:41 am Post subject: |
anyone?? _________________
Back to top |
Posted: Fri Sep 16, 2005 12:47 pm Post subject: |
Which model??
Keith _________________ Ride it like you stole it |
Back to top |
jbthumper
Posted: Fri Sep 16, 2005 1:38 pm Post subject: |
hi,looking for the 125... i think the 125 have the same master pump as the 660baggy... _________________
Back to top |
jbthumper
Posted: Thu Dec 01, 2005 11:23 am Post subject: |
anyone??
any compatible rebuild kit??or ANY rebuild kit for that matter....???
i only know grimeca off ducatis'...
FYI the 125 shares the same FF master cylinder as the baggy...
thanks. _________________
Back to top |
dpaarman
Joined: 23 Jun 2005 Posts: 4 Location: Independence, MO
Posted: Thu Dec 01, 2005 1:03 pm Post subject: |
I'm checking on the OEM Gasket kit for your 125, it contains 7 pieces. I'll update as soon as I get any info
MidAmerica PowerSports Plus
Don;
816-777-1785 |
Back to top |
jbthumper
Posted: Thu Dec 01, 2005 1:24 pm Post subject: |
thanks!if u can't find it, maybe i'll try the front brake pump rebuild kit of an aprilia make or something... _________________
Back to top |
phlat65 Moderator
Posted: Thu Dec 01, 2005 8:17 pm Post subject: |
the front pads are the same as the aprillia Pegaso, so I would guess the master is the same. also, the KTM dual sport bikes upto 2000 or so use the same front controls, the brake light switch is the same for sure, maybe they also use the Grimeca master... _________________ 2001 MZ Black Panther
Old Hondas- TT500 Ascott, 305 Dream Touring |
Back to top |
old paul
Posted: Thu Dec 01, 2005 10:47 pm Post subject: |
Worst case scenario, if you cannot find anything, take the o rings and seals to any good parts store. They'll have something the same size. _________________ Motorcycling used to be my second favorite thing, but now that I've become an old man, it's moved up a notch. |
Back to top |
jbthumper
Posted: Thu Dec 01, 2005 11:42 pm Post subject: |
phlat65,
the 125 only share the same m/c as the baggy...calipers off the 125 are japanese(weird,huh? ) but will still keep a look-out for those ktm m/c.
old paul,
thanks.
_________________
Back to top |
Hoke
Joined: 07 Feb 2005 Posts: 56 Location: Stockholm, Sweden
Posted: Fri Dec 02, 2005 12:27 am Post subject: |
Tip: The Baggy front brake looks exactly the same as the Yamaha TTR 600 Brembo front brake |
Back to top |
jbthumper
Posted: Fri Dec 02, 2005 2:25 am Post subject: |
hey thanks! this is getting better and better!! _________________
Back to top |
dpaarman
Posted: Fri Dec 16, 2005 11:13 am Post subject: RT 125 Master Cylinder Rebuild Kit |
OEM Rebuild kit #8050751000; Retail = $ 15.88, In-Stock at MZ warehouse! Call with your contact info & I can get the kit drop-shipped to you! S&H should be around $8.00!
Don
816-777-1785 |
Back to top |
jbthumper
Posted: Fri Dec 16, 2005 11:38 am Post subject: |
hi,
is that the part number from MZ??
if it is, i'll see if i can get it from MZ warehouse here(malaysia)...
might save me the s/h costs
(i know....i know...cheapskate )
thank you! _________________
Back to top |
