Author |
Message |
roge-a-billy
Joined: 14 Aug 2005 Posts: 41 Location: edge of madness (west london)
Posted: Fri Mar 03, 2006 3:37 pm Post subject: just finished |
before and after
Description: |
Filesize: |
25.72 KB |
Viewed: |
1501 Time(s) |
Description: |
Filesize: |
109.72 KB |
Viewed: |
1501 Time(s) |
Description: |
Filesize: |
106.78 KB |
Viewed: |
1501 Time(s) |
_________________ Up to my knees in gin & hookers |
Back to top |
Posted: Fri Mar 03, 2006 4:28 pm Post subject: |
Looking good matey. What can is that?
BTW for ride outs etc look at
www.solentsupermotos.co.uk
I ride with this group and they are a friendly bunch and some of the ride outs start from the Basingstoke / Reading area. The ride outs have between 4 and 35 supermotos taking part.
Back to top |
roge-a-billy
Posted: Sat Mar 04, 2006 1:18 pm Post subject: |
From front to rear:-
R1 brake disk, axle crash bungs (solid axle drill & tap to fit) Acerbis supermoto mud guard, Hand guards, in board mounts off E-bay rap round bars by owner, ally moto-X bars, Domino grips, Split fire plug, NGK silicon lead, Both carbs lifted up a notch on the needles and mix screw turned out 7 turns from closed ( still slight popping on over run so really needs a jetting kit ) adjusted so CV carb opens just after primary carb. Rubber strip top of air box removed, But might put it back to try and richen it back up. Exhaust from box to twin pipes cut and rewelded by owner for a pattern so an adault could then weld it professionally ( www.predatormotorsport.co.uk). Carbon Can Co exhaust (came with the bike ). Exhaust bar the can sprayed in BBQ paint (cheeper than exhaust paint just as good) because.... well I like it! White panels done by a local company, not easy so many curves caused white panels to crease alot so he had to get special vinyl in, at no extra cost. Stickers picked up her and there (moto-X and off road show) mainly free. Acerbis rear guard and mini flashers came with bike. Axle crash bungs on rear
Description: |
Filesize: |
275.38 KB |
Viewed: |
1466 Time(s) |
Back to top |
cat
Joined: 30 Nov 2005 Posts: 398 Location: South Africa
Posted: Sat Mar 04, 2006 9:54 pm Post subject: |
It looks good.
Next time get the cat in the photo.
Take a close-up of the disc, please - I wanna see how it's done. The caliper mount looks stock from here - is it a bigger disc?
The Acerbis tail piece works ok, that's quite a good way to solve it.
Where did you get the Domino grips?! I've just been searching for them - now. I gave up ...there's only one place that has them, it seems - carpimoto, but they only come with the throttles - I was about to email them and ask if I could buy just the grips - but now I'm looking at their rear wheel stands. And it looks like they only do UPS, which would cost way too much.
The rubber strip you mention, on top of the air box - d'you mean that strip of car door sealing stuff? I wondered how air was supposed to get in. I drilled holes in mine.
Did you do the sliders yourself? I know phlat mentioned it once, used a drill press, but I want to know how deep and so on.
There's..some..tip about the carbs - I've got it saved, but I think I posted it here - it involves raising one needle and lowering the other. So that might help.
Thanks for the photos. I wouldn't mind some more. Get the cat in too, like next to the front wheel..I think it'll match the bike.
Back to top |
Posted: Sun Mar 05, 2006 2:28 am Post subject: |
Cat
The early Yamaha R1 disc is a straight replacement. I've had one fitted for about 18 months now as the bobbins on the original diac got real loose. It was so bad the disc rattled, with about 1/4 inch of radial play.
I think the disc is the same as the Yamaha Thunderace as well.
Back to top |
cat
Posted: Sun Mar 05, 2006 2:54 am Post subject: |
keithcross wrote: | Cat
Keith |
yeah I read that thread about alternative parts again. Well, that's nice, at least it's not some odd bolt pattern.
What is a bit odd, though, is the size of the disc bolts; the only thing they're like at all is some Ducatis, it seems. M8x15 in the front, and the back ones are M6x16 but they've got flanges, like integrated washers. Most of the others have nice shanks/collars bigger than the thread diameter, and they're mostly much longer. The only other bikes with such short bolts are the mx bikes.
oh, those bobbins...that's why I wouldn't trust those Stealth sprockets, no matter what they say. The last thing you need is bobbin/rivets holding your sprocket together.
Back to top |
Posted: Sun Mar 05, 2006 4:57 am Post subject: |
While that tail end looks good, I dont really want to start hacking off bits of the frame. Now if I could get hold of another sub frame at a low enough price, things might be different. Same applies to the front bars for the headlight and the sides of the fuel tank.
I actually have a similar rea light assembly in my workshop and a sammer acerbis one with an LED rear light.
When modifying a bike I like to be able to have the bits to put it back to standard just in case. Silly I know but thats just me.
Back to top |
cat
Posted: Sun Mar 05, 2006 6:18 am Post subject: |
Yes, me too. I might persuade myself, if I get really tired of trying to do it another way, but...I can always compromise at first and go riding instead of fussing about it.
Back to top |
roge-a-billy
Posted: Sun Mar 05, 2006 6:35 am Post subject: |
As Kieth says The front disk was a straight bolt on. I went to the Big UK bike show (N.E.C Birmingham) and asked the EBC brakes stand the cost of wavey R1 disks, 124.00 pounds and he also quoted numbers for a 320mm disk when I said it was for a supamoto. They were very suprised and interested when I said it fitted MZ Baggi's and wrote it down for future ref'. R1 disk is lighter and does give you better brakes, bought of E-bay 11.00 pounds all in.
Domino grips off E-bay from some one braking a CCM Duel sport, some would say the CCM had fell to pieces and he was sell what was left 5.00 pounds all in
As kieth says I go steady messing with the carbs/ breathing and just start with bits I can replace first eg:- rubber strip lift needles etc, Have now got a 135 main jet which I will be putting in soon.
Axle bungs, I drilled with the axles still on the bike VERY carefully have used long M8 bolts, but drilled the hole deeper than the than the length of the bolts. If there is a bike/floor interface and one brakes off your going to have to drill out remaining bolt to start again.
Tail piece came with bike as I said and sub frame has not beeen cut in anyway will check on make fair sure it was acerbis but will have a look some time
Cat standard Tabby female unmodified, but like Baggi a bit over weight
Kieth I am aware of Southern S/M at Bordon etc, problem is I also Mechanic/ sometimes race Bangers at Fleet Hants. Mrs Billy not so happy If I'm out ALL the time
Back to top |
cat
Back to top |
cat
Back to top |
cat
Posted: Sun Mar 05, 2006 7:20 am Post subject: |
Ariete grips, supposedly the hot thing,, well, they're ridiculous, I wouldn't have them if you paid me. They've got ones with leopard skin print and ones with cows and flowers and stuff sticking out the ends.
http://ariete.eroom.it/products/display_unit.html
Back to top |
Roge a billy
Let me know when you are racing next, might pop in for a visit. Fleet is only about 20 miles from me
Back to top |
Scheffi
Posted: Sun Mar 05, 2006 5:03 pm Post subject: |
Yeah... nice bike!!
When I was 18 I used to love doing things like this, but now I have no time and no desire.... I prefer riding my bikes.
Perhaps I don't have to impress the young girls any more!?
Joerg
_________________ Baghira Enduro, MZ ETZ 250 with sidecar
http://www.sachsen-tourismus.de/
http://www.germany-tourism.de/ |
Back to top |
roge-a-billy
Back to top |
