MZ Riders
MZ Baghira - Technical Data, Service Specifications, Parts.
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk
Author Message
cat
PostPosted: Thu Mar 16, 2006 2:13 am    Post subject: MZ Baghira - Technical Data, Service Specifications, Parts. Reply with quote
MZ Baghira - Technical Data, Service Specifications, Alternative Parts.mht
If anyone has any more details (like part numbers, specific models, etc.) please post them and I'll update the document.
MZ Baghira - Technical Data, Service Specifications, Alternative Parts.zip
 Description:
Download
 Filename:  MZ Baghira - Technical Data, Service Specifications, Alternative Parts.zip
 Filesize:  77.86 KB
 Downloaded:  290 Time(s)
Back to top
View user's profile Send private message Send e-mail
Hoke
PostPosted: Fri Mar 17, 2006 7:28 am    Post subject: Reply with quote
Greate!!!!! Very Happy
Headligh is the same as for the Husqvarna/Husaberg to (cheaper here in Sweden) and a lot of other KTM and offroadbikes, the TTR 600 fits to (but is not H4).
The indicators are the same as some Husqvarna/Husaberg to, some mopeds have them to (then they get really cheap ).
Airfilter: KTM Duke 1 (DT1 RW 250-02) will fit ok.
Thanks 4 the greate efford, here in Sweden there is only one MZ-dealer (very good one, but far away - http://www.eurospeed.nu ) and You have to find some other bike with the same stuff on to be able to buy spare parts from the local dealer. This list is perfect for us! Very Happy
I think that the rear breakdisk is the same as the "old" BMW 650 Funduro and the front one as the older Yamaha R6.
And off course the engine and the carb is the same as Yamaha XTZ660, so all XTZ-engineparts will fit...
Stock rear sprocket on the MZ 660 Baghira Forest (1999) = 45 tooth.
Don't forget to loosen the oilcap to before draining the oil
And then to put it on and tighten before starting the engine Laughing
Keep up the good work!
Edit:
andyw wrote:
'Twin Air' filters for the MZ Mastiff,the part no you require is 154512
.......or as I did by luck find the same filter as listed for the KTM SC/Duke and Maico 98/03.
No-Toil air filter maintenance kit - aerosol bidegradable filter oil, filter grease and cleaning fluid (try MX shops Wink )
Look here to for interchangeable parts http://www.mzriders.com/viewtopic.php?t=606&highlight=interchangeable
Back to top
View user's profile Send private message Visit poster's website
cat
PostPosted: Fri Mar 17, 2006 9:57 am    Post subject: Reply with quote
Thanks, Hoke. The original file is from a Finnish guy's website; when I find it, I'll forward the thanks to him. (His website is interesting.)
It was originally the Enduro specs (wheelbase, seat height, etc.) but I took that out before I posted it, thinking that it is not that that we are interested in; the main thing is to have a good list of alternative parts.
Hoke wrote:
Headlight is the same as for the Husqvarna/Husaberg to (cheaper here in Sweden) and a lot of other KTM and offroadbikes, the TTR 600 fits to (but is not H4).
If you can get part numbers... even better.
Is that the part number?
Good, with that and the Twin Air number that andyw has given, I should find the UNI Filter number.
We must get part numbers, or model years. I know that 2 people used R1 front discs but I didn't add it because I think the R1 / R6 discs have changed over the years.
Hoke wrote:
And of course the engine and the carb is the same as Yamaha XTZ660, so all XTZ-engineparts will fit...
Yes.
Only problem with that - for me (and the americans, I think) is that I like to get parts from US vendors because the prices are lower, but their online microfiches do not have the 660 models. (Today I was looking for the intake valve cover gasket (and I found that it was an o-ring) so I could find it only by looking at the Raptor 660.)
Yes, sorry about that, I'll fix it.
Embarassed
Back to top
PostPosted: Fri Mar 17, 2006 10:48 am    Post subject: Reply with quote
The R1 front disc I have on my Baggi is the early type, up to 2002 I think. Its also the same as the Yamaha Thunder Ace.
Indicators are also the same as fitted to some Triumphs and Ducatis. Front brake light switch same as some Aprillia's,
Most smaller o rings same as XT600,
Sprokets are the same as some model years of the XT600/TT600. I think you will find this on the site somewhere.
_________________
Back to top
cat
PostPosted: Fri Mar 17, 2006 12:03 pm    Post subject: Reply with quote
Thanks, Keith. I'll add the R1 disc -02. www.mrcycles.com has Yamaha microfiche.
Front brake light switch... that's a useful one, because they seem to be things that fail. I read somewhere that some Grimeca parts are the same as Brembo.
The indicators seem so common, and most people would probably replace with smaller ones. ...It doesn't seem worth trying to include them. I think the information in the thread is good enough.
The o-ring for the intake valve cover was $4-$5, way too much for an o-ring. Better to measure it and source it locally. I thought it was a gasket and that I'd rather have a couple of gaskets to use instead of messy Yamabond, but the o-rings will last for years.
I've just been trying to cross-reference Twin Air and Unifilter - including Uniflow / Unifilter Australia. Unifilter is hopeless and Unifilter Aus list doesn't correspond to Twin Air - the KTM LC4 models and years. Which means Twin Air get the MZ rider business. Smile
Back to top
Hoke
PostPosted: Fri Mar 17, 2006 12:25 pm    Post subject: Reply with quote
The front brake light switch are the same as the KTM LC4:a, and one off the two most common universals -just take the old one with you to the dealer and compare. Almost any hydraulic brakelight switch will fitt the Baggys rear brakelight to...
Sorry, no numbers Rolling Eyes
Back to top
cat
PostPosted: Fri Mar 17, 2006 12:32 pm    Post subject: Reply with quote
ah! ok. There it is in this thread now. What to do.
It sounds like they are the ones that are famous for being sh*t.
I was thinking about the tail light bulbs, that people say are blowing so much... maybe they're like the house light bulbs we get nowadays, made in China. Mad
Back to top
cat
PostPosted: Fri Mar 17, 2006 1:53 pm    Post subject: Reply with quote
Keith, what d'you think?
Yamaha YZF front disc part numbers (USA)
YZF-R1 (1999) 4SV-2581T-00-00
YZF-R1 (2000) 5JJ-2581T-01-00 (replaces 5JJ-2581T-00-00)
YZF-R1 (2001) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
YZF-R1 (2002) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
YZF-R1 (2003) 5JJ-2581T-11-00
YZF-R1 (2004) 5VY-2581T-20-00
YZF-R6 (2000) 4SV-2581T-00-00
YZF-R6 (2001) 4SV-2581T-00-00
YZF-R6 (2002) 4SV-2581T-00-00
YZF-R6 (2003) 5SL-2581T-00-00
YZF-R6 (2004) 5SL-2581T-00-00
FZ1 (2001) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
FZ1 (2002) 5JJ-2581T-11-00 (replaces 5JJ-2581T-10-00)
FZ1 (2003)
FZ1 (2004) 5PX-2581T-00-00
my guess would be either the 2000 R1 or 2001-2003 R1 and FZ1/Fazer.
btw, did you use the original bolts?
Back to top
PostPosted: Fri Mar 17, 2006 3:40 pm    Post subject: Reply with quote
Yep I used the original bolts, the set up has been working well know for just about 20,000 kms Smile.
I also like the idea of a link that lists compatable part from alternitive sources.
_________________
Back to top
cat
PostPosted: Tue Apr 04, 2006 4:43 pm    Post subject: JT Sprockets at denniskirk.com Reply with quote
Rear sprocket JT857.xx (where xx is number of teeth)
Listed at www.dennniskirk.com for Yamaha XT600
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=8110340S&store=Main&catId=415&productId=o81103&leafCatId=41508
If that doesn't work or you want to see what other parts are listed for XT600, set up bikes for yourself - Yamaha XT600 1995 and 1994, under both OFFROAD and METRIC bikes. (Their system is weird; I think the JT857 sprockets were listed for XT600 under METRIC but not under OFFROAD.)
Back to top
Hoke
PostPosted: Mon Oct 23, 2006 12:18 pm    Post subject: Reply with quote
Does anyone know what ignitionlock the Baghira have?
I can not read what is printed on mine after someone tried to take my bike.
On top it is printed ZADI (brand) and something like Q933?? I can only for shure read that one 9 is printed.
On the bottom it says ZADI PF385.
If it is Q933 it should be the same äs CCM 404.
The 933 (Aprillia Pegaso)/ KTM LC4 00- looks the same but have no "parkinglight" mode.
Does anyone now what the number is on the top of the lock?
Edit: In the usermanual it stand that it is Zadi Q933
Back to top
Display posts from previous:
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk All times are GMT - 5 Hours
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
