Author |
Message |
BronxBaghira
Posted: Tue Nov 08, 2005 5:30 pm Post subject: Popin' Baghira |
I have a 2005 Baghira and I put an M4 exhaust on it. It sounds great, the bike starts right up and runs great, but it pops like a bastard on deceleration. I'm thinking its too lean right from the factory. Any ideas? |
Back to top |
DEmark
Joined: 30 Dec 2003 Posts: 218 Location: Maryland USA
Posted: Tue Nov 08, 2005 6:38 pm Post subject: |
It could also be an exhaust leak, check all your joints for full engagement and no leaks. |
Back to top |
BronxBaghira
Posted: Wed Nov 09, 2005 11:28 am Post subject: |
Thanks, I'll check all the fittings. |
Back to top |
Randew2U
Posted: Fri Nov 11, 2005 11:03 pm Post subject: |
Hey Bronx, Im up here near Albany with an 04 BP and there is a guy in Newburg who has some posts in here on his incredible engine build. It would be greeat if you guys want to meet up at the Americade Rally in Lake George next June or something to go for a ride. I just brought my bike in for the winter and want to do some nice mods. Randy |
Back to top |
F0ul_Oli
Joined: 01 Mar 2005 Posts: 103 Location: Deeside,North Wales,UK
Posted: Mon Nov 14, 2005 1:43 pm Post subject: |
It seems they do that!!
You need to get a tuning kit for the carb - although one great piece of advice on here was to remove the rubber surround - which stopped my popin!
Foul _________________ I will only run out of ways of modify the Baggy when it weighs less that 100 kg and runs 100 bhp at the back wheel!!
http://www.businessandit.co.uk - putting the IT in Profit! |
Back to top |
AtomicSpew
Joined: 31 May 2005 Posts: 40 Location: Santa Cruz, CA
Posted: Mon Nov 14, 2005 4:13 pm Post subject: |
Hey Bronx-
I concur: an '03 Baggy here with the M4 Carbon pipe: Popped like a bitch, which was easily fixed with a less-lean tuning (not 100% fixed, but much better), and the rubber-surround removal will also help, though I'm of a mind that it's there for a reason... |
Back to top |
thumperacer
Posted: Fri Mar 17, 2006 10:54 am Post subject: |
The popping is caused by a lean mixture off throttle. Try adjusting the needle and or the pilot jet screw. _________________ Thumpers rule! |
Back to top |
