MZ Riders
Cylinder head knackered.............
Goto page 1, 2  Next
Author Message
andyw
PostPosted: Tue May 09, 2006 3:55 pm    Post subject: Cylinder head knackered............. Reply with quote
Will I ever get this bike back on the road!!! Shocked
Latest discovery is that some ham fisted tiny brained t**t has at some time broken one of the exhaust studs from the head Sad (god knows how??!!). Then to make matters worse the culprit has drilled out the head and 'glued' a bolt in place.....surprise surprise, this bodge has failed.
I'm not sure the head is repairable, not only has a larger than necessary hole been drilled but on dremelling out the remains of the 'glue' I find that a waterway has been perforated Evil or Very Mad
I'm making enquiries about repairing but seems a good idea to look for a replacement head as well!
...............(it's a good job the guy I bought the bike from is not local!!! Evil or Very Mad )
........if anyone can point me in the right direction to find a replacement head I'll be very grateful Very Happy
_________________
2005 R1200GS - 2002 MZ Mastiff: No more Sad
www.MotorcycleInfo.co.uk
Back to top
View user's profile Send private message Visit poster's website
Sourcer
PostPosted: Tue May 09, 2006 5:41 pm    Post subject: Reply with quote
Is this what you need?
http://cgi.ebay.co.uk/SZR-660-XT-660-CLYINDER-HEAD-AND-CAM-YAMAHA_W0QQitemZ8064198944QQcategoryZ10490QQrdZ1QQcmdZViewItem
Back to top
PostPosted: Tue May 09, 2006 5:48 pm    Post subject: Reply with quote
Dont have a spare myself, but Steve who lives in Suffolk may have one. Or you could try to get one for a 660 Raptor as I believe they fit, no problem.
_________________
Back to top
whysub01
PostPosted: Wed May 10, 2006 12:46 am    Post subject: Reply with quote
I'll have a word with my mate Steve (see above) who builds race engines-he may have a spare he can sell.
Will check back later with result.
_________________
Back to top
View user's profile Send private message Send e-mail
whysub01
_________________
Back to top
andyw
PostPosted: Wed May 10, 2006 4:32 am    Post subject: Reply with quote
Yes and no............right parts but I want A1 condition i.e. bolt on and go Very Happy ......thanks anyway, don't know why but although I've tried eBay didn't see that one Confused
Thanks .....fingers crossed
_________________
Back to top
whysub01
PostPosted: Wed May 10, 2006 9:47 am    Post subject: Reply with quote
Andy-PM Sent
_________________
Back to top
cat
PostPosted: Thu May 11, 2006 1:36 pm    Post subject: Reply with quote
It can be fixed, but you need an expert welder and fabricator. If you were here, you could get it done. If you can see the water passage hole, the perforation, then it could almost certainly be fixed.
Back to top
andyw
PostPosted: Fri May 12, 2006 3:38 am    Post subject: Reply with quote
I'm waiting for a second-hand head to arrive (Many thanks to whysub01 for the lead Very Happy ) but I've also got contact info for an 'expert' in aluminium welding.
I prefer to run an undamaged/repaired head so will use that when it arrives and hopefully recoup some of the costs by having the original head repaired and eBaying it.
Thanks again to everyone for the help and advice........
.......anyone got recommendations/advice for cleaning the top of the piston (removing carbon deposits) and or tips for things to watch out for on engine top end reassembly?
_________________
Back to top
cat
PostPosted: Fri May 12, 2006 4:15 am    Post subject: Reply with quote
Don't scratch it, or carbon builds up on the scratches immediately. The scraper things are metal, but as long as the scratches are superficial, you can polish them off with fine waterpaper.
If you find some..substance, or solvent, please let us know. Maybe brake cleaner ...isn't it caustic soda?
Back to top
andyw
PostPosted: Fri May 12, 2006 4:38 pm    Post subject: Reply with quote
Spent ages trawling the net but not come up with a solvent/cleaning agent for removing carbon deposits - obviously needs to be something that will not react with aluminium in any way.
Tips I've found so far:
Scraper - use a soft grade aluminium or even wooden wedge shaped scraper.
If cleaning the piston in situ (i.e. barrel not removed), tape round the edges of the piston to be absolutely sure no carbon/coke other debris can fall in to the ringland
Take great care not to mark the piston - also, DON'T polish the cleaned pistion
_________________
Back to top
PostPosted: Fri May 12, 2006 5:13 pm    Post subject: Reply with quote
I have used a chemical for helping to remove compond type head gaskets which loosens carbon deposits. Its not to safe and must be used in a well ventilated area. Its called MEK (shortened name - Methel ethel ketone or something like it). It used to be used in the UK printing trade, but I dont think they use it anymore.
_________________
Back to top
andyw
PostPosted: Sun May 14, 2006 5:16 am    Post subject: Reply with quote
IT RUNS!
..........new top end sounds quiet and smooth. So far all I've done is run it up to temp in the garage and leave it running for a few minutes more - so far so good. Will let it cool and then do the same before going for a gentle run Very Happy
Cleaning combustion chamber, valves and piston crown - did use some carb cleaner but not sure it made much difference. The job was pretty easy with a bit of care using:
# An aluminium scraper (just a piece of aluminium sheet cut to 20mm wide, bend a bit of a curve at one end and then chamfer both ends to make a sharpish scraping edge)
# A small brass (NOT steel!!) wire brush
# A thin piece of plastic as a second scraper
CARE - if cleaning the piston crown in situ (i.e. barrel still on engine) mask up the edge of the piston and barrel to make sure no debris enters the waterways or ringland.
Also took the time to grind the valves/valve seats in and put new valve stem oil seals on.
 Description:
 Filesize:  137.69 KB
 Viewed:  1171 Time(s)
_________________
Back to top
whysub01
PostPosted: Sun May 14, 2006 8:34 am    Post subject: Reply with quote
Did you get the head from Steve? Whatever, very glad you have it running now.
He did a motor for me whicjh is still sitting on the garage floor, and I have no time to swap them over.
Looking for a mechanic, preferably with knowledge of the Sport model or even the 660 motor to do the swap for me (nice bit of cash work) but can find anyone to do it? Can I buggery!
_________________
Back to top
andyw
PostPosted: Sun May 14, 2006 8:40 am    Post subject: Reply with quote
Quote:
I'm waiting for a second-hand head to arrive (Many thanks to whysub01 for the lead ) but I've....................
Laughing
Yes indeed, many thanks for your help. What work has Steve done on the new motor you have? (....if you can't find anyone to fit it for you I'll take it off your hands Razz )
_________________
Back to top
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
