MZ Riders
Bike stands
Author Message
friendfire
PostPosted: Mon Apr 24, 2006 7:35 am    Post subject: Bike stands Reply with quote
Bit of a stupid question, but i am looking for a stand for the sport so i can drop both wheels and forks, and have it at a reasonanble height to work on.
Seen some stands, but they seem to rely on the fact that the bikes have a frame low down and the lift supports the fram area, anyone got any suggestions? hope that makes sense?
Cheers
Mick
_________________
http://www.projectmz.co.uk
Back to top
View user's profile Send private message Visit poster's website
dgunther
PostPosted: Mon Apr 24, 2006 5:10 pm    Post subject: Re: Bike stands Reply with quote
Cheers
Mick
Since the frame goes beneath the engine, a motorcycle/ATV jack is a good option. They lift the bike by the frame rails, so you can drop the forks, wheels, even the swingarm if you need to. Most will give you about 12-18" of lift depending on the model. Check Sears or a similar vendor.
If you don't want to use a jack, you may be able to use a stem stand on the front - instead of holding the front by the bottom of the forks, it puts a pin into the steering stem to lift the bike so you can drop the forks.
Back to top
View user's profile Send private message MSN Messenger
Sourcer
PostPosted: Wed May 03, 2006 5:34 pm    Post subject: Reply with quote
Just a question about the stand. Is there a main stand on the Baghira Black Panther?
Back to top
street_moto
PostPosted: Thu May 04, 2006 3:32 am    Post subject: Reply with quote
No main stand on the Black Panther, but I bought this stand off Ebay, £79 delivered, lifts to a decent height, both wheels off ground and you can manouvre the bike once lifted because it has wheels. It's steady enough to work on, but any tight nuts are loosened off before lifting, hope this helps. Wink
 Description:
 Filesize:  125.95 KB
 Viewed:  820 Time(s)
Back to top
Location: Parkersburg, West Virginia usa .You know the PARTS have been SHIPPED when the MAIL MAN knocks
PostPosted: Thu May 04, 2006 9:59 am    Post subject: same Reply with quote
i have a stand that looks the same in black and it works fine
but had to make a wood frame to fit it to bottom of both the
rt125 and saxon tour as they are not stable if just lifted with it
with out an adaptor Very Happy
_________________
Dave 2002 MZ RT125+95 Saxon Tour in WV USA "I like the road less traveled if it's PAVED!."
www.qrz.com/wd8cyv
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
cat
PostPosted: Thu May 04, 2006 10:20 am    Post subject: Reply with quote
street_moto wrote:
It's steady enough to work on, but any tight nuts are loosened off before lifting, ...
I saw one a couple days ago that had a J-hook system that fastened the footpegs to the stand. I can't remember what it was but I'll find it and put pictures. I thought that it would be easy to weld brackets to a stand like yours and get J-hooks.
Get 2 J-hooks, hook them through the footpegs, and mark the side edges of the top of the stand where the brackets should be welded on, cut 2 pieces of flat steel about 20mm wide and long enough so they extend out under the J-hooks and mark them where the holes for the J-hooks should be drilled.
Back to top
cat
PostPosted: Thu May 04, 2006 10:35 am    Post subject: Reply with quote
You can't see it properly here, but you get the idea. ...I think my description is better. I couldn't have seen it, I must have imagined it.
They use some sort of loops on the stand instead of tabs.
http://bikestandlift.com
Expensive, and never mind the J-hooks, the whole thing would fall over. But the J-hooks are a good idea anyway, for other stands.
Back to top
Sourcer
PostPosted: Thu May 04, 2006 12:21 pm    Post subject: Reply with quote
Okey, thanks for the info.
Back to top
Display posts from previous:
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
