MZ Riders
Wheels
Author Message
friendfire
PostPosted: Sat Apr 22, 2006 11:20 am    Post subject: Wheels Reply with quote
Right got the wheels off and almost ready to get them shot blasted and powder coated, however how do you get the bearings out from the centre, removed dust caps and no idea how to remove the rest?
See image in case i have not explained very well Embarassed
[/img]
 Description:
 Filesize:  57.79 KB
 Viewed:  1270 Time(s)
 Description:
 Filesize:  54.81 KB
_________________
http://www.projectmz.co.uk
Back to top
View user's profile Send private message Visit poster's website
friendfire
PostPosted: Sat Apr 22, 2006 11:22 am    Post subject: Reply with quote
Actually the dust caps came off the Swingarm, this will also be sprayed and I have the same problem with removing the bearings.
Cheers All
Mick
_________________
Back to top
PostPosted: Sun Apr 23, 2006 2:24 am    Post subject: Reply with quote
I usually use a bearing puller that utilzes a slid hammer to remove wheel bearings. They can normally be removed using a drift. Removing bearings usually damages them, so plan on buying new bearings when you refit the parts.
_________________
Back to top
Fil
PostPosted: Sun Apr 23, 2006 2:25 am    Post subject: Reply with quote
I usually find a socket (on an extension bar) that will just fit through the hole in the centre of the bearing, and use this to work round the bearing on the opposite side. If you slightly angle the socket/ extension bar, the edge of the socket will just sit on the edge of the inner race of the bearing. You can then give it a clout with a hammer (recommend a soft faced hammer). You can then reposition the socket a little further round the bearing and repeat the process until it falls out. I usually work round the bearing by starting at 12 o'clock, then 6, then 3 then 9. Hope that makes sense!
Also, you will probably find that there is a spacer in the hub between the bearings. This will push over to the side just enough to allow you to get to the inner race of the opposite bearing.
Just don't be tempted to re-use the old bearings, as knocking them out by the inner race will knacker them!
Back to top
friendfire
PostPosted: Sun Apr 23, 2006 2:53 am    Post subject: Reply with quote
Cheers guys will give it a go.
MIck
_________________
Back to top
Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
PostPosted: Sun Apr 23, 2006 9:40 am    Post subject: doing this Reply with quote
you are not alone
i am doing this to my rt125 at 12500 miles
changed tires thursday and the sound of dry bearings while on the wheel
balance sent me to the bearing shop in a hurry
on friday
the bearings had seals on both sides so a repack while in the wheel
is not possible....because no grease would get into bearing
_________________
Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
thanhnguyen52
PostPosted: Sun Apr 23, 2006 6:38 pm    Post subject: pack the bearing Reply with quote
hi Dave,try my way:leave the bearing(s) in the hub(rim or wheel),use a picker or small flat screw driver pry to remove the plastic cover(be gentle)then put thick bearing grease all over the balls of the bearing,just enough not too much,then put the cover back...might last,like new.hope this help.
Back to top
thanhnguyen52
PostPosted: Sun Apr 23, 2006 6:39 pm    Post subject: pack the bearing Reply with quote
n/a
Back to top
jimc
PostPosted: Mon Apr 24, 2006 6:45 am    Post subject: Reply with quote
Some heat in the hub will make bearing removal easier too.
Don't get too carried away, an electric heat gun or careful use of a propane
torch should do the trick.
_________________
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
Back to top
friendfire
PostPosted: Mon Apr 24, 2006 6:56 am    Post subject: Reply with quote
Thanks All, some good advice there. Was planning on replacing them anyhow to be honest.
Cheers
Mick
_________________
Back to top
dmon722000
PostPosted: Sat Apr 29, 2006 8:38 am    Post subject: Reply with quote
"F" those bearings! The rear bearings aside from being very common and cheap are also notorious for rusting due to the weak water sealing ability of the dust seal. So bang those bearings out using a drift and remember to walk them out using the 12, 6, 3, 9 o'clock "walk out" method of removal. Go to your locak bearing shop and bring your old ones with you and you can get some great quality stuff, thet are a real common bearing too.
Back to top
Display posts from previous:
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
