MZ Riders
Carb cleaning / check-over
Author Message
andyw
PostPosted: Mon Apr 17, 2006 12:34 pm    Post subject: Carb cleaning / check-over Reply with quote
Workning my way through the possibe causes of my 2002 Mastiff being a non starter now and need a little help on the carb front Very Happy
Checked the basics, float bowl reasonable clean/free from debris, floats appear airtight, rubber diaphragm 'thingy' Embarassed appears free of holes/cracks (how can you be sure there's no pinholess?), nothing obvious loose/fallen off.
So, what's the recommended jet settings and which one is which? Embarassed
Where should I apply compressed air to ensure clear fuel-ways/jets?
What's the procedure to check/set the float height?
Anything else?
Thanks again!
http://www.suzukisv1000.com/images/mz/Carb001.jpg
http://www.suzukisv1000.com/images/mz/Carb002.jpg
http://www.suzukisv1000.com/images/mz/Carb003.jpg
http://www.suzukisv1000.com/images/mz/Carb005.jpg
http://www.suzukisv1000.com/images/mz/Carb006.jpg
http://www.suzukisv1000.com/images/mz/Carb007.jpg
http://www.suzukisv1000.com/images/mz/Carb008.jpg
http://www.suzukisv1000.com/images/mz/Carb009.jpg
??....images not appearing??
_________________
2005 R1200GS - 2002 MZ Mastiff: No more Sad
www.MotorcycleInfo.co.uk
Back to top
View user's profile Send private message Visit poster's website
Fil
PostPosted: Mon Apr 17, 2006 4:07 pm    Post subject: Reply with quote
I had to strip and rebuild my carbs after they got gummed up from the bike being stored for a couple of years.
I basically striped out the jets and cleaned them, and made sure the float bowl and valve were all clean.
I then set the pilot jet/ air jet (whatever you prefer to call it) at 2.5 turns out as per the handbook, but some people say they will run upto 5.5 turns out.
Try this procedure to check the fuel level in the float bowl:
Replace float bowl drain pipe with a clear plastic tube of the same diameter (so you can see the fuel in the pipe).
Bend the clear tube up past the left side of the carbs, and zip-tie it up so that the top of the tube is well above the top of the carbs (making sure there are no kinks in the pipe).
Open the drain screw in the bottom of the float bowl, and the fuel should find a level in the clear plastic tube (make sure the bike is level too - not on the sidestand!).
The level you see in the clear tube should correspond to the fuel level in the float bowl. You can mark the level on the side of the float bowl and make any adjustments to suit.
Hope that helps!
Also, try a search on 'carbs' as I made a couple of posts relating to my carb problems a few months back - I think there were some set up tips that some of the guys gave me.
Back to top
andyw
PostPosted: Tue Apr 18, 2006 7:27 am    Post subject: Reply with quote
Appreciated Fil, really helpful Very Happy
Anyone else, more tips advice?
_________________
Back to top
andyw
PostPosted: Tue Apr 18, 2006 8:50 am    Post subject: Reply with quote
Was going to foillow your tip for checking fuel level in the float bowl Fil but came across a slight snag! Previous owner was obviously ham fisted - drain screw head rounded right off, I still can't beleive I managed to get the SOB out.............
BSA Regal to the rescue.......they actually carry these in stock! Wink
 Description:
 Filesize:  24.68 KB
 Viewed:  1196 Time(s)
_________________
Back to top
cat
PostPosted: Fri Apr 21, 2006 3:06 am    Post subject: Reply with quote
Shocked ohhhh my...WORD!!! Shocked I did that Wednesday night. (I had a bad night.) The frikking thing's made of lead! oh, you're lucky - mine's still in. Shocked
I tried different screwdriver bits but nothing seemed to fit properly. I think it was a bit graunched already from when I was replacing the float bowl screws, a while ago ...I must have tried it and found that it was graunching and left it.
So then I tried screw extractors. The little one was biting but then I made the mistake of trying to straighten it, align it, and it stopped biting. So I tried the next bigger one and it quickly just ...f**** up the screw more.
I was thinking I'll have to sharpen a small screwdriver and try to bash /chisel a slot in it. It's not easy to tap it out because it's down a hole, you can't get the screwdriver at the right angle.
I should have put Q10 on it so by tonight it would - maybe - help.
Why do they make carb screws out of lead - or whatever it bloody is! Exclamation Evil or Very Mad zinc or something.
hey, it looks like an air screw! What's it actually for? I was going to try to replace it with an Allen.
Oh well, maybe I'll getting hold of BSA Regal - if I can't replace it with an Allen. I want some sprocket lock washers and exhaust gaskets, and - another stupid thing - or stupid me - if you tighten the rear brake cable guide P-clips a bit too much ... they're screwed into brass "washer/nut thingies" that are held in the hole in the swingarm by the rubber grommet ... I ended up with the grommet inside the swingarm. I Crying or Very sad was looking at what mx bike ones I could use instead.
Back to top
View user's profile Send private message Send e-mail
cat
PostPosted: Fri Apr 21, 2006 3:22 am    Post subject: Re: Carb cleaning / check-over Reply with quote
The images... you click the [Img] button in the editor, paste the URL, then click the button again (which has changed to [Img*]) ... or else just type it [img]the_URL_in_here[/img]
Get a magnifier. From Kennedy. They're cheap, they do the job. Plastic. I just got one with some other Kennedy stuff. x4 magnification. It cost about..less than a pound.
Back to top
cat
PostPosted: Fri Apr 21, 2006 4:48 am    Post subject: Reply with quote
Andy, maybe you can sort this out for me. I'm trying to organise main jet drill sizes and so on - and if I'm going to order a float bowl drain screw, I want to get main jets at the same time.)
I've just found that 2 of the MZ Teikei diagrams I've got show different main jet arrangements - the secondary carb. One is the same as the Yamaha XT - it has what looks pretty much like a normal main jet but apparently held in by [#29 in the diagram - BOLT, HOLDING]. The other has what you could call a 'nipple' and seems to scew in itself without the 'BOLT, HOLDING'. I think that's probably the one we've got and the other diagram is the one is the XT one (a few slight differences) ....?
Back to top
cat
PostPosted: Fri Apr 21, 2006 5:03 am    Post subject: Reply with quote
Check the pictures...
 Description:
 Filesize:  44.97 KB
 Viewed:  1166 Time(s)
 Description:
 Filesize:  14.59 KB
Back to top
andyw
PostPosted: Sat Apr 22, 2006 12:16 pm    Post subject: Reply with quote
Cat....I have an XTZ660 ('91) manual and my carb setup is as shown in that (diagram attached) - apparently a Teiki Y26PV although apart from a 'TK' marking and 'Made in Japan' there are no identifiers on the carbs that I could see.
 Description:
 Filesize:  153.02 KB
 Viewed:  1153 Time(s)
_________________
Back to top
cat
PostPosted: Sat Apr 22, 2006 5:03 pm    Post subject: Reply with quote
Thanks. Exclamation That looks like a 3rd different configuration of secondary main jet, and they're all the Y26PV - although I think there is some other number involved along with that - I saw it somewhere. I wonder if that's the same main jet as the Baghira.
Back to top
andyw
PostPosted: Sun Apr 23, 2006 12:19 pm    Post subject: Reply with quote
Interesting, I wonder what 'variants' are in use on the MZ's?
Maybe bikes of differing age use different cab setups?
And Fil's idea on checking float bowl fuel level in action............
 Description:
 Filesize:  86.59 KB
 Viewed:  1140 Time(s)
 Description:
 Filesize:  97.6 KB
_________________
Back to top
Display posts from previous:
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
