Author |
Message |
CM
Posted: Fri May 26, 2006 1:19 pm Post subject: |
Oh Fu** with p ... not b ouuu what a shame....
If you understand me it´s okay
The whole disk is from Braking.
...if you look on your front wheel (where the brake is), you see a little spacer. That one must be about 2 or 3mm longer than the original. I think it must be 2,8mm longer but I post the exact size and some better pics of the brake tomorrow, if you want.
_________________ MZ Baghira 660 Black Panther
Mikuni TM34B65 carb, GPR Exhaust, Tuning Manifolds, Magura SX Handlebar, Braking 320mm Wave Disk, Brembo P4 4caliper, 5/8 Pump |
Back to top |
cat
Joined: 30 Nov 2005 Posts: 398 Location: South Africa
Posted: Fri May 26, 2006 1:45 pm Post subject: |
You don't have to measure the spacer but more photos always good. Those Braking sizes/mm are good, I know what to do. I must just burn a cd to backup all these things I saved.
Thanks!
Now you need to update your signature line, with Braking disc, etc.
Back to top |
CM
Posted: Fri May 26, 2006 1:59 pm Post subject: |
You´re right.....and now, it´s done
Okay, tomorrow I make some new pics
The brake is really awesome. You can´t compare it with the original one....it´s a different dimension of braking
Quote: | I purchased my Mastiff in Cuxhaven from a Bike shop, they had a black Baghira when I was there, and now they don't. Maybe you purchased the Baghira from the same bike shop on the Cuxhavener Str. 288. |
really? ....Str.288....I don´t know a street which is called like that.... We have no MZ Dealer in Cuxhaven, only in Oederquart, Hamburg and in Bremen.
Back to top |
cat
Posted: Fri May 26, 2006 2:33 pm Post subject: |
CM wrote: |
really? ....Str.288....I don´t know a street which is called like that.... We have no MZ Dealer in Cuxhaven, only in Oederquart, Hamburg and in Bremen. |
I found it on multimap.com -- in the north, near the sea.
Back to top |
Sourcer
Joined: 01 May 2006 Posts: 39 Location: Stockholm, Sweden
Posted: Fri May 26, 2006 2:50 pm Post subject: |
CM wrote: | really? ....Str.288....I don´t know a street which is called like that.... We have no MZ Dealer in Cuxhaven, only in Oederquart, Hamburg and in Bremen. |
This bike shop is not a MZ dealer, but they sell good used bikes.
Here is their homepage.
http://www.johns-und-maackens.de
Back to top |
CM
Posted: Fri May 26, 2006 3:11 pm Post subject: |
ahhh, it´s the Cuxhavener Straße.... but it´s in Hamburg
If you look on a map, look at Hamburg an then look at the coast to the left. Then you see Stade and after that Cuxhaven
Back to top |
Sourcer
Back to top |
CM
Posted: Fri May 26, 2006 3:42 pm Post subject: |
Jep, the Cuxhaven up to the left.....even where I live is nearly on the map
Ahhh, you mean the B73.....
Oh, I see you´re coming from Sweden.....if you have time, a lot of time drive to the Baghira Forum meeting at the 30.6. till 2.7.06 in Gräfenroda I´ll be there
Back to top |
Posted: Fri May 26, 2006 4:41 pm Post subject: |
cat wrote: | and the english speak nothing else. |
Not true cat, sometimes we speak giberish and drunkanise as well Looking forward to my trip to the Netherlands next Thursday
Back to top |
CM
Posted: Sat May 27, 2006 8:41 am Post subject: |
Here the pics.
Here you can see that the outer ring is not "in the middle".
This spacer must be a little bit longer...then I´m ready for TÜV
Back to top |
Posted: Sat May 27, 2006 10:21 am Post subject: |
So from what I can make out, the disc is of sett, unlike the standard disc which is flat. This then gives more clearance for the calpier. Looked at teh fron end on a Yamaha XT660X supermoto. They have an off set 320mm disc as standard. I reall have to try and borrow one to see what swaps over
Back to top |
CM
Posted: Sat May 27, 2006 2:24 pm Post subject: |
If not, make a spacer
A spacer with 5mm offset is in my garage because I hadn´t known that the Braking disk has it as standart...
On the package stands XT 600X....
Back to top |
whysub01
Posted: Sat May 27, 2006 2:56 pm Post subject: |
keithcross wrote: | I have been looking at fitting a 4 pot caliper to my bike for some time now, but cant find one to clear the wheel spokes yet. Anyone here done this mod? I have noticed the disc could be spaced out maybe 5mm, maybe this is what others have done.
Any ideas welcome.
Keith |
keith
i have a 4 pot Nissan caliper from a VFR, and a bracket to enable it to swap fror the original.
When i can find a couple of days and we can arrange to do the Sport engine swap, I'll bring it along for you to check out. MZPog fron Visordown had it on his Mastiff-and could out brake me all the time by metres!
_________________ Becoming A Track Day Addict. Baggi Well On The Way To Completion. Well, One DAy Closer................ |
Back to top |
Posted: Sat May 27, 2006 4:44 pm Post subject: |
I look forward to seeing this modification Might have to do this mod myself one day.
Back to top |
Sourcer
Posted: Sat May 27, 2006 10:02 pm Post subject: |
CM wrote: | Oh, I see you´re coming from Sweden.....if you have time, a lot of time drive to the Baghira Forum meeting at the 30.6. till 2.7.06 in Gräfenroda I´ll be there |
I have plenty of time, and with a bunch of feather pillows under my ass, driving 1337 km to Gräfenroda will be a pleasure.
Back to top |
