Author |
Message |
waverider
Posted: Fri Dec 30, 2005 11:49 am Post subject: Custom Built Baghira Skid Plate w/ Pics |
After taking my Baghira out in the dirt and rocks for the first time and ripping the oil line from under the frame, I had to come up with a quick and reliable solution for a skid plate.
I called Touratech and they wanted over $100 US and six week to get the plate that they offered. I didn't want to wait that long so I decided to build my own.
I called up a local metal shop and took a couple of sketches with dimensions over to them. The wanted $35 for the 11 gauge plate with one bend in it. Perfect. From there I trimmed the plat to fit the exact contour I wanted. I also welded in three mounting tabs and bolted it up.
Here are the pics:
Now I have a heavy duty skid plate with full coverage od the engine and oil lines. It also offers some protection to the water pump.
Cheers |
Back to top |
jbthumper
Posted: Fri Dec 30, 2005 1:24 pm Post subject: |
looks good _________________
Back to top |
F0ul_Oli
Joined: 01 Mar 2005 Posts: 103 Location: Deeside,North Wales,UK
Posted: Fri Dec 30, 2005 3:21 pm Post subject: |
any chance of posting the pattern so us on the other side of the pond can have something as nice?
F0ul _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
http://www.businessandit.co.uk - putting the IT in Profit! |
Back to top |
waverider
Posted: Fri Dec 30, 2005 5:46 pm Post subject: |
No problem. I will trace off an exact pattern when I get back in town and can pull the plate off of the bike. The drawing that I took to the metal shop was nothing than a 21"X15" piece of 11 gauge metal with a 100* bend 15 1/2" on the long side.
From there I just traced out along the frame rail of the bike and used a cutting torch to trim it back.
Cheers |
Back to top |
Posted: Fri Dec 30, 2005 6:11 pm Post subject: |
Well I think it looks better than some of the expensive ones acessory shops well.
Keith _________________ Ride it like you stole it |
Back to top |
