MZ Riders
Interchangeable parts - a list
Goto page 1, 2  Next
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk
Author Message
F0ul_Oli
PostPosted: Fri Mar 18, 2005 7:13 am    Post subject: Interchangeable parts - a list Reply with quote
I was thinking how nice it would be to have a list of stuff, designed for other bikes, that fit the MZ range ( In interested in the Baghira, but lets make the list for everyone)
So far, I know the engine is a Yamaha 660cc and all the normal service parts fit.
The front disc is a Yamaha R1/6 model -99 - are the calipers also from this bike?
The front mudguard is a KTM model, but I don't know which bike!
The Rear brake Cylinder is also a KTM but which model?
What about the clocks? Did someone say they were from a Husky?
It seems to me the only bit which you can only get from MZ is the frame!
If we all put down our words of wisdom, we could edit the whole thread at the end and create a document for easy reading - what do you think?
_________________
Back to top
View user's profile Send private message
PostPosted: Fri Mar 18, 2005 10:42 am    Post subject: Reply with quote
The later style (not the square ones or the round ones) are the same as a Huskvarna (spelling not quite right but you get the meaning) SM and the husky tacho can be made to fit as well (electronic).
The front brake caliper is NOT the same as a Yamaha R6. The Yamaha unit is a four pot calpier, the MZ a 2 pot sliding caliper.
The KTM front mudgaurd like many others will fit (I have a Suzuki RM, UFO pattern one fitted to my Baghira)
Brilliant idea about this documant as well.
Dougal
_________________
Back to top
F0ul_Oli
PostPosted: Fri Apr 22, 2005 5:19 am    Post subject: Reply with quote
Just added some bits about the brake pads here.
Engine -
Service parts are the same as Yamaha XTZ 660
Oli Filter - Yamaha part # 4X7-13440-90
radiator guards for a KTM LC4 640 fit the Baghira perfectly
Electrics -
Tacho - The later style (not the square ones or the round ones) are the same as a Huskvarna SM and the husky tacho can be made to fit as well (electronic).
The CDI units from the following will fit.
Yamaha SZR660
Yamaha XTZ660
Any MZ 660
yamaha TDM 850 3VD item, not for the 4TX series. - The rev limiter is set at 8400rpm, ignition some degrees earlier (38° to 42°.
Battery off an XT600 will fit.
replace the original headlight bulb with a piaa super plasma bulb
Exhaust -
You can use a connector pipe from any 660 based bike, the back box needs to fit the end of this connector pipe ( my back box was once on a Fireblade! - this is because my connector pipe will accept any end can with a 50mm inlet - standard size for the Ducati 749 underseat pipes!
Brakes -
The Aprillia Pegasso uses the same FRONT pads as the Baghira and the same REAR pads as does the Yamaha TDR 125
Plastics -
The headlamp is a stock KTM fittment
The front mud guard is a pattern part, as is the rear number plate holder
Larger Fuel Tank -
None available but a KTM model can be modified, but the seat also needs replacing.
Wheels -
Rear Yamaha 41 tooth sprocket JTR857-41
_________________
Back to top
bikerbabe
PostPosted: Fri Apr 29, 2005 1:43 pm    Post subject: Reply with quote
Brill idea peeps Laughing If I find any interchangeable parts I'll post 'em here.
_________________
Can't think of one.
Back to top
gedge
PostPosted: Sat May 07, 2005 5:09 am    Post subject: Reply with quote
The standard baggy headlamp is also a KTM item.
radiator guards ( if you want them )are off a KTM LC4 and so the rads are also from the same model..
_________________
Back to top
tuny
PostPosted: Wed Apr 12, 2006 1:37 pm    Post subject: Reply with quote
the wheels from the mastiff, where do they come from? not the spocket one"s, i mean the aloy wheels.?
Back to top
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Wed Apr 12, 2006 1:57 pm    Post subject: Reply with quote
The standard Baggi headlight unit is also the same as those fitted to Huskvarnas and Husabergs amongst others
The rear shock protector/mudflap is the same as a KTM 640.
Front and rear sprockets are teh same as teh Yamaha XTZ660.
Alloy wheels are a MZ item. They require a different sized spindle for each wheel though. They are very similar to CCM R30 wheels as well.
Wheel hubs are modified Yamaha units (different bearing sizes)
All engine componants are teh same as Yamaha XTZ/SZR 660.
As are starter motor and carbs.
_________________
Back to top
tuny
PostPosted: Mon May 22, 2006 1:24 pm    Post subject: Reply with quote
are all cluchtes of baggi, mastiff and scorpions the same? so can i order a cluch of a scorpion to fit my mastiff?
Back to top
PostPosted: Mon May 22, 2006 2:20 pm    Post subject: Reply with quote
All 660 enigines from the MZ 660 and Yamaha XTZ and SZR 660 are the same.
_________________
Back to top
tuny
PostPosted: Mon May 22, 2006 11:28 pm    Post subject: Reply with quote
i know this is not right, becaus the szr hase a different gearbox it's 1e is much longer then the baggi's 1e. but maybe the cluch is the same, i'l try it. why do they ask the date of make from a scorpion fore the cluch on ebay???? (is there a diference?)
Back to top
PostPosted: Tue May 23, 2006 2:38 pm    Post subject: Reply with quote
Just looked up the reference number for friction plates and springs for the SRZ660 and the XTZ660. Same part number. Interestingly the new XT660X and R have the same friction plates as well.
_________________
Back to top
TrashBagh
PostPosted: Thu May 25, 2006 12:51 pm    Post subject: Seat Bolts!! Reply with quote
Hey people I've got an 03 Bagh which is missing two out of the three seat hold-down bolts... anybody have any leads as to where I can locate replacements?
Back to top
RiverDrive
PostPosted: Thu May 25, 2006 3:04 pm    Post subject: Reply with quote
http://www.boltdepot.com/
_________________
01 Sport Cup
"Quality is the parent, the source of all subjects and objects." - Robert Pirsig
Back to top
View user's profile Send private message Send e-mail Visit poster's website
cat
PostPosted: Fri May 26, 2006 3:26 am    Post subject: Reply with quote
Can you give me the part number for the list? What about the springs?
Back to top
PostPosted: Fri May 26, 2006 12:00 pm    Post subject: Reply with quote
The catalogue I have is from M & P motorcycle accessories in the UK. See
www.mandp.com
The part number thay give is 508 563 (£46.50)for the friction plates and 508 694 for the springs (£7.50). Prices plus P&P. No makers name is included in teh catalogue.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk All times are GMT - 5 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
