Author |
Message |
-8-
Joined: 16 Jun 2004 Posts: 60 Location: Atlantic City,NJ
Posted: Wed Jun 16, 2004 7:36 pm Post subject: Baghira carb problem... |
After a mad blast riding home yesterday I noticed a strong fuel smell after I parked the beast in the shed. This morning the smell was still strong but I backed it out and tried to start it up. No go...just fuel spilling out the overflow tube from the carbs. I turned the fuel valve off and let it sit. Two people I asked said it's probably stuck floats. Can anyone suggest a remedy?
Description: |
Nelson-Rigg saddle bags & tail bag. Works nice, lots o room PLUS softens the high-side landings real well! |
Filesize: |
264.02 KB |
Viewed: |
4528 Time(s) |
Back to top |
RichBeBe
Joined: 09 May 2004 Posts: 74 Location: New York City
Posted: Wed Jun 16, 2004 8:19 pm Post subject: |
It is one of a few things:
Stuck Float
Bad float (that no longer floats)
A tear in the rubber of the needle valve
Something wrong with the needle valve seat
A piece of debris stuck in the valve holding it open
I would be willing to bet it is a stuck float though
Take the back end of a screwdriver (plastic end) and wack the float bowl a few times and turn the fuel back on. See if that stops it, if not you need to open the bowl up.
Thats my two cents for whatever it's worth
Back to top |
125SMash Moderator
Posted: Wed Jun 16, 2004 8:32 pm Post subject: |
hey, what brand/model handguards are those?
_________________ 2002 MZ 125SM |
Back to top |
-8-
Posted: Wed Jun 16, 2004 9:26 pm Post subject: |
I did whack the float bowl (right hand side carb) with exactly that! Turned the fuel on but still didn't start... no fuel spilling out the hose now though. I am going to let it sit overnight and try again tomarrow. Any chance of fouling the plug if it doesn't start right off?
btw: Acerbis hand guards, scuffed up good with a Scotchbrite pad. Only now my mirrors vibrate at 55mph+ whereas they were clear before. I think the additional brace points on the bars exagerates in the mirrors. Hey...how do you like the 125SM? I think I may get 1 for my wife.
Back to top |
125SMash Moderator
Posted: Wed Jun 16, 2004 9:57 pm Post subject: |
its my first own bike so my opinon maybe skewed.
i love it, its gorgeous sounds great and it doesnt kill me with insurance premiums.
only complaint is skant dealer presence on the island, odometer is in kilometers and lots of shifting in city riding.
id recommend it if mz wasnt coming out with a 250 'soon'.
kinda alsmot wish i waited..
naaaaah
Back to top |
cat-tard
Posted: Wed Jun 16, 2004 10:09 pm Post subject: |
One other thing to check for is fuel in the oil... sometimes, the float-bowl will overflow and run down the intake-port to collect on top of the piston... once there, it seeps past the rings and winds up in the crankcase. ...this is very bad for all the parts that depend on the oil for lubrication, and if there's any doubt (unexplained increase in oil-level or odor of fuel from sump) then it's worth the trouble to just go ahead and change the oil NOW before you put any miles on contaminated oil (and potentially create more problems).
Back to top |
phlat65 Moderator
Posted: Wed Jun 16, 2004 11:20 pm Post subject: |
what she said!! also, hold it wide open and crank it to help clear the excess fuel, with no choke.
_________________ 2001 MZ Black Panther
Old Hondas- TT500 Ascott, 305 Dream Touring |
Back to top |
Brian
Joined: 19 Nov 2003 Posts: 252 Location: Seattle, Washington
Posted: Thu Jun 17, 2004 2:29 am Post subject: |
( wrote: | I did whack the float bowl (right hand side carb) with exactly that! Turned the fuel on but still didn't start... no fuel spilling out the hose now though. I am going to let it sit overnight and try again tomarrow. Any chance of fouling the plug if it doesn't start right off?
btw: Acerbis hand guards, scuffed up good with a Scotchbrite pad. Only now my mirrors vibrate at 55mph+ whereas they were clear before. I think the additional brace points on the bars exagerates in the mirrors. Hey...how do you like the 125SM? I think I may get 1 for my wife. |
scotchbrite....... great idea..... buggers up the finish though... right ???
_________________ "Brian" 2003 MZ Baghira |
Back to top |
-8-
Posted: Thu Jun 17, 2004 5:41 am Post subject: |
Fuel in the oil!?!? Cripes I hope not! I will check though. No other indications were present when this started...in fact I swear since I changed the oil last month the damn thing keeps getting faster & smoother. I wish I could find an exploded view of the carbs so I can at least look like I knew what I was doing. Do I need to drop both fuel bowls or can I start with the right side?
'Hold it wide open & crank it'? Doesn't that go against what's stated clearly in the owners manual NOT to do? I was going to crank it with the fuel valve 'off' to clear excess fuel. I guess I need to pull the seat off to make sure I don't ignite the air filter like Roy did. http://members.tripod.com/roy_bertalotto/id25.htm (go to bottom of page)
btw- Scotchbrite was only for the handguards! I was going to paint them flat black but a vigorous 10 minutes with the pad did the trick.
Back to top |
Islander
Joined: 30 May 2004 Posts: 45 Location: Portsmouth, RI, USA
Posted: Thu Jun 17, 2004 9:41 am Post subject: Hand guards |
The handguards, did they bolt up easily. When you ordered them, did you order for MZ or are they universal. I am asking because I have never thought of getting hand guards, but they look good.
_________________ 2004 MZ Baghira Black Panther
2003 Honda VTX 1800 C |
Back to top |
-8-
Back to top |
Brian
Back to top |
Brian
Posted: Thu Jun 17, 2004 3:27 pm Post subject: |
Brian wrote: | the standard heights always get me all fuzzzzy...... nice pict.....
Islander just what eight said on the bars and acerbis stuff.... easy, lining them up is a pain though.... by the way Acerbis makes a universal SM front fender for $ 29.00 although it doesn't protect as well as the stocker but cheaper and better lookin..... Phlat and I put lock hart phillips blinkers on our hand guards... I put higher watt bulbs in and painted them orange, changed the 3 amp fuse to 5 amp fuse and now you can see me a mile away..... |
Back to top |
Brian
Posted: Thu Jun 17, 2004 3:34 pm Post subject: |
I can't delete my mistake/ quote ???? or is my chin strap toooooo tight and cutting off the flow of blood to my peasized brain.... where's a mod when you need one.....
Back to top |
Islander
Posted: Thu Jun 17, 2004 3:39 pm Post subject: Thanks |
Thanks for the information. By the way, ( , that is a bit of false advertising that could get you into some trouble. I am talking about the NOS sticker on the black can. Does make it look useful though.
Back to top |
