MZ Riders
my mz
Goto page 1, 2  Next
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk
Author Message
dbird
PostPosted: Wed Jul 12, 2006 5:12 pm    Post subject: my mz Reply with quote
i love my mz black panther but i think i need to replace the clutch. anyone know where i can take it in sacramento?
 Description:
love it
 Filesize:  265.82 KB
 Viewed:  2678 Time(s)
Back to top
View user's profile Send private message Send e-mail
PostPosted: Wed Jul 12, 2006 5:20 pm    Post subject: Reply with quote
Any Yamaha dealer should be able to do this for you. Plates are the same as an XT600 I think. Search previous posts for information.
Either that or contact a UK Yamaha dealer and ask for XTZ or SRZ 660 plates and get your local dealer to do the job for you.
_________________
Back to top
dbird
PostPosted: Wed Jul 12, 2006 7:01 pm    Post subject: thanks Reply with quote
good idea i called a shop in san fransisco and they quoted me 365 for plates and seals...that sound about right?
Back to top
Drew
PostPosted: Wed Jul 12, 2006 7:40 pm    Post subject: Reply with quote
No help on the clutch, but did you just get the bike? It looks quite clean.
_________________
Relax. You'll live longer.
Back to top
dbird
PostPosted: Wed Jul 12, 2006 7:58 pm    Post subject: Reply with quote
thanks i like it alot and yes i just got it about a month ago its an 03 got it for 4000 Very Happy
Back to top
Scheffi
PostPosted: Thu Jul 13, 2006 10:49 am    Post subject: Reply with quote
You are really sure, that your clutch is faulty. I can't believe it! Probably you have the wrong oil inside... change it.... and use a motorcycle oil. A half-synthetic oil is enough.
_________________
Baghira Enduro, MZ ETZ 250 with sidecar
http://www.sachsen-tourismus.de/
http://www.germany-tourism.de/
Back to top
View user's profile Send private message Visit poster's website
dbird
PostPosted: Thu Jul 13, 2006 2:23 pm    Post subject: Reply with quote
do you mean the wrong clutch fluid or motor oil? i changed both when it started getting difficult to shift into 2nd and 3rd and it worked for a few days but it started again??? thanks for the help.
Back to top
Drew
PostPosted: Thu Jul 13, 2006 3:37 pm    Post subject: Reply with quote
I think what Scheffi is suggesting is if a car oil with friction-inhibitor additives was used, then the clutch would slip due to the additive. Motorcycle oils don't have friction inhibitors added.
I don't own a Baggy myself, so I'm not sure if they use separate oils for clutch and motor.
_________________
Back to top
PostPosted: Thu Jul 13, 2006 11:36 pm    Post subject: Reply with quote
no seperate oil. I can't believe the clutch is bad. I have 15,000 miles on mine, and I abuse the crap out of it. raced it, wheelie all the time, back it in, still works great....
_________________
Back to top
Scheffi
PostPosted: Fri Jul 14, 2006 7:42 am    Post subject: Reply with quote
Exactly! I couldn't find the perfect english words for it!
My clutch works perfectly (since 40 000 km).
_________________
Back to top
jimc
PostPosted: Fri Jul 14, 2006 9:18 am    Post subject: Clutch Reply with quote
The 660 motor runs engine, clutch , and tranny in the same oil.
If you're experiencing difficult shifting, you probably have a cable free play adjustment OR OTHER CLUTCH RELEASE issue. make sure that your handlebar end lever moves a quarter inch or so before the release lever down on the right side of the motor starts to move. Does the bike want to creep with it in gear with the clutch in? A dragging clutch will give you shifting headaches.
As far as oils go, don't use anything marked "EC Energy Conserving" in the round API label on the container. The slippery additives in these are not the best for a wet clutch. It also might be possible that the clutch has been fried and the plates are warped. This will allow it to hook up OK, but it will drag and probably engage unevenly - look for shaking when the clutch is released slowly. A competent mechanic an change the clutch plates in less than one hour, and check for boogered up hub and housing - wear can cause good clutch plates to drag. This can be fixed if it's not too far gone., otherwise you're looking at a bigger job to change the whole enchilada.
What do you mean "clutch fluid"?
Good Luck........
_________________
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
Back to top
dbird
PostPosted: Fri Jul 14, 2006 2:47 pm    Post subject: Reply with quote
new to it and this is my frist street bike so i really appreciate all the info. i used a valvoline motorcycle 10w-40 with superior wet clutch protection. when it was changed the problem went away but now its back what could it be???
Back to top
dbird
PostPosted: Fri Jul 14, 2006 3:51 pm    Post subject: Reply with quote
it doesnt drag its just really hard to shift from 1st to 3rd and back down and yes it does try to pull forward when engaged in 1st.???
Back to top
PostPosted: Fri Jul 14, 2006 5:00 pm    Post subject: Reply with quote
It sounds like adjustment to me and the clutch is dragging. Try to adjust it, or get it adjusted. It is unusual for a dragging clutch to be worn out.
_________________
Back to top
dbird
PostPosted: Fri Jul 14, 2006 5:02 pm    Post subject: Reply with quote
thanks i will try that, hope it works Confused
Back to top
Display posts from previous:
Post new topic   Reply to topic    MZ/MuZ Riders Forum Index :: Mechanic/Tech Talk All times are GMT - 5 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
www.MZRiders.com © lostblur
ezPortal © Smartor
