Author |
Message |
andyw
Joined: 14 Mar 2006 Posts: 89 Location: UK South West
Posted: Mon Apr 10, 2006 9:13 am Post subject: Mastiff with a not so mastiff spark! |
Bikes been running right as rain since I bought it a few weeks back. try to start it the other morning, cranks over fine but no sign of it firing up
Put it down to low battery so next day after a night on the Optimate and...........same again!!
Neutral light shows
There's fuel (I can smell it after a few tries at starting)
........but found the spark (new spark plug) looked very weak and yellowish.
Looks like an ignition problem, where do I start?....new ignition coil? - advice appreciated
Andy _________________ 2005 R1200GS - 2002 MZ Mastiff: No more
www.MotorcycleInfo.co.uk |
Back to top |
Posted: Mon Apr 10, 2006 12:30 pm Post subject: |
First off I would try again with hte old spark plug. New ones can be faulty. Other than that, does it have a spark? If so it might be a fuel problem. If not check all the connections for the igniton circuit.
Keith _________________ Ride it like you stole it |
Back to top |
cat
Joined: 30 Nov 2005 Posts: 398 Location: South Africa
Posted: Tue Apr 11, 2006 1:56 am Post subject: |
maybe the battery's died - although it's unlikely. check the connections at the ignition components. one by one, make sure they're tight and make sure they're clean. go through them one by one, clean with contact cleaner. if they look maybe a bit corroded, clean them with fine waterpaper.
and put the old spark plug back, like Keith says.
then report back. don't go buying new coils or anything just yet. |
Back to top |
andyw
Posted: Tue Apr 11, 2006 5:15 am Post subject: |
Thanks guys, the new sparkplug was fine for two weeks so don't think that's it, have replaced that with another new one anyway.
There is a spark but it looks really weak and it's yellowish rather than blue.
Fuel seems ok, crank the engine over a number of times and you get the smell of fuel. I've also pulled the fuel line and petrol flows.
Check all ignition connections - good tip, thanks. _________________ 2005 R1200GS - 2002 MZ Mastiff: No more
Back to top |
